Dialer interface issue.
suresharja
Level 3
Level 3
Hi All,
I have three interfaces as follows:
interface Dialer1
description DIALER INTERFACE TO Branch
ip address 172.16.254.62 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name branch
dialer string xxxxxx
dialer-group 1
ppp authentication chap pap
interface Dialer2
description DIALER INTERFACE TO Region
ip address 172.16.254.106 255.255.255.252
encapsulation ppp
delay 6000
dialer pool 1
dialer remote-name region
dialer idle-timeout 60
dialer string xxxxxxxxx
dialer-group 1
interface Dialer3
description DIALER INTERFACE TO Central
ip address 172.22.16.62 255.255.255.252
encapsulation ppp
delay 12000
dialer pool 1
dialer remote-name central
dialer idle-timeout 30
dialer-group 1
no cdp enable
access-list 111 deny eigrp any any
access-list 111 deny udp any any eq snmp
access-list 111 deny udp any any eq snmptrap
access-list 111 permit ip any any
Dialer-list 1 protocol ip list 111
Question: When I create interesting traffic which Dialer will cause dial ? Iam using EIGRP. When leased line is down none of the above dialers are dialing out.why?
Can anybody help me out??
Thanks.
Suresh
Georg Pauwen
Hello Suresh,
which interfaces are you backing up ? Can you post the entire configuration of your router ?
GP
Hi GP,
Entire Router configuration is posted.My question is when leased line goes down, Which dialer interface is activated and why?
Requirement is : If Dialer1 fails to connect to branch, then Dialer2 should dial to Region, and incase both dialers fail ultimately Dialer3 should dial to Central Office. How can I achieve this ??
R1#sh run
Building configuration...
Current configuration : 3034 bytes
version 12.3
service password-encryption
hostname R1
enable secret 5 xxxxxxxxxxxxxxx
username xxxx password 0 xxxxxx
username xxxxx password 0 xxxxx
no aaa new-model
ip subnet-zero
no ip domain lookup
isdn switch-type basic-net3
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
interface FastEthernet0
description Connected to Local Lan
ip address 10.133.14.129 255.255.255.128
ip access-group 101 in
ip accounting output-packets
speed auto
interface Serial0
description CONNECTED TO BRANCH
ip address 172.16.8.6 255.255.255.252
encapsulation ppp
backup interface Dialer1
interface Serial1
no ip address
shutdown
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
interface Dialer2
encapsulation ppp
delay 6000
dialer pool 1
dialer-group 1
interface Dialer3
encapsulation ppp
delay 12000
dialer pool 1
dialer-group 1
no cdp enable
router eigrp 100
network 10.133.14.128 0.0.0.127
network 172.16.8.4 0.0.0.3
network 172.16.254.60 0.0.0.3
network 172.16.254.104 0.0.0.3
network 172.22.16.60 0.0.0.3
no auto-summary
ip classless
no ip http server
access-list 101 deny tcp any any eq 135
access-list 101 deny tcp any any eq 137
access-list 101 deny tcp any any eq 138
access-list 101 deny tcp any any eq 445
access-list 101 permit ip any any
line con 0
line aux 0
line vty 0 4
password xxxx
login
no scheduler allocate
end
Thanks.
Suresh
Hi Suresh,
You don't have any floating static routes to send traffic to the dialers. The backup int command only keeps the dialer in standby mode and EIGRP is denied from being interesting traffic to trigger a call. Try adding a static route for a destination pointing to one of the three dialer interfaces or allow EIGRP as interesting.
Hope this helps.
Danny
