GRE/Ipsec Problems
Josh Sprang
I am having problems spinning up a GRE/IPSEC tunnel to a remote site.  The WAN on the remote side DSL.  Connection is as follows:
local-------------------------------------------remote
6509<gre source>-----ASA--<ipsec source>-----------1841 <ipsec destination>--------3550-12g<gre destination>
I the IPsec tunnel is up fine between the 1841 and the ASA.  3550 tunnel source <loopback 1> can ping the interface vlan on the 6509 desitnation and reverse.  I have a /30 on the tunnel interfaces.  I cannot ping the two tunnel interfaces accross via the /30 the GRE.  show ip route and traces show them going into the tunnels.  Also I notices packets are not matched on the crypto ACL for GRE.  IP packets for ICMP are.  Both Tunnel interfaces are up/up connected.  I have kicked down the mtu on the tunnel to 1400 and mss to 1360 but no luck.  Any Ideas?  I am stumped..  See relevant config below:
3550:
interface Tunnel1
ip address 10.25.30.13 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1360
tunnel source Loopback1
tunnel destination 10.25.0.4
tunnel path-mtu-discovery
# ping 10.25.30.14
Sending 5, 100-byte ICMP Echos to 10.25.30.14, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Routing entry for 10.25.30.12/30
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via Tunnel1
      Route metric is 0, traffic share count is 1
interface Loopback1
ip address 10.25.117.18 255.255.255.255
end
SOUTHRTRB#show int tunnel 1
Tunnel1 is up, line protocol is up
1841:
crypto isakmp policy 10
encr *
authentication pre-share
group *
crypto isakmp key ..... address .....
crypto ipsec transform-set .... esp-... esp-...-hmac
crypto map vpn 10 ipsec-isakmp
set peer ....
set transform-set .....
match address 101
interface Dialer1
ip address negotiated
no ip unreachables
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication pap callin
ppp chap hostname
ppp chap password 7
ppp pap sent-username
crypto map vpn
access-list 101 permit ip host 10.25.117.18 host 10.25.0.4
access-list 101 permit gre host 10.25.117.18 host 10.25.0.4
Extended IP access list 101
    10 permit ip host 10.25.117.18 host 10.25.0.4 (913 matches)
    20 permit gre host 10.25.117.18 host 10.25.0.4
ASA:
access-list vpn extended permit ip host 10.25.0.4 host 10.25.117.18
nat (inside) 0 access-list vpn
access-list sou extended permit ip host 10.25.0.4 host 10.25.117.18
access-list sou extended permit gre host 10.25.0.4 host 10.25.117.18
access-list sou; 2 elements; name hash: 0x988a052a
access-list sou line 1 extended permit ip host 10.25.0.4 host 10.25.117.18 (hitcnt=14) 0xbfcfe00c
access-list sou line 2 extended permit gre host 10.25.0.4 host 10.25.117.18 (hitcnt=0) 0x7072016a
crypto isakmp policy 110
encryption
hash
group
lifetime 86400
crypto map AT 600 match address sou
crypto map AT 600 set peer
crypto map AT 600 set transform-set
6500:
interface Tunnel80
ip address 10.25.30.14 255.255.255.252
ip pim sparse-dense-mode
tunnel source 10.25.0.4
tunnel destination 10.25.117.18
Tunnel80 is up, line protocol is up
#ping 10.25.30.13
Sending 5, 100-byte ICMP Echos to 10.25.30.13, timeout is 2 seconds:
#show ip route 10.25.30.13
  Redistributing via bgp 65000
  Advertised by bgp 65000
  * directly connected, via Tunnel80
david.tran
Level 4
Level 4
Your setup look correct.  One thing I would do if you want to see GRE to match the ACL, yo need to do this:
most of the time, GRE and IPSec end-point are the same but your setup is little different.
On the ASA, add the following route:  route inside 10.25.30.14 255.255.255.255 next-hop-6509
On the ASA, add the following route:  route outside 10.23.30.13 255.255.255.255 internet-next-hop
On the Cisco 1841, add the following route:  ip route 10.25.30.13 255.255.255.255 next-hop-3550
On the Cisco 1841, add the following route:  ip route 10.23.30.14 255.255.255.255 internet-next-hop
Now for everything else, it does not know, it will use the default route.
This "should" work.
If you think about it, it makes sense.  Your ASA does not know about your tunnel80, on the 6509, In order for the GRE to be encrypted, it must know specific route.  The same goes for the Cisco 1841 as well.
Does that help you?
If I remember right, GRE is not supported on the Catalyst 3550. Also if it is possible to configure that, I wouldn't expect that it will work.
A supported way to configure that is to do both the GRE- and IPSec-encapsulation on the 1841.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Correct, GRE tunnel should be terminated on the 1841, not on the 3550.[ where it will be process switched on an untested command ]
