DNS problem when using VPN connection between Cisco 800 Series and iPhone 4S
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-13-2012 08:29 AM
has anybody configured a VPN connection between a 800 series Router and an iPhone 4S unsing the internal iPhone Cisco VPN client? I solved the VPN connection, but I can't use DNS, but why?
Via ICMP is the DNS server reachable
Internal DNS: 10.0.0.11
Configuration:
version 12.4
no service pad
service password-encryption
hostname router
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 <removed>
aaa new-model
aaa authentication login CONSOLE local-case
aaa authentication login VTY local-case
aaa authentication login AUX local-case
aaa authentication login CRYPTO_ISAKMP_CLIENT local
aaa authentication enable default enable
aaa authorization network CRYPTO_ISAKMP_CLIENT local
aaa session-id common
resource policy
ip cef
no ip domain lookup
ip domain name intra.local
ip ssh version 2
username kon privilege 15 secret 5 <removed>
crypto logging session
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
lifetime 3600
crypto isakmp keepalive 10
crypto isakmp nat keepalive 20
crypto isakmp xauth timeout 90
crypto isakmp client configuration group CRYPTO_ISAKMP_CLIENT
key <removed>
dns 10.0.0.11
domain intra.local
pool VPN-POOL
save-password
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association idle-time 3600
crypto ipsec transform-set VPN-TRANSFORMSET esp-aes 256 esp-sha-hmac
crypto dynamic-map CRYPTO_ISAKMP_CLIENT 1
set transform-set VPN-TRANSFORMSET
crypto map STATIC_CRYPTO_MAP local-address Dialer0
crypto map STATIC_CRYPTO_MAP client authentication list CRYPTO_ISAKMP_CLIENT
crypto map STATIC_CRYPTO_MAP isakmp authorization list CRYPTO_ISAKMP_CLIENT
crypto map STATIC_CRYPTO_MAP client configuration address respond
crypto map STATIC_CRYPTO_MAP 1 ipsec-isakmp dynamic CRYPTO_ISAKMP_CLIENT
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description "-> WAN"
no snmp trap link-status
pvc 1/32
pppoe-client dial-pool-number 1
interface FastEthernet0
description <removed>
duplex full
speed 100
interface FastEthernet1
duplex full
speed 100
interface FastEthernet2
duplex full
speed 100
interface FastEthernet3
duplex full
speed 100
interface Virtual-Template1 type tunnel
description "Used for Dialer 0 Crypto map"
ip unnumbered Dialer0
tunnel mode ipsec ipv4
interface Vlan1
description "-> LAN"
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
description "WAN"
ip address negotiated
ip mtu 1452
ip nat outside
ip access-group 101 in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname <removed>
ppp chap password <removed>
ip local pool VPN-POOL 192.168.0.200 192.168.0254
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip access-list standard VTY
permit 10.0.0.0 0.0.0.255
logging trap debugging
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 101 remark ---> Internet LAN
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 permit udp any any eq isakmp
access-list 101 permit udp any any eq non500-isakmp
access-list 101 deny icmp any any
dialer-list 1 protocol ip permit
control-plane
banner motd $
| Security disclaimer |
| This computer system is for authorized users only. All activity is |
| logged and regulary checked by systems personal. Individuals using |
| this system without authority or in excess of their authority are |
| subject to having all their services revoked. Any illegal services |
| run by user or attempts to take down this server or its services |
| will be reported to local Network Services department. Anyone using |
| this system consents to these terms. |
line con 0
exec-timeout 20 0
login authentication CONSOLE
no modem enable
line aux 0
exec-timeout 20 0
login authentication AUX
transport input ssh
line vty 0 4
access-class VTY in
exec-timeout 20 0
login authentication VTY
transport input ssh
scheduler max-task-time 5000
ntp logging
ntp master 2
ntp server 192.53.103.108 source dialer 0 prefer
ntp server 129.187.254.32 source dialer 0
end
- Labels:
VPN
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-22-2013 06:46 AM
solved the problem by my self. One statement was missing. IT was reverse-route, which is requiered to create the routing entries.
reverse-route
