GETVPN - problem
Hubert Wisniewski
Community Member
I'm trying to run GETVPN on small test network. I have three routers:
R1 - as KS
R3 & R4 as a members
R1 config:
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set GET esp-aes esp-sha-hmac
crypto ipsec profile GET
set transform-set GET
crypto gdoi group GET
identity number 1
server local
  rekey lifetime seconds 300
  rekey retransmit 10 number 2
rekey authentication mypubkey rsa R1.test.com
  rekey transport unicast
  sa ipsec 1
   profile GET
   match address ipv4 150
   replay counter window-size 64
  address ipv4 10.0.0.1
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex half
R3 config:
encr aes
hash md5
group 2
identity number 1
server address ipv4 10.0.0.1
crypto map GET 10 gdoi
set group GET
ip address 10.0.0.3 255.255.255.0
duplex half
crypto map GET
show commands:
R1#sh crypto gdoi
Group Information
    Group Name               : GET
    Group Identity           : 1
    Group Members            : 2
    IPSec SA Direction       : Both
    Active Group Server      : Local
    Group Rekey Lifetime     : 300 secs
    Group Rekey
        Remaining Lifetime   : 189 secs
    Rekey Retransmit Period  : 10 secs
    Rekey Retransmit Attempts: 2
    Group Retransmit
        Remaining Lifetime   : 0 secs
      IPSec SA Number        : 1
      IPSec SA Rekey Lifetime: 3600 secs
      Profile Name           : GET
      Replay method          : Count Based
      Replay Window Size     : 64
      SA Rekey
         Remaining Lifetime  : 1390 secs
      ACL Configured         : access-list 150
    Group Server list        : Local
and
R4#sh crypto gdoi
Group Information
    Group Name               : GET
    Group Identity           : 1
    Rekeys received          : 0
    ACL Received From KS     : gdoi_group_GET_temp_acl
    Active Group Server      : 10.0.0.1
    Group Server list        : 10.0.0.1
R4#
I got an error message:
*Apr 16 19:05:17.691: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet.
        (ip) vrf/dest_addr= /10.0.0.4, src_addr= 10.0.0.1, prot= 17
R4(config-if)#
Have you got any idea what is wrong ?
Hello Hubert,
The reason is the following.
Rekeys are sent via udp on port 848. Since they are encrypted by the KEK [ but not by the TEK ], the router can't decrypt when IPSEC is looking at them.
Your KS policy should in fact look like:
Access-list 150 deny udp any any eq 848
access-list 150 permit ip any any
Hubert Wisniewski
Community Member
I found the problem: access-list 150 permit any any
When I changed it to match only LAN networks behind routers it started to work fine.
Hello Hubert,
ok, now it's clear, thanks a lot
