dynamic ip FlexVPN Hub-and- dynamic ip multi Spoke
katheer_4u
Good day
Hi Everyone,
I'm having some trouble with FlexVPN in a Hub & multi Spoke i have both site are dynamic ip. actually the VPN is up but when i trying to configure the 2nd spoke 1 st one getting down and when i restrat the 1st one its getting VPN up but 2nd one its getting down
if anyone can help me i really appreciated
HUB
HO-FLXVPN#show running-config
Building configuration...
Current configuration : 3455 bytes
! Last configuration change at 15:26:37 UTC Thu Jan 23 2020 by ciscouser
version 15.5
no platform punt-keepalive disable-kernel-core
hostname HO-FLXVPN
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authorization network default local
aaa session-id common
ip domain name mm.com
subscriber templating
license udi pid ISR4331/K9 sn FDO20432DC6
license boot level securityk9
redundancy
mode none
crypto ikev2 authorization policy POC-AUTH-POL-01
route set interface
route set access-list POC-ROUTE-ACL-01
crypto ikev2 authorization policy FLEX-AUTH-POL-01
route set interface
route set access-list FLEX-ROUTE-ACL-01
crypto ikev2 proposal POC-PROP-01
encryption aes-cbc-128
integrity sha256
group 19
crypto ikev2 policy POC-POL-01
match fvrf any
crypto ikev2 profile POC-IKEV2-PROFILE-01
match identity remote address 0.0.0.0
identity local address 192.168.100.222
authentication remote pre-share key 6 cisco123
authentication local pre-share key 6 cisco123
aaa authorization group psk list default FLEX-AUTH-POL-01
virtual-template 23
vlan internal allocation policy ascending
crypto ipsec transform-set POC-IPSEC-TS-01 esp-aes esp-md5-hmac
mode transport
crypto ipsec profile POC-IPSEC-PROF-01
set transform-set POC-IPSEC-TS-01
set ikev2-profile POC-IKEV2-PROFILE-01
interface GigabitEthernet0/0/0
ip address 192.168.100.222 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Virtual-Template23 type tunnel
ip unnumbered Vlan1
ip nhrp network-id 23
ip nhrp redirect
tunnel source GigabitEthernet0/0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile POC-IPSEC-PROF-01
interface Vlan1
ip address 192.168.250.1 255.255.255.0
ip nat inside
ip nat inside source list 20 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/1/0
ip route 0.0.0.0 0.0.0.0 192.168.100.1
ip route 192.168.42.0 255.255.255.0 192.168.250.2
ip route 192.168.101.0 255.255.255.0 192.168.250.2
ip route 192.168.203.0 255.255.255.0 192.168.250.2
ip ssh rsa keypair-name mm.com
ip access-list standard FLEX-ROUTE-ACL-01
permit 192.168.101.0 0.0.0.255
permit 192.168.203.0 0.0.0.255
permit 192.168.42.0 0.0.0.255
ip access-list standard POC-ROUTE-ACL-01
permit any
access-list 20 permit 192.168.250.0 0.0.0.255
access-list 21 permit 192.168.203.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 21 in
transport input all
end
Spoke
Branch#show running-config
Current configuration : 2825 bytes
version 15.3
hostname Branch
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip name-server 216.146.35.35
ip name-server 216.146.36.36
ip cef
no ipv6 cef
license udi pid C887VAM-K9 sn FCZ1950929W
route set interface
integrity sha256
group 19
match fvrf any
identity local address 192.168.100.250
virtual-template 23
crypto ikev2 client flexvpn POC-FLEX-CLIENT-01
peer 1 fqdn xxxxxxx.dyndns.org dynamic
client connect Tunnel23
controller VDSL 0
mode transport
interface Tunnel23
ip unnumbered Vlan1
ip nhrp redirect
tunnel source Vlan2
tunnel destination dynamic
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 2
no ip address
interface Vlan1
ip address 192.168.14.1 255.255.255.0
interface Vlan2
ip address 192.168.100.250 255.255.255.0
no ip http server
ip route 172.16.114.0 255.255.255.0 192.168.14.2
ip route 192.168.114.0 255.255.255.0 192.168.14.2
permit 192.168.114.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
scheduler allocate 20000 1000
end
Branch#show crypto ikev2 sa detailed
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 192.168.100.250/4500 89.211.152.117/4500 none/none READY
Encr: AES-CBC, keysize: 128, Hash: SHA256, DH Grp:19, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 86400/17018 sec
CE id: 2001, Session-id: 1
Status Description: Negotiation done
Local spi: 7435398A5B040F61 Remote spi: 9A900A01F9641E5B
Local id: 192.168.100.250
Remote id: 192.168.100.222
Local req msg id: 5 Remote req msg id: 6
Local next msg id: 5 Remote next msg id: 6
Local req queued: 5 Remote req queued: 6
Local window: 5 Remote window: 5
DPD configured for 0 seconds, retry 0
Fragmentation not configured.
Extended Authentication not configured.
NAT-T is detected inside
Cisco Trust Security SGT is disabled
Initiator of SA : Yes
Remote subnets:
192.168.250.1 255.255.255.255
6 Accepted Solutions
Can you enable some debugs "debug crypto ikev2" and "debug aaa authorization" on both the hub and spoke prior to establishing a VPN from the other spoke, then upload the output of when the tunnel fails.
On the spoke you are referencing a Virtual-Template which you don't have defined in your configuration, can you remove it and try again.
