FlexVPN and OSPF issue
wkamil123
I have an issue with OSPF rountig on routers configured in hub and spoke topology.
An issue is on a routes which OSPF do not advertise from hub to spokes.
Subnets created on a hub router are not seen on spokes but new added subnet on spoke is seen in hub routing table.
Adding ip ospf network brodcast command on a hub virtual-template interface causes OSPF adjacency to down.
By the way, EIGRP works fine.
Has anyone encountered this issue with OSPF.
Please, look short config below;
-----------------------HUB-------------------------------
crypto ikev2 authorization policy default
route set interface
crypto ikev2 proposal ikev2_prop
encryption aes-cbc-256
integrity sha512
group 16
crypto ikev2 policy ikev2_policy
proposal ikev2_prop
crypto ikev2 keyring Flex_key
peer Spokes
  address 192.168.50.197
  pre-shared-key local 12345
  pre-shared-key remote 12345
peer RTB
  address 192.168.50.199
crypto ikev2 profile Flex_IKEv2
match identity remote address 192.168.50.197 255.255.255.255
match identity remote address 192.168.50.199 255.255.255.255
authentication remote pre-share
authentication local pre-share
keyring local Flex_key
virtual-template 1
no crypto isakmp default policy
crypto ipsec transform-set ipsec_trans esp-aes 256 esp-sha512-hmac
mode tunnel
crypto ipsec profile default
set transform-set ipsec_trans
set ikev2-profile Flex_IKEv2
interface Loopback1
ip address 172.16.10.1 255.255.255.0
ip ospf 10 area 0
interface Loopback10
ip address 10.1.1.1 255.255.255.0
ip ospf 10 area 0
interface Loopback50
ip address 50.1.1.1 255.255.255.0
ip ospf 10 area 50
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/1
bandwidth 100000
ip address 192.168.50.198 255.255.255.0
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered Loopback1
ip mtu 1400
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/1
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile default
router ospf 10
redistribute connected subnets
network 10.1.1.0 0.0.0.255 area 0
sh cryp ike sa
IPv4 Crypto IKEv2  SA
Tunnel-id Local                 Remote                fvrf/ivrf            Status
1         192.168.50.198/500    192.168.50.197/500    none/none            READY
      Encr: AES-CBC, keysize: 256, Hash: SHA512, DH Grp:16, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 86400/77565 sec
2         192.168.50.198/500    192.168.50.199/500    none/none            READY
      Life/Active Time: 86400/77542 sec
IPv6 Crypto IKEv2  SA
sh ip rou
S*    0.0.0.0/0 [1/0] via 192.168.50.1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/24 is directly connected, Loopback10
L        10.1.1.1/32 is directly connected, Loopback10
      50.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        50.1.1.0/24 is directly connected, Loopback50
L        50.1.1.1/32 is directly connected, Loopback50
      100.0.0.0/32 is subnetted, 1 subnets
O IA     100.1.1.1 [110/2] via 172.16.10.254, 21:32:58, Virtual-Access1
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.10.0/24 is directly connected, Loopback1
L        172.16.10.1/32 is directly connected, Loopback1
      192.168.50.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.50.0/24 is directly connected, GigabitEthernet0/1
L        192.168.50.198/32 is directly connected, GigabitEthernet0/1
      200.1.1.0/32 is subnetted, 1 subnets
O IA     200.1.1.1 [110/2] via 172.16.10.253, 21:32:38, Virtual-Access2
      201.1.1.0/32 is subnetted, 1 subnets
O IA     201.1.1.1 [110/2] via 172.16.10.253, 21:32:38, Virtual-Access2
      220.1.1.0/32 is subnetted, 1 subnets
O IA     220.1.1.1 [110/2] via 172.16.10.253, 00:06:11, Virtual-Access2
---------------------------SPOKE---------------------------------------------
integrity sha512
group 16
proposal ikev2_prop
peer Spokes
match identity remote address 192.168.50.198 255.255.255.0
virtual-template 1
mode tunnel
interface Loopback200
ip address 200.1.1.1 255.255.255.0
ip ospf 10 area 200
interface Loopback201
ip address 201.1.1.1 255.255.255.0
ip ospf 10 area 201
interface Loopback220
ip address 220.1.1.1 255.255.255.0
ip ospf 10 area 220
interface Tunnel1
ip address 172.16.10.253 255.255.255.0
ip mtu 1400
tunnel destination 192.168.50.198
tunnel protection ipsec profile default shared
ip address 192.168.50.199 255.255.255.0
duplex auto
speed auto
router ospf 10
network 172.16.10.0 0.0.0.255 area 0
sh cryp ike sa
1         192.168.50.199/500    192.168.50.198/500    none/none            READY
      Life/Active Time: 86400/77852 sec
sh ip route
C        172.16.10.0/24 is directly connected, Tunnel1
L        172.16.10.253/32 is directly connected, Tunnel1
L        192.168.50.199/32 is directly connected, GigabitEthernet0/1
      200.1.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        200.1.1.0/24 is directly connected, Loopback200
L        200.1.1.1/32 is directly connected, Loopback200
      201.1.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        201.1.1.0/24 is directly connected, Loopback201
L        201.1.1.1/32 is directly connected, Loopback201
      220.1.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        220.1.1.0/24 is directly connected, Loopback220
L        220.1.1.1/32 is directly connected, Loopback220
sh ip ospf database ro  172.16.10.1
            OSPF Router with ID (200.1.1.1) (Process ID 10)
                Router Link States (Area 0)
  Adv Router is not-reachable in topology Base with MTID 0
  LS age: 336
  Options: (No TOS-capability, DC)
  LS Type: Router Links
  Link State ID: 172.16.10.1
  Advertising Router: 172.16.10.1
  LS Seq Number: 80000065
  Checksum: 0x4B6E
  Length: 60
  Area Border Router
  AS Boundary Router
  Number of Links: 3
    Link connected to: a Stub Network
     (Link ID) Network/subnet number: 10.1.1.1
     (Link Data) Network Mask: 255.255.255.255
      Number of MTID metrics: 0
       TOS 0 Metrics: 1
    Link connected to: another Router (point-to-point)
     (Link ID) Neighboring Router ID: 100.1.1.1
     (Link Data) Router Interface address: 0.0.0.18
       TOS 0 Metrics: 1
     (Link ID) Neighboring Router ID: 200.1.1.1
     (Link Data) Router Interface address: 0.0.0.17
       TOS 0 Metrics: 1
Kamil,
A tunnel interface in this deployment (and VT/VAs for that matter) is a point to point interface, there's really no good reason to keep anything other than /32 (I might not be aware of some intricacies in more complex deployment).
