DMVPN Problem
sadist001
Level 2
Level 2
I have configured Dual Hub VPN, connection with first Hub Established successfully, but there is problem with another one.
Configuration is identical.
on spoke I see next situation (show dmvpn detail):
Interface: Tunnel255
Session: [0x7F6EA7A5F8]
Session ID: 0
IKEv1 SA: local 92.51.*.*/500 remote 95.104.*.*/500 Active
Capabilities:(none) connid:1360 lifetime:19:59:36
Session ID: 0
IKEv1 SA: local 92.51.*.*/500 remote 95.104.**/500 Inactive
Capabilities:(none) connid:1359 lifetime:0
Crypto Session Status: UP-ACTIVE
fvrf: (none), Phase1_id: 95.104.*.*
IPSEC FLOW: permit 47 host 92.51.*.* host 95.104.*.*
Active SAs: 2, origin: crypto map
Inbound: #pkts dec'ed 0 drop 0 life (KB/Sec) 4608000/3576
Outbound: #pkts enc'ed 12 drop 0 life (KB/Sec) 4607998/3576
Outbound SPI : 0x7D25AF98, transform : esp-256-aes esp-sha256-hmac
Socket State: Open
On HUB Isee:
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 UNKNOWN 172.31.*.* IKE never IX
Where is the problem?
Yes, you are right.
Problem has been solved.
I have delete unusable IPSec profile and its helped.
10 Replies 10
balaji.bandi
how is your topology diagram, they use same link to connect to anther hub or use different Interface ?
Look at the good example :
https://knowtoshare.wordpress.com/2017/01/06/cisco-dmvpn-dual-hub-single-topology/
BB
Topology is simple.
I Have 2 Hubs, each spoke mush connect to them. There are no problem with connection between Hub-1 and spoke, but connection is not establishing with Hub-2. Configuration is the same but... Same Physical Link.
Can you post the spoke config for both
BB
Spoke Config:
interface Tunnel255
description Hub_1
ip address 172.31.100.250 255.255.255.0
ip mtu 1400
ip nhrp authentication AGNHRP
ip nhrp map 172.31.100.254 95.104.*.*
ip nhrp map multicast 95.104.*.*
ip nhrp network-id 255
ip nhrp nhs 172.31.100.254
ip tcp adjust-mss 1360
tunnel source 92.51.*.*
tunnel destination 95.104.*.*
tunnel key 255
tunnel protection ipsec profile Profile-IKEv1
interface Tunnel254
description Hub_2
ip address 172.31.101.250 255.255.255.0
ip mtu 1400
ip nhrp map 172.31.101.254 5.10.*.*
ip nhrp map multicast 5.10.*.*
ip nhrp network-id 254
ip nhrp nhs 172.31.101.254
tunnel destination 5.10.*.*
tunnel key 254
Hub 1 Config:
interface Tunnel255
description Hub_1
ip address 172.31.100.254 255.255.255.0
no ip redirects
ip mtu 1400
tunnel source 95.104.*.*
tunnel mode gre multipoint
tunnel key 255
Hub 2 Config:
interface Tunnel254
description Hub_2
ip address 172.31.101.254 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast dynamic
tunnel source 5.10.*.*
tunnel key 254
end
Hub-1 is ISR4431, Hub-2 is ISR4331.
Spoke is 1100.
There is no ip nhrp map multicast dynamic command on Hub-1 because its implicity command.
use share as a IPSec profile.
As I know shared profile uses when source is Interface, not IP Address. As source I use IP Address.
As I know tunnel source be ip address or interface because it same for two tunnel then the IPSec shared must be used.
Yes, you are right.
you are so welcome friend.
sadist001
Level 2
Level 2
any ideas?