Can you also provide the configuration of the other spoke.
Can you try establishing the tunnel without authorisation just for testing, this would confirm whether it's authorisation that could be causing the issue.
From that error it looks like the router cannot resolve the dyndns name. You don't appear to have your name-servers defined as you do on the other spoke.
...but if that was the case the VPN would not have established in the first place. In your initial post you mentioned the VPN on this 2nd spoke did briefly establish.
What about providing the debugs for review?
hi
in the branch 2 already add the in the ikev2 authorization policy FLEX-AUTH-POL-01
permit 192.168.121.0 0.0.0.255
route set interface
virtual-template 23
hub
HO-FLXVPN#show crypto ikev2 sa detail
2 192.168.100.222/4500 37.210.165.251/4500 none/none READY
Encr: AES-CBC, keysize: 128, PRF: SHA256, Hash: SHA256, DH Grp:19, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 86400/630 sec
CE id: 1006, Session-id: 6
Local spi: 4E6743C21E7F38E9 Remote spi: 35C7F3F6FD62FC3B
Local id: 192.168.100.222
Remote id: 192.168.100.250
Local req msg id: 0 Remote req msg id: 3
Local next msg id: 0 Remote next msg id: 3
Local req queued: 0 Remote req queued: 3
Initiator of SA : No
Remote subnets:
192.168.14.1 255.255.255.255
IPv6 Crypto IKEv2 SA
The authorisation policy was not defined in the ikev2 profile in the initial configuration you provided.
Regardless, it looks like you have defined the same local identity under the ikev2 profile of both spokes. The need to be unique, that's going to confuse the hub.
identity local address 192.168.100.250 << change this on spoke2
I assume that debug is from branch2 spoke, can that branch2 router even communicate/ping the hub?
Can you run ikev2 debug on the hub when you attempt to establish the tunnel please, upload the output here.
Can you upload the current configuration of the hub and both spokes, please upload them as text file makes it easier to review.
If the hub and branch2 spoke cannot communicate with each other (which is what it looks like from your ikev2 debugs) then no tunnel will be established. You need to get them communicating with each other.
Are you pinging using the FQDN or are pinging using the IP address? If you are relying on DNS resolution, I suggest checking DNS is still working, clear the cache and get the 2 routers to communicate with each other....then hopefully the VPN should re-establish.
16 Replies 16
1st of all thanks a lot for the prompt reply
Please see the below Spoke 2 (Branch 2) configuration and now i'm wondering it's given new error even its not getting up and there is not any hit in hub
New Spoke (branch 2) Error
*Jan 23 18:15:30.000: Domain: query for xxxxx.dyndns.org type 1 to 255.255.255.255timed out
*Jan 23 18:15:42.000: Domain: query for xxxxx.dyndns.org type 1 to 255.255.255.255timed out
*Jan 23 18:15:54.000: Domain: query for xxxxx.dyndns.org type 1 to 255.255.255.255timed out
*Jan 23 18:16:05.999: Domain: query for xxxxx.dyndns.org type 1 to 255.255.255.255timed out
*Jan 23 18:16:17.999: Domain: query for xxxxx.dyndns.org type 1 to 255.255.255.255timed out
*Jan 23 18:16:29.999: Domain: query for xxxxx.dyndns.org type 1 to 255.255.255.255timed out
Branch2
Branch2 #show running-config
Current configuration : 2807 bytes
! Last configuration change at 18:14:01 UTC Thu Jan 23 2020
version 15.5
hostname Branch2
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
ip cef
no ipv6 cef
cts logging verbose
route set interface
integrity sha256
group 19
match fvrf any
peer 1 fqdn xxxxx.dyndns.org dynamic
controller VDSL 0
crypto ipsec transform-set POC-IPSEC-TS-01 estimed outp-aes esp-md5-hmac
mode transport
interface Tunnel23
ip unnumbered Vlan1
ip nhrp redirect
tunnel source Vlan2
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address 192.168.21.1 255.255.255.0
interface Vlan2
no ip http server
ip route 172.16.121.0 255.255.255.0 192.168.21.2
ip route 192.168.121.0 255.255.255.0 192.168.21.2
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
end
Please see the below Spoke 2 (Branch 2) configuration and when i enter the ip name-server in branch 2 VPN was UP but branch 1 its down
see those logs and after i restart the branch 1 its up, now its seem both are VPN lights are up but unable to ping form the branch 2 to hub
in Hub there is no debugs for review
Branch 2 (config)#ip name-server 216.146.35.35
Branch 2 (config)#ip name-server 216.146.36.36
*Jan 23 19:31:07.487: Domain: query for xxxxx.dyndns.org type 1 to 316.146.35.35 Reply received ok
*Jan 23 19:31:07.647: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Jan 23 19:31:07.651: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 19:31:07.651: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 19:31:07.655: IKEv2:(SESSION ID = 1,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH public key, DH Group 19
*Jan 23 19:31:07.655: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Jan 23 19:31:07.655: IKEv2:(SESSION ID = 1,SA ID = 1):Request queued for computation of DH key
*Jan 23 19:31:07.655: IKEv2:IKEv2 initiator - no config data to send in IKE_SA_INIT exch
*Jan 23 19:31:07.655: IKEv2:(SESSION ID = 1,SA ID = 1):Generating IKE_SA_INIT message
*Jan 23 19:31:07.655: IKEv2:(SESSION ID = 1,SA ID = 1):IKE Proposal: 1, SPI size: 0 (initial negotiation),
Num. transforms: 4
AES-CBC SHA256 SHA256 DH_GROUP_256_ECP/Group 19
*Jan 23 19:31:07.655: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.250:500/VRF i0:f0]
Initiator SPI : 190A0556C327099D - Responder SPI : 0000000000000000 Message id: 0
IKEv2 IKE_SA_INIT Exchange REQUEST
Payload contents:
SA KE N VID VID NOTIFY(NAT_DETECTION_SOURCE_IP) NOTIFY(NAT_DETECTION_DESTINATION_IP)
*Jan 23 19:31:07.655: IKEv2:(SESSION ID = 1,SA ID = 1):Insert SA
*Jan 23 19:31:07.707: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:500/To 192.168.100.250:500/VRF i0:f0]
Initiator SPI : 190A0556C327099D - Responder SPI : 83918630D3837E1A Message id: 0
IKEv2 IKE_SA_INIT Exchange RESPONSE
Payload contents:
