Dial in Problem over AUX of Cisco 2811 Terminal Router
hiteshoberai
I want to do a remote dial in to Cisco 2811 Terminal Router over AUX.
I am not able to connect whenever i dial i only get the dial tone i had attached USR modem to the AUX port of the Router
Terminal Router Config
version 12.4
service password-encryption
hostname ANDIPCTER01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret
no aaa new-model
ip cef
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip host ANDINETPIX01 2075 1.1.1.1
ip host ANDIPCSW01 2071 1.1.1.1
ip host ANDIPCSW02 2072 1.1.1.1
ip host ANDIPCPIX02 2070 1.1.1.1
ip host ANDIPCPIX01 2069 1.1.1.1
ip host ANDACC03 2080 1.1.1.1
ip host ANDACC02 2081 1.1.1.1
ip host ANDACC01 2079 1.1.1.1
ip host ANDINETRTR01 2074 1.1.1.1
ip host ANDINETPIX02 2076 1.1.1.1
ip host ANDCORE01 2066 1.1.1.1
ip host ANDRTR01 2067 1.1.1.1
ip host ANDRTR02 2068 1.1.1.1
ip host ANDCORE02 2073 1.1.1.1
bridge irb
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface Async1
ip unnumbered Loopback0
encapsulation ppp
ppp authentication chap
interface BVI1
ip address 10.101.31.20 255.255.255.0
ip local pool TERMINAL 2.2.2.2 2.2.2.4
ip route 0.0.0.0 0.0.0.0 10.101.31.1
no ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 20 permit 10.101.32.32 0.0.0.31
access-list 20 permit 10.101.6.160 0.0.0.31
access-list 50 permit 10.101.39.17
access-list 50 permit 10.101.2.17
access-list 50 permit 10.101.32.32 0.0.0.31
access-list 50 permit 10.101.6.160 0.0.0.31
snmp-server community
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CCC
This system is for the use of authorized users only. Individuals
using this computer system without authority, or in excess of their
system monitored and recorded.
In the course of monitoring individuals improperly using this
system, or in the course of system maintenance, the activities of
authorized users also are monitored.
Anyone using this system expressly consents to such monitoring
and recording. Please be advised that unauthorized access to this
system is a violation of applicable laws. If monitoring
reveals possible evidence of criminal activity, system personnel
may provide that evidence to law enforcement officials.
=========================================================================^C
line con 0
exec-timeout 1 0
login local
line aux 0
exec-timeout 0 0
password 7 #####
login
modem InOut
transport preferred none
transport input all
speed 115200
flowcontrol hardware
line 1/0 1/15
transport input all
line vty 0 4
access-class 20 in
exec-timeout 1 0
login local
transport input all
line vty 5 15
access-class 20 in
exec-timeout 1 0
login local
transport input all
scheduler allocate 20000 1000
Pls suggest where is the problem or solution
Not applicable
What kind of cabling are you using? See this link for proper cabling setup:
http://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094ce6.shtml
You configuration looks ok. Here are some links for attaching a modem to an AUX port in case you haven't seen them already:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a008009428b.shtml
Please rate this post and mark as solved if applicable.
Makarand Chitale
If I understand correctly this is being used for out of band access to the 2800 (for management purpose) - correct?
On the USR modem
- Have dip switches 3 & 8 down, rest up.
- Reverse telnet to the modem and add
at&f1s0=1&c1&d2&a1&w
Config on aux port is fine (if we are not doing ppp), make sure cable is roll over cable between USR modem and aux port.
Mak
dacruzer1
Thanks Everyone.  I will try your recommendations.
Alfred
