Device required for VPN and Wifi
Dear Experts,
Can I use a Cisco SA 500 series Appliances for security, as my business is small.
Does this device support below mention VPN option for remote access
OR can you  people please suggest me any cisco device that should give me wireless  option and it should support below top 5 VPN option
IPsec Xauth RSA
IPsec Xauth PSK
IPsec hybrid RSA
L2TP/IPsec PSK
L2TP/IPsec RSA
PPTP
IPsec IKEv2 PSK
IPsec IKEv2 RSA
or any cisco device that should be cable of providing Wifi and the above mentioned VPN options for remote access.
As my company is small I don't want to use any VPN application for Remote access, just want to use in build VPN options available in Android and ios.
Your valuable advises and suggestions would be really appreciable.
I have been struggling to find the device that can fulfill my above requirement...Please help me.
Mohammed Rashid
9 Replies 9
The SA500 might provide VPN and Wifi, but as an EOL device not any security any more.
There are a couple of choices that you have:
  1. ASA 5506W has an integrated AP and has many security-functions and options for VPN. The setup and configuration needs some advanced knowledge.
  2. If you want a device that is really easy to manage, the Cisco Meraki MX64W could be the the best option. Wifi is integrated, VPN is supported by the build-in clients of common OS like L2TP/IPsec.
Hi Karsten,
Thanks for your valuable suggestions...really appreciate.
Does this Cisco Meraki MX64W device supports the below mentioned VPN options or can we configure this device to acts as VPN gateway with below options so that the remote users with android or Iphone can connect to this device.
Psec Xauth RSA
IPsec Xauth PSK
IPsec hybrid RSA
PPTP
IPsec IKEv2 PSK
IPsec IKEv2 RSA
no and yes, It doesn't support all these functions, but all common OS are supported:
https://documentation.meraki.com/MX-Z/Client_VPN/Client_VPN_OS_Configuration
Then What device would you recommend if I want to go with all those  VPN options..please let me know...
There must be some device that supports all those things including wifi
Then go for the ASA 5506W.
Then it means all those VPN options and including WIFI feature is available with that device.
Basically yes:
1) IPSec xauth and hybrid. That's EasyVPN server. Legacy technology from last century but VPN3000 -> PIX -> ASA have been the typical VPN gateways for this technology with lots of options.
2) IKEv2 with native clients is supported, at least for Windows.
3) PPTP? Don't know if that"s still supported. But you shold use instead clear text communication which has an overall better security level.
Regardless of these options, I would also consider buying Anyconnect licenses for VPN.
Hey Karsten,
Thanks very much for your help.
one last question... Till now I was using TPlink wireless 3g router and now I will get rid of that one... for connectivity I was using USB 3G dongle and the IP address was changing very often..
I think I should go for new DSL connection with static public IP for these VPNs to work.
Usually ISPs in my area they take one public IP and do Natting for many home users, as the normal home users they don't need public static IP and due to which we are not able to remotely access our routers.
I think I should request specifically to my ISP for one public static IP.
what do you say on this...Any recommendation on this also would be appreciable.
For all kind of remote access VPN you need to have a public IP that is not filtered from the internet. If the provider only provides a private IP you can't configure any inbound services. If that's the case, you could still use services like Teamviewer or AnyDesk to access the PCs in your office.