*Jan 23 19:31:07.707: IKEv2:(SESSION ID = 1,SA ID = 1):Processing IKE_SA_INIT message
*Jan 23 19:31:07.707: IKEv2:(SESSION ID = 1,SA ID = 1):Verify SA init message
*Jan 23 19:31:07.711: IKEv2:(SESSION ID = 1,SA ID = 1):Checking NAT discovery
*Jan 23 19:31:07.711: IKEv2:(SESSION ID = 1,SA ID = 1):NAT INSIDE found
*Jan 23 19:31:07.711: IKEv2:(SESSION ID = 1,SA ID = 1):NAT detected float to init port 4500, resp port 4500
*Jan 23 19:31:07.711: IKEv2:(SESSION ID = 1,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH secret key, DH Group 19
*Jan 23 19:31:07.731: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Request queued for computation of DH secret
*Jan 23 19:31:07.731: IKEv2:(SA ID = 1):[IKEv2 -> Crypto Engine] Calculate SKEYSEED and create rekeyed IKEv2 SA
*Jan 23 19:31:07.731: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] SKEYSEED calculation and creation of rekeyed IKEv2 SA PASSED
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Completed SA init exchange
*Jan 23 19:31:07.731: IKEv2:Config data to send:
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-request
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-dns, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-nbns, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv6-dns, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv6-subnet, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 242, data: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(1)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 02-Mar-15 04:13 by prod_rel_team
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: split-dns, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: banner, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: config-url, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: backup-gateway, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: def-domain, length: 0
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Have config mode data to send
*Jan 23 19:31:07.731: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Generate my authentication data
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Use preshared key for id 192.168.100.250, key len 14
*Jan 23 19:31:07.735: IKEv2:[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
*Jan 23 19:31:07.735: IKEv2:[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Get my authentication method
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):My authentication method is 'PSK'
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Generating IKE_AUTH message
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Constructing IDi payload: '192.168.100.250' of type 'IPv4 address'
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):ESP Proposal: 1, SPI size: 4 (IPSec negotiation),
Num. transforms: 3
AES-CBC MD596 Don't use ESN
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Building packet for encryption.
Payload contents:
VID IDi AUTH CFG SA TSi TSr NOTIFY(INITIAL_CONTACT) NOTIFY(SET_WINDOW_SIZE) NOTIFY(ESP_TFC_NO_SUPPORT) NOTIFY(NON_FIRST_FRAGS)
*Jan 23 19:31:07.735: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:4500/From 192.168.100.250:4500/VRF i0:f0]
Initiator SPI : 190A0556C327099D - Responder SPI : 83918630D3837E1A Message id: 1
IKEv2 IKE_AUTH Exchange REQUEST
Payload contents:
ENCR
*Jan 23 19:31:07.815: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:4500/To 192.168.100.250:4500/VRF i0:f0]
IKEv2 IKE_AUTH Exchange RESPONSE
Payload contents:
VID IDr AUTH CFG SA TSi TSr NOTIFY(SET_WINDOW_SIZE) NOTIFY(ESP_TFC_NO_SUPPORT) NOTIFY(NON_FIRST_FRAGS)
*Jan 23 19:31:07.815: IKEv2:(SESSION ID = 1,SA ID = 1):Process auth response notify
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Searching policy based on peer's identity '192.168.100.222' of type 'IPv4 address'
*Jan 23 19:31:07.819: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 19:31:07.819: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Verify peer's policy
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Peer's policy verified
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Get peer's authentication method
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Peer's authentication method is 'PSK'
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Get peer's preshared key for 192.168.100.222
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Verify peer's authentication data
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Use preshared key for id 192.168.100.222, key len 14
*Jan 23 19:31:07.819: IKEv2:[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
*Jan 23 19:31:07.819: IKEv2:[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Verification of peer's authenctication data PASSED
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 19:31:07.819: IKEv2:Using mlist default and username FLEX-AUTH-POL-01 for group author request
*Jan 23 19:31:07.819: AAA/BIND(0000000D): Bind i/f
*Jan 23 19:31:07.819: AAA/AUTHOR (0xD): Pick method list 'default'
*Jan 23 19:31:07.819: IKEv2:(SA ID = 1):[IKEv2 -> AAA] Authorisation request sent
*Jan 23 19:31:07.819: IKEv2:(SA ID = 1):[AAA -> IKEv2] Received AAA authorisation response
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Received valid config mode data
*Jan 23 19:31:07.819: IKEv2:Config data recieved:
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-reply
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.250.1 255.255.255.255
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.101.0 255.255.255.0
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.203.0 255.255.255.0
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.42.0 255.255.255.0
*Jan 23 19:31:07.819: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 246, data: Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 25-Mar-16 16:59 by mcpre
*Jan 23 19:31:07.823: IKEv2:(SESSION ID = 1,SA ID = 1):Set received config mode data
*Jan 23 19:31:07.823: IKEv2:(SESSION ID = 1,SA ID = 1):Processing IKE_AUTH message
*Jan 23 19:31:07.823: IKEv2:IPSec policy validate request sent for profile POC-IKEV2-PROFILE-01 with psh index 1.
