dynamic ip FlexVPN Hub-and- dynamic ip multi Spoke
katheer_4u
Good day
Hi Everyone,
I'm having some trouble with FlexVPN in a Hub & multi Spoke i have both site are dynamic ip. actually the VPN is up but when i trying to configure the 2nd spoke 1 st one getting down and when i restrat the 1st one its getting VPN up but 2nd one its getting down
if anyone can help me i really appreciated
HUB
HO-FLXVPN#show running-config
Building configuration...
Current configuration : 3455 bytes
! Last configuration change at 15:26:37 UTC Thu Jan 23 2020 by ciscouser
version 15.5
no platform punt-keepalive disable-kernel-core
hostname HO-FLXVPN
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authorization network default local
aaa session-id common
ip domain name mm.com
subscriber templating
license udi pid ISR4331/K9 sn FDO20432DC6
license boot level securityk9
redundancy
mode none
crypto ikev2 authorization policy POC-AUTH-POL-01
route set interface
route set access-list POC-ROUTE-ACL-01
crypto ikev2 authorization policy FLEX-AUTH-POL-01
route set interface
route set access-list FLEX-ROUTE-ACL-01
crypto ikev2 proposal POC-PROP-01
encryption aes-cbc-128
integrity sha256
group 19
crypto ikev2 policy POC-POL-01
match fvrf any
crypto ikev2 profile POC-IKEV2-PROFILE-01
match identity remote address 0.0.0.0
identity local address 192.168.100.222
authentication remote pre-share key 6 cisco123
authentication local pre-share key 6 cisco123
aaa authorization group psk list default FLEX-AUTH-POL-01
virtual-template 23
vlan internal allocation policy ascending
crypto ipsec transform-set POC-IPSEC-TS-01 esp-aes esp-md5-hmac
mode transport
crypto ipsec profile POC-IPSEC-PROF-01
set transform-set POC-IPSEC-TS-01
set ikev2-profile POC-IKEV2-PROFILE-01
interface GigabitEthernet0/0/0
ip address 192.168.100.222 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Virtual-Template23 type tunnel
ip unnumbered Vlan1
ip nhrp network-id 23
ip nhrp redirect
tunnel source GigabitEthernet0/0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile POC-IPSEC-PROF-01
interface Vlan1
ip address 192.168.250.1 255.255.255.0
ip nat inside
ip nat inside source list 20 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/1/0
ip route 0.0.0.0 0.0.0.0 192.168.100.1
ip route 192.168.42.0 255.255.255.0 192.168.250.2
ip route 192.168.101.0 255.255.255.0 192.168.250.2
ip route 192.168.203.0 255.255.255.0 192.168.250.2
ip ssh rsa keypair-name mm.com
ip access-list standard FLEX-ROUTE-ACL-01
permit 192.168.101.0 0.0.0.255
permit 192.168.203.0 0.0.0.255
permit 192.168.42.0 0.0.0.255
ip access-list standard POC-ROUTE-ACL-01
permit any
access-list 20 permit 192.168.250.0 0.0.0.255
access-list 21 permit 192.168.203.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 21 in
transport input all
end
Spoke
Branch#show running-config
Current configuration : 2825 bytes
version 15.3
hostname Branch
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip name-server 216.146.35.35
ip name-server 216.146.36.36
ip cef
no ipv6 cef
license udi pid C887VAM-K9 sn FCZ1950929W
route set interface
integrity sha256
group 19
match fvrf any
identity local address 192.168.100.250
virtual-template 23
crypto ikev2 client flexvpn POC-FLEX-CLIENT-01
peer 1 fqdn xxxxxxx.dyndns.org dynamic
client connect Tunnel23
controller VDSL 0
mode transport
interface Tunnel23
ip unnumbered Vlan1
ip nhrp redirect
tunnel source Vlan2
tunnel destination dynamic
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 2
no ip address
interface Vlan1
ip address 192.168.14.1 255.255.255.0
interface Vlan2
ip address 192.168.100.250 255.255.255.0
no ip http server
ip route 172.16.114.0 255.255.255.0 192.168.14.2
ip route 192.168.114.0 255.255.255.0 192.168.14.2
permit 192.168.114.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
scheduler allocate 20000 1000
end
Branch#show crypto ikev2 sa detailed
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 192.168.100.250/4500 89.211.152.117/4500 none/none READY
Encr: AES-CBC, keysize: 128, Hash: SHA256, DH Grp:19, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 86400/17018 sec
CE id: 2001, Session-id: 1
Status Description: Negotiation done
Local spi: 7435398A5B040F61 Remote spi: 9A900A01F9641E5B
Local id: 192.168.100.250
Remote id: 192.168.100.222
Local req msg id: 5 Remote req msg id: 6
Local next msg id: 5 Remote next msg id: 6
Local req queued: 5 Remote req queued: 6
Local window: 5 Remote window: 5
DPD configured for 0 seconds, retry 0
Fragmentation not configured.
Extended Authentication not configured.
NAT-T is detected inside
Cisco Trust Security SGT is disabled
Initiator of SA : Yes
Remote subnets:
192.168.250.1 255.255.255.255
16 Replies 16
If the hub and branch2 spoke cannot communicate with each other (which is what it looks like from your ikev2 debugs) then no tunnel will be established. You need to get them communicating with each other.
Are you pinging using the FQDN or are pinging using the IP address? If you are relying on DNS resolution, I suggest checking DNS is still working, clear the cache and get the 2 routers to communicate with each other....then hopefully the VPN should re-establish.
thanks so much and i found the debug on HUB and i changed the IP and so far its okay now
hub and both branches
HUB#
*Jan 24 13:28:43.565: %IP-4-DUPADDR: Duplicate address 192.168.100.222 on GigabitEthernet0/0/0, sourced by 005f.8612.bfc1
*Jan 24 13:29:13.566: %IP-4-DUPADDR: Duplicate address 192.168.100.222 on GigabitEthernet0/0/0, sourced by 005f.8612.bfc1
*Jan 24 13:29:43.567: %IP-4-DUPADDR: Duplicate address 192.168.100.222 on GigabitEthernet0/0/0, sourced by 005f.8612.bfc1
*Jan 24 13:30:13.567: %IP-4-DUPADDR: Duplicate address 192.168.100.222 on GigabitEthernet0/0/0, sourced by 005f.8612.bfc1
*Jan 24 13:30:43.568: %IP-4-DUPADDR: Duplicate address 192.168.100.222 on GigabitEthernet0/0/0, sourced by 005f.8612.bfc1
*Jan 24 13:31:13.569: %IP-4-DUPADDR: Duplicate address 192.168.100.222 on GigabitEthernet0/0/0, sourced by 005f.8612.bfc1