"set route interface" is your biggest friend ;-)
M.
10 Replies 10
Marcin Latosiewicz
I checked it out in the lab, at least the generic OSPF setup.
A few comments - do not "redistribute connected" not all of them - you can introduce recursive routing (i.e. introduce tunnel endpoint through the tunnel).
Spoke2#show ip ospf interface tu1
Tunnel1 is up, line protocol is up
  Internet Address 10.1.1.177/32, Area 0, Attached via Network Statement
  Process ID 65001, Router ID 192.168.102.1, Network Type POINT_TO_POINT, Cost: 1000
  Topology-MTID    Cost    Disabled    Shutdown      Topology Name
        0           1000      no          no            Base
  Transmit Delay is 1 sec, State POINT_TO_POINT
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:03
  Supports Link-local Signaling (LLS)
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 1/1, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 1, maximum is 1
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 172.25.1.1
  Suppress hello for 0 neighbor(s)
Spoke2#show ip route ospf
Gateway of last resort is 172.16.2.1 to network 0.0.0.0
      10.0.0.0/32 is subnetted, 3 subnets
O        10.1.1.176 [110/3000] via 10.1.1.1, 00:01:38, Tunnel1
O IA  192.168.0.0/24 [110/1010] via 10.1.1.1, 00:01:21, Tunnel1
Hub#sh run | s r o
router ospf 65001
network 192.168.0.0 0.0.0.255 area 10
then I added
route-map CONNECTED_TO_OSPF, permit, sequence 10
  Match clauses:
    interface Loopback999
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
Hub#sh run | s r o
router ospf 65001
redistribute connected subnets route-map CONNECTED_TO_OSPF
And checked on Spoke
Spoke1#show ip route ospf
Gateway of last resort is 172.16.1.1 to network 0.0.0.0
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
O        10.1.1.177/32 [110/3000] via 10.1.1.1, 00:05:06, Tunnel1
O E2     10.255.255.0/24 [110/20] via 10.1.1.1, 00:00:04, Tunnel1
O IA  192.168.0.0/24 [110/1010] via 10.1.1.1, 00:04:49, Tunnel1
Final note "shared" is not needed on point to point interfaces.
Hi Marcin,
Thanks for quick response.
Unfortunately this solution with a route-map did not work.
Please provide listing from command "sh ip ospf dat rou 10.1.1.1" on your Spoke.
I'm looking solution why Adv Router is not-reachable on spoke - 'Adv Router is not-reachable in topology Base with MTID 0'
Regards Kamil
Kamil,
That was not meant to be THE solution, it was a solution to the problem I listed above ;-)
The setup is gone, I had to move one to do some testing for document I'm writing, I'll try to restore it back, but can't promise the timeline.
M.
Spoke1#sh ip ospf database topology
            OSPF Router with ID (192.168.101.1) (Process ID 1)
                Base Topology (MTID 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
172.25.1.1      172.25.1.1      11          0x80000008 0x004B78 3
192.168.101.1   192.168.101.1   17          0x80000003 0x00C69D 2
192.168.102.1   192.168.102.1   19          0x80000003 0x0090D3 2
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
192.168.0.0     172.25.1.1      6           0x80000003 0x004A23 0
and
Spoke1#sh ip ospf database route 172.25.1.1
  Routing Bit Set on this LSA in topology Base with MTID 0
  LS age: 42
  Link State ID: 172.25.1.1
  Advertising Router: 172.25.1.1
  LS Seq Number: 80000008
  Checksum: 0x4B78
  Length: 60
  AS Boundary Router
  Number of Links: 3
       TOS 0 Metrics: 1
     (Link ID) Neighboring Router ID: 192.168.102.1
     (Link Data) Router Interface address: 0.0.0.27
       TOS 0 Metrics: 1000
     (Link ID) Neighboring Router ID: 192.168.101.1
     (Link Data) Router Interface address: 0.0.0.25
       TOS 0 Metrics: 1000
I'm looking further what is wrong.
Thank's for your help.
K.
One thing that I noticed is that you're using /24 assignment on your interfaces (tun and VT) since those are point to point, I'm relying on /32 addressing assigned from same pool.
I'm using /24 addressing because I have 14 sites (spokes) and two hub routers and I deceided to use one subnet for tunnel connection.
Kamil,
M.
Marcin, you are right, ospf works with a /32 addressing.
Hi Marcin, I have just run into the exact same issue. I was using a /27 mask and didn't receive the OSPF routes on my spoke router. Once I changed the interface mask to /32 on the hub and spoke tunnel interfaces it fixed the issue.
Do you know why the /32 mask resolves the issue?
