DMVPN over IPSec problem
Fernandes
Hi, I have 2 DMVPN tunnel over IPSec with 2 two spoke.
One tunnel everything Okay. Tunnel UP
But second tunnel problem. DMVPN state IPSEC. I am getting these logs
IOS: c1100-universalk9.17.06.03a.SPA.bin
Router: cisco C1101-4PLTEP (1RU)
Interface: Tunnel14, IPv4 NHRP Details
Type:Spoke, NHRP Peers:2,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 xxxxxxxxxxxxx 172.21.0.1 IPSEC 00:01:02 S
1 xxxxxxxxxxxxx 172.21.0.2 NHRP 00:00:53 S
Jan 6 18:05:57: %CRYPTO_ENGINE-3-CSDL_COMPLIANCE_FAIL: Cisco PSB security compliance violation is detected. Use of MD5 by IPSEC key engine is denied
Jan 6 18:05:58: %CRYPTO_ENGINE-3-CSDL_COMPLIANCE_FAIL: Cisco PSB security compliance violation is detected. Use of MD5 by IPSEC key engine is denied
HUB LOGS
RTR01#sh crypto ipsec sa peer YYYYYYYY
interface: Tunnel14
Crypto map tag: vodmvpn-prof-pasha-head-1-IPv4, local addr XXXXXX
protected vrf: (none)
local ident (addr/mask/prot/port): (XXXXXXXX/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (YYYYYYYY/255.255.255.255/47/0)
current_peer YYYYYYY port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: XXXXXX, remote crypto endpt.: YYYYYYY
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb Port-channel44.357
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
interface: Tunnel12
Crypto map tag: vodmvpn-prof-pasha-head-1-IPv4, local addr XXXXXXX
local ident (addr/mask/prot/port): (XXXXXXX/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (YYYYYYY/255.255.255.255/47/0)
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb Port-channel44.390
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
RTR01#
since one tunnel is work and one not
add another transform with SHA/SHA2 instead of MD5 with AH.
this make both tunnel work.
if remove the OLD transform and add new one then you need to add this new in all spoke.
5 Replies 5
@Fernandes use SHA or SHA2
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb76866
Conditions: IPSec tunnel configured with DES/3DES as the encryption algorithm or MD5 HMAC algorithm in the transform set.
Workaround: Use different encryption or HMAC algorithm within the IPSec transform set.
Further Problem Description: An additional fix from CSCwb78173 is needed to completely fix this issue.
Fernandes
@Rob Ingram @MHM Cisco World Thank u so much
Solved problem
I use this encryption
crypto isakmp policy 10
encryption aes 256
hash sha256
authentication pre-share
group 14
and
crypto ipsec transform-set xxxxx esp-aes 256 esp-sha256-hmac
mode transport
You are so welcome
Please remember to select a correct answer as this not only helps others that might have the same problem bot also rewards the experts that have answered your question.
Please remember to select a correct answer and rate helpful posts