*Jan 23 19:31:07.823: IKEv2:(SA ID = 1):[IPsec -> IKEv2] Callback received for the validate proposal - PASSED.
*Jan 23 19:31:07.823: IKEv2:(SESSION ID = 1,SA ID = 1):IKEV2 SA created; inserting SA into database. SA lifetime timer (86400 sec) started
*Jan 23 19:31:07.823: IKEv2:(SESSION ID = 1,SA ID = 1):Session with IKE ID PAIR (192.168.100.222, 192.168.100.250) is UP
*Jan 23 19:31:07.823: IKEv2:IKEv2 MIB tunnel started, tunnel index 1
*Jan 23 19:31:07.823: IKEv2:(SESSION ID = 1,SA ID = 1):Load IPSEC key material
*Jan 23 19:31:07.823: IKEv2:(SA ID = 1):[IKEv2 -> IPsec] Create IPsec SA into IPsec database
*Jan 23 19:31:07.827: IKEv2:(SA ID = 1):[IPsec -> IKEv2] Creation of IPsec SA into IPsec database PASSED
*Jan 23 19:31:07.827: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-set
*Jan 23 19:31:07.827: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.21.1 255.255.255.255
*Jan 23 19:31:07.827: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.121.0 255.255.255.0
*Jan 23 19:31:07.827: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 242, data: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(1)T1, RELEASE SOFTWARE (fc2)
*Jan 23 19:31:07.827: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel23, changed state to up
*Jan 23 19:31:07.831: IKEv2:(SESSION ID = 1,SA ID = 1):Checking for duplicate IKEv2 SA
*Jan 23 19:31:07.831: IKEv2:(SESSION ID = 1,SA ID = 1):No duplicate IKEv2 SA found
*Jan 23 19:31:07.831: IKEv2:(SESSION ID = 1,SA ID = 1):Sending info exch config
*Jan 23 19:31:07.831: IKEv2:(SESSION ID = 1,SA ID = 1):Building packet for encryption.
Payload contents:
CFG
*Jan 23 19:31:07.831: IKEv2:(SESSION ID = 1,SA ID = 1):Checking if request will fit in peer window
*Jan 23 19:31:07.831: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:4500/From 192.168.100.250:4500/VRF i0:f0]
Initiator SPI : 190A0556C327099D - Responder SPI : 83918630D3837E1A Message id: 2
IKEv2 INFORMATIONAL Exchange REQUEST
Payload contents:
ENCR
*Jan 23 19:31:07.831: %FLEXVPN-6-FLEXVPN_CONNECTION_UP: FlexVPN(POC-FLEX-CLIENT-01) Client_public_addr = 192.168.100.250 Server_public_addr = 37.211.149.33
*Jan 23 19:31:07.871: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:4500/To 192.168.100.250:4500/VRF i0:f0]
IKEv2 INFORMATIONAL Exchange RESPONSE
Payload contents:
CFG
*Jan 23 19:31:07.871: IKEv2:(SESSION ID = 1,SA ID = 1):Processing ACK to informational exchange
*Jan 23 19:31:07.871: IKEv2:Config data recieved:
*Jan 23 19:31:07.871: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-ack
*Jan 23 19:31:07.871: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 0
*Jan 23 19:31:07.871: IKEv2:(SESSION ID = 1,SA ID = 1):Set received config mode data
HUB (HO-FLXVPN)
Gateway of last resort is 192.168.100.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.100.1
192.168.21.0/32 is subnetted, 1 subnets
S 192.168.21.1 is directly connected, Virtual-Access2
S 192.168.42.0/24 [1/0] via 192.168.250.2
192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.100.0/24 is directly connected, GigabitEthernet0/0/0
L 192.168.100.222/32 is directly connected, GigabitEthernet0/0/0
S 192.168.101.0/24 [1/0] via 192.168.250.2
S 192.168.121.0/24 is directly connected, Virtual-Access2
S 192.168.203.0/24 [1/0] via 192.168.250.2
192.168.250.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.250.0/24 is directly connected, Vlan1
L 192.168.250.1/32 is directly connected, Vlan1
But now still branch 2 VPN lights are UP but in hub there is no routing table or unable to ping hub
Branch2 #show crypto ikev2 sa detailed
1 192.168.100.250/4500 37.211.149.33/4500 none/none READY
Life/Active Time: 86400/988 sec
Local spi: 190A0556C327099D Remote spi: 83918630D3837E1A
Local req msg id: 3 Remote req msg id: 0
Local next msg id: 3 Remote next msg id: 0
Local req queued: 3 Remote req queued: 0
Remote subnets:
Branch 1 aftre restratrd
Branch 1# ping 192.168.250.1
Sending 5, 100-byte ICMP Echos to 192.168.250.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/12 ms
Branch 1 #show crypto ikev2 sa detailed
Life/Active Time: 86400/265 sec
Local spi: 71B4A7780B5A9464 Remote spi: ECAABF7773997035
Remote subnets:
HUB (HO-FLXVP)
HO-FLXVPN#show crypto ikev2 sa detailed
1 192.168.100.222/4500 37.210.165.251/4500 none/none READY
Life/Active Time: 86400/187 sec
CE id: 1003, Session-id: 3
Local spi: ECAABF7773997035 Remote spi: 71B4A7780B5A9464
Remote subnets:
Remote subnets:
now both branch 1 and branch 2 are showing crypto ikev2 sa detailed but im unable to ping branch 2 to hub
The branch2 spoke router is not sending it's local routes to the hub, you can determine this in the output of "show crypto ikev2 sa detail" on the hub. Add the authorisation policy "FLEX-AUTH-POL-01" to branch2 spokes' IKEv2 profile. This should send the 192.168.121.0 network to the hub.
