dmvpn problem
daniel f.
Frequent Visitor
Frequent Visitor
hello together,
i have a dmvpn configuration with dual hub and ospf.
i had one spoke and now added another spoke. but i dont want both spokes to open a tunnel with each other, i want all traffic going through the hub.
with "tunnel mode gre ip" on a spoke the spoke dont do anything, i dont see the 2 hubs as ospf neighbors anymore. the hubs are configured as follows:
interface Tunnel0
 bandwidth 100000
 ip address 172.16.5.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp authentication test
 ip nhrp map multicast dynamic
 ip nhrp network-id 100000
 ip nhrp holdtime 600
 ip ospf network broadcast
 ip ospf priority 2
 delay 1000
 tunnel source GigabitEthernet0/0
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile Profile
end
and the spokes:
interface Tunnel0
 description VPN
 bandwidth 1000
 ip address 172.16.5.13 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nat outside
 ip nhrp map multicast x.x.x.1 <-official ips of the hubs masked
 ip nhrp map 172.16.5.1 x.x.x.1
 ip nhrp map multicast x.x.x.2
 ip nhrp map 172.16.5.2 x.x.x.2
 ip nhrp holdtime 300
 ip nhrp nhs 172.16.5.1
 ip nhrp nhs 172.16.5.2
 ip virtual-reassembly in
 ip ospf priority 0
 ip ospf cost 5000
 delay 1000
 tunnel source Dialer1
 tunnel key 100000
i have seen routes from one spoke at the other spoke so i made a routemap filtering that routes so that in routing table it takes default route to hub and not to spoke but they still try to open a tunnel with each other which is blocked by incomg acl so the traffic is flowing as intended but i dont want the spokes always trying to open a tunnel they shouldnt. i just want to have dmvpn phase 1
re775
Level 2
Level 2
Please try "ip ospf network point-to-multipoint" on all the hub and spoke routers.
Also, it would be helpful if you can post the ipsec portion of the config  (minus any security info).
Best of luck with your setup.
re775
Level 2
Level 2
daniel f.
Frequent Visitor
Frequent Visitor
thank you, its working 🙂
Hi Daniel,
Do you want to mark the answer from re775@nyu as correct answer?
