DMVPN spoke tunnel up/down after changing hub isp ip
adavisvpn
crypto isakmp policy 1
encr aes 192
authentication pre-share
crypto isakmp policy 2
encr aes 256
group 5
lifetime 10800
crypto isakmp key DesMv90 address (change to new ip)
crypto isakmp key DY3S-h3xp0l1 address xxxxxxx
crypto isakmp key DY3S-h3xp0l1 address xxxxxxxx
crypto isakmp keepalive 10 10
crypto ipsec transform-set AES-256 esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
interface Tunnel0
bandwidth 1000
ip address 192.168.106.2 255.255.255.0
ip mtu 1400
ip nhrp authentication DMVPN_NW
ip nhrp map 192.168.106.1 (changed to new ip)
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp nhs 192.168.106.1
ip tcp adjust-mss 1360
ip ospf network point-to-multipoint
ip ospf mtu-ignore
delay 1000
tunnel source Cellular0
tunnel destination (changed to new ip)
tunnel key 100000
tunnel protection ipsec profile CiscoCP_Profile1
interface Cellular0
ip address negotiated
this was the only changes, should be no issues, but the tunnel protocol is down.  Help?
28 Replies 28
Sorry that acl is for a p-2-p vpn that is working.  Below is the MDVPN Config for the hub and spoke without the other vpn's config components:
HUB:
encr aes 192
crypto isakmp key ?????? address 0.0.0.0
mode transport
interface Tunnel2
bandwidth 1000
ip address 192.168.xxxx 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast dynamic
ip nhrp nhs 192.168.xxxxxx
ip nhrp registration no-unique
ip ospf mtu-ignore
delay 1000
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description wan$ETH-WAN$
ip address xxxxxxxxxxx 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/1
description lan$ETH-LAN$
ip address 192.168.xxxxx 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
router ospf 11
network 192.168.xxxxx 0.0.0.255 area 3
router iso-igrp area_1
net 49.0001.7c0e.ce5b.d720.00
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 104.184.14.118
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip route 8.8.8.8 255.255.255.255 GigabitEthernet0/0 104.184.14.118
ip route xxxxxxxxxx 255.255.255.0 192.168.xxxx
logging dmvpn rate-limit 20
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.xxxx 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.xxxxx 0.0.0.255
dialer-list 1 protocol ip permit
spoke:
hostname router2 this is the spoke
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
ip domain name yourdomain.com
ip name-server xxxxxxxxxx
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
object-group network local_cws_net
object-group network local_lan_subnets
any
object-group network vpn_remote_subnets
any
redundancy
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
encr aes 192
crypto isakmp key ?????? address xxxxxxx
mode transport
interface Tunnel0
bandwidth 1000
ip mtu 1400
ip nhrp map 192.168.xxxxx xxxxxxxxxxx
ip ospf mtu-ignore
delay 1000
tunnel destination xxxxxxxxxxxxx
tunnel key 100000
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
no peer default ip address
async mode interactive
crypto map CMAP_1
routing dynamic
description $ETH-LAN$
ip address xxxxxxxxxxx 255.255.255.240
ip nat inside
ip tcp adjust-mss 1400
ip policy route-map clear-df
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.128
ip tcp adjust-mss 1452
router ospf 11
network xxxxxxxxxxx 0.0.0.15 area 3
ip http server
ip nat inside source route-map SDM_RMAP_1 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
dialer-list 1 protocol ip list 1
ipv6 ioam timestamp
route-map SDM_RMAP_1 permit 1
match ip address NAT
access-list 23 remark CCP_ACL Category=17
access-list 23 permit 10.10.10.0 0.0.0.127
access-list 23 permit xxxxxxxxxxxx 0.0.0.255
access-list 23 permit 192.168.xxxxxx 0.0.0.15
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
These are not identical
crypto isakmp key ?????? address 104.184.14.113
ip nhrp map 192.168.106.1 65.15.162.127
sorry.  I used the config before i changed the ISP to send and changed ips, missed that one.  The nhrp map is 192.168.xxxxx xxxxxxxxxxx.  I made these changes because of the hub isp ip changing:
crypto isakmp key DesMv90 address xxxxxxxxxx
ip nhrp map 192.168.106.1 xxxxxxxxxx
That's it.
Please share last correct config of both hub and spoke.
MHM
adavisvpn
It is looking like the only option is to delete the DMVNP hub and spoke tunnels, crypto, and isa's and start all over if no one has any other ideas.  This should not be this difficult.
I received it before two-three hrs
Just give me some time.
MHM
for 1:  is this right?
Tunnel0
2.  Is this right?
crypto isakmp key DesMv90 address 0.0.0.0
sorry this answer for my two point or other thing ?
If I have two types of tunnels with two cypto isakmp polices, how to I specifiy which poliyc each crypto isakmp key's use?
Ex.
encr 3des
hash md5
group 2
encr aes 192
crypto isakmp key other_tunnel key address xxxxxxxxxxxx
crypto isakmp key dmvmp_tunnel address 0.0.0.0
First tunnel down issue solved?
The routers send both policy and peer will select one match it own' so there is no problem with this.
So all work not help you to solve issue.
Goodluck when you talk with ISP.
MHM