Please see the below branch 2 debug preview
Branch 2
EZDANWAKARA#
*Jan 23 20:33:24.002: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 23 20:33:24.002: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.250:500/VRF i0:f0]
Initiator SPI : 82BDD478CC9187E5 - Responder SPI : 0000000000000000 Message id: 0
Payload contents:
*Jan 23 20:33:24.790: %FLEXVPN-6-FLEXVPN_CONNECTION_DOWN: FlexVPN(POC-FLEX-CLIENT-01) Client_public_addr = 192.168.100.250 Server_public_addr = 37.211.149.33
*Jan 23 20:33:34.790: Domain: query for xxxxxxxx.dyndns.org type 1 to 216.146.35.35Reply received ok
*Jan 23 20:33:34.950: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 20:33:34.950: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 20:33:34.950: IKEv2:SA is already in negotiation, hence not negotiating again
*Jan 23 20:33:55.198: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 23 20:33:55.198: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.250:500/VRF i0:f0]
Payload contents:
*Jan 23 20:34:04.950: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 20:34:04.950: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 20:34:04.950: IKEv2:SA is already in negotiation, hence not negotiating again
*Jan 23 20:34:34.949: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 20:34:34.949: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 20:34:34.949: IKEv2:SA is already in negotiation, hence not negotiating again
*Jan 23 20:34:57.293: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 23 20:34:57.293: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.250:500/VRF i0:f0]
Payload contents:
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:500/To 192.168.100.250:500/VRF i0:f0]
Initiator SPI : 82BDD478CC9187E5 - Responder SPI : 6CB68A02F68DAF0D Message id: 0
Payload contents:
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):Processing IKE_SA_INIT message
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):Verify SA init message
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):Checking NAT discovery
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):NAT INSIDE found
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):NAT detected float to init port 4500, resp port 4500
*Jan 23 20:34:57.361: IKEv2:(SESSION ID = 1,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH secret key, DH Group 19
*Jan 23 20:34:57.385: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Request queued for computation of DH secret
*Jan 23 20:34:57.385: IKEv2:(SA ID = 1):[IKEv2 -> Crypto Engine] Calculate SKEYSEED and create rekeyed IKEv2 SA
*Jan 23 20:34:57.385: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] SKEYSEED calculation and creation of rekeyed IKEv2 SA PASSED
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Completed SA init exchange
*Jan 23 20:34:57.385: IKEv2:Config data to send:
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-request
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-dns, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-nbns, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv6-dns, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv6-subnet, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 242, data: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(1)T1, RELEASE SOFTWARE (fc2)
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: split-dns, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: banner, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: config-url, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: backup-gateway, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: def-domain, length: 0
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Have config mode data to send
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Generate my authentication data
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Use preshared key for id 192.168.100.250, key len 14
*Jan 23 20:34:57.385: IKEv2:[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
*Jan 23 20:34:57.385: IKEv2:[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):Get my authentication method
*Jan 23 20:34:57.385: IKEv2:(SESSION ID = 1,SA ID = 1):My authentication method is 'PSK'
*Jan 23 20:34:57.389: IKEv2:(SESSION ID = 1,SA ID = 1):Generating IKE_AUTH message
*Jan 23 20:34:57.389: IKEv2:(SESSION ID = 1,SA ID = 1):Constructing IDi payload: '192.168.100.250' of type 'IPv4 address'
*Jan 23 20:34:57.389: IKEv2:(SESSION ID = 1,SA ID = 1):ESP Proposal: 1, SPI size: 4 (IPSec negotiation),
Num. transforms: 3
*Jan 23 20:34:57.389: IKEv2:(SESSION ID = 1,SA ID = 1):Building packet for encryption.
