Dial in problem when using type 5 encryption
fahmyaziz
Community Member
Hi. I have a Cisco 3725 multiservice access router and have clients dialing in to it. Currently all the users are using a type 7 password encryption. When I switch them to type 5, my clients are not able to authenticate with my router. Is there anyway around this problem (either on the router or on my clients side)? Thanks
lgijssel
Level 11
Level 11
Can you post the output from "debug ppp neg" ?
That will enable us to see what is actually going on.
Leo
Hi Leo. This is the authentication part taken from the debug
*Mar 19 07:21:40.418: As76 LCP: State is Open
*Mar 19 07:21:40.418: As76 PPP: Phase is AUTHENTICATING, by this end
*Mar 19 07:21:40.418: As76 CHAP: O CHALLENGE id 73 len 30 from "ftprouter"
*Mar 19 07:21:40.566: As76 LCP: I IDENTIFY [Open] id 3 len 18 magic 0x678C0C38 MSRASV5.00
*Mar 19 07:21:40.586: As76 LCP: I IDENTIFY [Open] id 4 len 30 magic 0x678C0C38 MSRAS-1-EDS-OPERATION1
*Mar 19 07:21:40.586: As76 CHAP: I RESPONSE id 73 len 25 from "bcbb"
*Mar 19 07:21:40.586: As76 PPP: Phase is FORWARDING, Attempting Forward
*Mar 19 07:21:40.586: As76 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Mar 19 07:21:40.586: As76 CHAP: O FAILURE id 73 len 25 msg is "Authentication failed"
*Mar 19 07:21:40.586: As76 PPP: Sending Acct Event[Down] id[477]
*Mar 19 07:21:40.586: As76 PPP: Phase is TERMINATING
*Mar 19 07:21:40.586: As76 LCP: O TERMREQ [Open] id 186 len 4
*Mar 19 07:21:40.882: As76 LCP: I TERMACK [TERMsent] id 186 len 4
*Mar 19 07:21:40.882: As76 LCP: State is Closed
*Mar 19 07:21:40.882: As76 PPP: Phase is DOWN
*Mar 19 07:21:40.882: As76 PPP: Phase is ESTABLISHING, Passive Open
*Mar 19 07:21:40.882: As76 LCP: State is Listen
*Mar 19 07:21:40.962: %ISDN-6-DISCONNECT: Interface BRI1/0:2 disconnected from 0389252206 , call lasted 40 seconds
*Mar 19 07:21:42.882: %LINK-5-CHANGED: Interface Async76, changed state to reset
*Mar 19 07:21:42.882: As76 LCP: State is Closed
*Mar 19 07:21:42.882: As76 PPP: Phase is DOWN
*Mar 19 07:21:47.882: %LINK-3-UPDOWN: Interface Async76, changed state to down
Any ideas?
This appears to bw not-supported. I have found the answer in the link below:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087cb1.html#wp1025388
Leo
Thanks Leo. Looks like I have to find another way to secure the passwords. Cheers
