10-15-2025 08:55 PM
My FTD public facing interfaces are using "front door" VRF setups and I need to enable an interface for RA VPN. From what I have found the challenge is going to be leaking my internal routes to the "front door" VRF interface. I've seen examples using route-maps, dynamic routing protocols, redistribution etc.. so there seems to be several ways to accomplish this. Can anybody recommend a simple, straightforward option for doing this?
10-15-2025 11:15 PM
Check one of the examples (see if that meets your requirement ?)
https://docs.defenseorchestrator.com/cdfmc/t-ravpn-vr-config-example.html
10-15-2025 11:22 PM
@tato386 "You cannot use interfaces that belong to user-defined virtual routers in policy-based site-to-site or remote access VPNs."
10-16-2025 06:36 AM - edited 10-16-2025 06:37 AM
"supported only on..." is sometimes not the same as "won't work".