Payload contents:
*Jan 23 20:34:57.389: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:4500/From 192.168.100.250:4500/VRF i0:f0]
Initiator SPI : 82BDD478CC9187E5 - Responder SPI : 6CB68A02F68DAF0D Message id: 1
Payload contents:
ENCR
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:4500/To 192.168.100.250:4500/VRF i0:f0]
Payload contents:
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Process auth response notify
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Searching policy based on peer's identity '192.168.100.222' of type 'IPv4 address'
*Jan 23 20:34:57.465: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 20:34:57.465: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Verify peer's policy
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Peer's policy verified
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Get peer's authentication method
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Peer's authentication method is 'PSK'
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Get peer's preshared key for 192.168.100.222
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Verify peer's authentication data
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Use preshared key for id 192.168.100.222, key len 14
*Jan 23 20:34:57.465: IKEv2:[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
*Jan 23 20:34:57.465: IKEv2:[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
*Jan 23 20:34:57.465: IKEv2:(SESSION ID = 1,SA ID = 1):Verification of peer's authenctication data PASSED
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 20:34:57.469: IKEv2:Using mlist default and username FLEX-AUTH-POL-01 for group author request
*Jan 23 20:34:57.469: AAA/BIND(00000011): Bind i/f
*Jan 23 20:34:57.469: AAA/AUTHOR (0x11): Pick method list 'default'
*Jan 23 20:34:57.469: IKEv2:(SA ID = 1):[IKEv2 -> AAA] Authorisation request sent
*Jan 23 20:34:57.469: IKEv2:(SA ID = 1):[AAA -> IKEv2] Received AAA authorisation response
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Received valid config mode data
*Jan 23 20:34:57.469: IKEv2:Config data recieved:
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-reply
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.250.1 255.255.255.255
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.101.0 255.255.255.0
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.203.0 255.255.255.0
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.42.0 255.255.255.0
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 246, data: Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S3, RELEASE SOFTWARE (fc2)
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Error in settig received config mode data
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Auth exchange failed
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):: Auth exchange failed
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Abort exchange
*Jan 23 20:34:57.469: IKEv2:(SESSION ID = 1,SA ID = 1):Deleting SA
*Jan 23 20:35:04.949: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 20:35:04.949: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 20:35:04.949: IKEv2:(SESSION ID = 1,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH public key, DH Group 19
*Jan 23 20:35:04.949: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Jan 23 20:35:04.949: IKEv2:(SESSION ID = 1,SA ID = 1):Request queued for computation of DH key
*Jan 23 20:35:04.949: IKEv2:IKEv2 initiator - no config data to send in IKE_SA_INIT exch
*Jan 23 20:35:04.949: IKEv2:(SESSION ID = 1,SA ID = 1):Generating IKE_SA_INIT message
*Jan 23 20:35:04.949: IKEv2:(SESSION ID = 1,SA ID = 1):IKE Proposal: 1, SPI size: 0 (initial negotiation),
Num. transforms: 4
*Jan 23 20:35:04.949: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.250:500/VRF i0:f0]
Initiator SPI : 2EC958A5979924EA - Responder SPI : 0000000000000000 Message id: 0
Payload contents:
*Jan 23 20:35:04.949: IKEv2:(SESSION ID = 1,SA ID = 1):Insert SA
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:500/To 192.168.100.250:500/VRF i0:f0]
Initiator SPI : 2EC958A5979924EA - Responder SPI : FB7F569B2415B41F Message id: 0
Payload contents:
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):Processing IKE_SA_INIT message
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):Verify SA init message
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):Checking NAT discovery
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):NAT INSIDE found
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):NAT detected float to init port 4500, resp port 4500
*Jan 23 20:35:05.009: IKEv2:(SESSION ID = 1,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH secret key, DH Group 19
*Jan 23 20:35:05.033: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Request queued for computation of DH secret
*Jan 23 20:35:05.033: IKEv2:(SA ID = 1):[IKEv2 -> Crypto Engine] Calculate SKEYSEED and create rekeyed IKEv2 SA
*Jan 23 20:35:05.033: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] SKEYSEED calculation and creation of rekeyed IKEv2 SA PASSED
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Completed SA init exchange
*Jan 23 20:35:05.033: IKEv2:Config data to send:
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-request
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-dns, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-nbns, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv6-dns, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv6-subnet, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 242, data: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(1)T1, RELEASE SOFTWARE (fc2)
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: split-dns, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: banner, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: config-url, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: backup-gateway, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: def-domain, length: 0
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Have config mode data to send
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Generate my authentication data
*Jan 23 20:35:05.033: IKEv2:(SESSION ID = 1,SA ID = 1):Use preshared key for id 192.168.100.250, key len 14
*Jan 23 20:35:05.033: IKEv2:[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
*Jan 23 20:35:05.033: IKEv2:[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):Get my authentication method
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):My authentication method is 'PSK'
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):Generating IKE_AUTH message
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):Constructing IDi payload: '192.168.100.250' of type 'IPv4 address'
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):ESP Proposal: 1, SPI size: 4 (IPSec negotiation),
Num. transforms: 3
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):Building packet for encryption.
Payload contents:
*Jan 23 20:35:05.037: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:4500/From 192.168.100.250:4500/VRF i0:f0]
Initiator SPI : 2EC958A5979924EA - Responder SPI : FB7F569B2415B41F Message id: 1
Payload contents:
ENCR
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:4500/To 192.168.100.250:4500/VRF i0:f0]
Payload contents:
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Process auth response notify
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Searching policy based on peer's identity '192.168.100.222' of type 'IPv4 address'
*Jan 23 20:35:05.113: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.250
*Jan 23 20:35:05.113: IKEv2:Found Policy 'POC-POL-01'
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Verify peer's policy
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Peer's policy verified
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Get peer's authentication method
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Peer's authentication method is 'PSK'
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Get peer's preshared key for 192.168.100.222
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Verify peer's authentication data
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Use preshared key for id 192.168.100.222, key len 14
*Jan 23 20:35:05.113: IKEv2:[IKEv2 -> Crypto Engine] Generate IKEv2 authentication data
*Jan 23 20:35:05.113: IKEv2:[Crypto Engine -> IKEv2] IKEv2 authentication data generation PASSED
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Verification of peer's authenctication data PASSED
*Jan 23 20:35:05.113: IKEv2:(SESSION ID = 1,SA ID = 1):Check for EAP exchange
*Jan 23 20:35:05.113: IKEv2:Using mlist default and username FLEX-AUTH-POL-01 for group author request
*Jan 23 20:35:05.113: AAA/BIND(00000012): Bind i/f
*Jan 23 20:35:05.113: AAA/AUTHOR (0x12): Pick method list 'default'
*Jan 23 20:35:05.113: IKEv2:(SA ID = 1):[IKEv2 -> AAA] Authorisation request sent
*Jan 23 20:35:05.117: IKEv2:(SA ID = 1):[AAA -> IKEv2] Received AAA authorisation response
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Received valid config mode data
*Jan 23 20:35:05.117: IKEv2:Config data recieved:
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-reply
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.250.1 255.255.255.255
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.101.0 255.255.255.0
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.203.0 255.255.255.0
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.42.0 255.255.255.0
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 246, data: Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S3, RELEASE SOFTWARE (fc2)
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Set received config mode data
*Jan 23 20:35:05.117: IKEv2:(SESSION ID = 1,SA ID = 1):Processing IKE_AUTH message
*Jan 23 20:35:05.117: IKEv2:IPSec policy validate request sent for profile POC-IKEV2-PROFILE-01 with psh index 1.
*Jan 23 20:35:05.117: IKEv2:(SA ID = 1):[IPsec -> IKEv2] Callback received for the validate proposal - PASSED.
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):IKEV2 SA created; inserting SA into database. SA lifetime timer (86400 sec) started
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):Session with IKE ID PAIR (192.168.100.222, 192.168.100.250) is UP
*Jan 23 20:35:05.121: IKEv2:IKEv2 MIB tunnel started, tunnel index 1
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):Load IPSEC key material
*Jan 23 20:35:05.121: IKEv2:(SA ID = 1):[IKEv2 -> IPsec] Create IPsec SA into IPsec database
*Jan 23 20:35:05.121: IKEv2:(SA ID = 1):[IPsec -> IKEv2] Creation of IPsec SA into IPsec database PASSED
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-set
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.21.1 255.255.255.255
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 8, data: 192.168.121.0 255.255.255.0
*Jan 23 20:35:05.121: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: app-version, length: 242, data: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(1)T1, RELEASE SOFTWARE (fc2)
*Jan 23 20:35:05.121: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel23, changed state to up
*Jan 23 20:35:05.125: IKEv2:(SESSION ID = 1,SA ID = 1):Checking for duplicate IKEv2 SA
*Jan 23 20:35:05.125: IKEv2:(SESSION ID = 1,SA ID = 1):No duplicate IKEv2 SA found
*Jan 23 20:35:05.125: IKEv2:(SESSION ID = 1,SA ID = 1):Sending info exch config
*Jan 23 20:35:05.125: IKEv2:(SESSION ID = 1,SA ID = 1):Building packet for encryption.
Payload contents:
CFG
*Jan 23 20:35:05.125: IKEv2:(SESSION ID = 1,SA ID = 1):Checking if request will fit in peer window
*Jan 23 20:35:05.125: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:4500/From 192.168.100.250:4500/VRF i0:f0]
Initiator SPI : 2EC958A5979924EA - Responder SPI : FB7F569B2415B41F Message id: 2
Payload contents:
ENCR
*Jan 23 20:35:05.125: %FLEXVPN-6-FLEXVPN_CONNECTION_UP: FlexVPN(POC-FLEX-CLIENT-01) Client_public_addr = 192.168.100.250 Server_public_addr = 37.211.149.33
*Jan 23 20:35:05.153: IKEv2:(SESSION ID = 1,SA ID = 1):Received Packet [From 37.211.149.33:4500/To 192.168.100.250:4500/VRF i0:f0]
Payload contents:
CFG
*Jan 23 20:35:05.153: IKEv2:(SESSION ID = 1,SA ID = 1):Processing ACK to informational exchange
*Jan 23 20:35:05.153: IKEv2:Config data recieved:
*Jan 23 20:35:05.153: IKEv2:(SESSION ID = 1,SA ID = 1):Config-type: Config-ack
*Jan 23 20:35:05.153: IKEv2:(SESSION ID = 1,SA ID = 1):Attrib type: ipv4-subnet, length: 0
*Jan 23 20:35:05.153: IKEv2:(SESSION ID = 1,SA ID = 1):Set received config mode data
Ok, so does the hub now have the branch2 spoke routes? (I can see in the debugs the routes appear to be sent)
Can you now ping?
hi
still im unable to ping the hub to branch 2 to hub and hub to branch 2
but i can see the brach 2 routing table have hub route
but in the hub doesn't have the branch to route
branch 2 #ping 192.168.250.1
Success rate is 0 percent (0/5)
HUB
Remote subnets:
HO-FLXVPN#ping 192.168.21.1
Sending 5, 100-byte ICMP Echos to 192.168.21.1, timeout is 2 seconds:
Branch 2 #show crypto ikev2 sa detail
Life/Active Time: 86400/1167 sec
CE id: 2003, Session-id: 2
Local spi: 2EC958A5979924EA Remote spi: FB7F569B2415B41F
Remote subnets:
hi
route set interface
virtual-template 23
hub
Remote subnets:
now it's working
thanks you so much such for your valuable time
i'm really appreciate your help
thanks a lot
Good day
Yesterday i was changed the local IP and the branch 2 VPN was UP and when i came and checked today
branch 1 still up but branch 2 its down please see the debug
*Jan 24 10:50:29.712: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.251
*Jan 24 10:50:29.712: IKEv2:Found Policy 'POC-POL-01'
*Jan 24 10:50:29.712: IKEv2:SA is already in negotiation, hence not negotiating again
*Jan 24 10:50:30.548: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 24 10:50:30.548: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.251:500/VRF i0:f0]
Initiator SPI : 5F5F0F97996045F0 - Responder SPI : 0000000000000000 Message id: 0
Payload contents:
*Jan 24 10:50:35.536: IKEv2:(SESSION ID = 1,SA ID = 1):: Maximum number of retransmissions reached
*Jan 24 10:50:35.536: IKEv2:(SESSION ID = 1,SA ID = 1):Failed SA init exchange
*Jan 24 10:50:35.536: IKEv2:(SESSION ID = 1,SA ID = 1):Initial exchange failed: Initial exchange failed
*Jan 24 10:50:35.536: IKEv2:(SESSION ID = 1,SA ID = 1):Abort exchange
*Jan 24 10:50:35.536: IKEv2:(SESSION ID = 1,SA ID = 1):Deleting SA
*Jan 24 10:50:35.536: %FLEXVPN-6-FLEXVPN_CONNECTION_DOWN: FlexVPN(POC-FLEX-CLIENT-01) Client_public_addr = 192.168.100.251 Server_public_addr = 37.211.149.33
*Jan 24 10:50:45.535: Domain: query for xxxxxxxxxxx.dyndns.org type 1 to 216.146.36.36Reply received ok
*Jan 24 10:50:46.079: IKEv2:Searching Policy with fvrf 0, local address 192.168.100.251
*Jan 24 10:50:46.079: IKEv2:Found Policy 'POC-POL-01'
*Jan 24 10:50:46.083: IKEv2:(SESSION ID = 1,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH public key, DH Group 19
*Jan 24 10:50:46.083: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Jan 24 10:50:46.083: IKEv2:(SESSION ID = 1,SA ID = 1):Request queued for computation of DH key
*Jan 24 10:50:46.083: IKEv2:IKEv2 initiator - no config data to send in IKE_SA_INIT exch
*Jan 24 10:50:46.083: IKEv2:(SESSION ID = 1,SA ID = 1):Generating IKE_SA_INIT message
*Jan 24 10:50:46.083: IKEv2:(SESSION ID = 1,SA ID = 1):IKE Proposal: 1, SPI size: 0 (initial negotiation),
Num. transforms: 4
*Jan 24 10:50:46.083: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.251:500/VRF i0:f0]
Initiator SPI : 92B5064D643128E6 - Responder SPI : 0000000000000000 Message id: 0
Payload contents:
*Jan 24 10:50:46.083: IKEv2:(SESSION ID = 1,SA ID = 1):Insert SA
*Jan 24 10:50:48.075: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 24 10:50:48.075: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.251:500/VRF i0:f0]
Payload contents:
*Jan 24 10:50:51.971: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 24 10:50:51.971: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.251:500/VRF i0:f0]
Payload contents:
*Jan 24 10:50:59.591: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 24 10:50:59.591: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.251:500/VRF i0:f0]
Payload contents:
*Jan 24 10:51:14.227: IKEv2:(SESSION ID = 1,SA ID = 1):Retransmitting packet
*Jan 24 10:51:14.227: IKEv2:(SESSION ID = 1,SA ID = 1):Sending Packet [To 37.211.149.33:500/From 192.168.100.251:500/VRF i0:f0]
Payload contents:
1 192.168.100.251/500 37.211.149.33/500 none/none IN-NEG
Encr: Unknown - 0, PRF: Unknown - 0, Hash: None, DH Grp:0, Auth sign: Unknown - 0, Auth verify: Unknown - 0
Life/Active Time: 86400/0 sec
CE id: 0, Session-id: 0
Status Description: Initiator waiting for INIT response
Local spi: A7045B1350320EF9 Remote spi: 0000000000000000
Local id: 192.168.100.251
Remote id:
Local req msg id: 0 Remote req msg id: 0
Local next msg id: 1 Remote next msg id: 0
Local req queued: 0 Remote req queued: 0
Local window: 1 Remote window: 1
NAT-T is not detected
HO HUB there is no remote
Life/Active Time: 86400/8896 sec
CE id: 1013, Session-id: 11
Local spi: F99A87FC7A5E1858 Remote spi: 526757D69A6D6DBF
Local req msg id: 2 Remote req msg id: 5
Local next msg id: 2 Remote next msg id: 5
Local req queued: 2 Remote req queued: 5
Remote subnets:
Please see the attached hub, branch1 spoke and branch2 spoke. yes even i cant ping from the branch2 spoke to hub or hub to branch2 spoke and im useing both branch1 spoke and branch2 spoke singel fqdn XXXXX.dyndns.org and hud not have it . and its haveing port forwarding iplocal ip form the broadband router
