Have a problem with DMVPN configuration
tuannv17121
Hi all,
I have a problem with DMVPN, topology as below:
The purpose of this lab is make connection from LAN remote site 1(192.168.2.1) and remote site 2(192.168.3.1) to LAN central site (192.168.1.1)
I configured DMVPN Hub and Spokes at R1,R2,R3 respectively. All configuration seems correct. From R3 and R4 I can ping to LAN-R1(192.168.1.1) OK. But on R5 and R6 I can not ping to 192.168.1.1. Besides, on R1 I also could not ping to 192.168.2.1 amd 192.168.3.1.
I already configured EIGRP between R3 and R5, R4 and R6. Additionally, On R3 and R4 I also configured static (192.168.1.1) into EIGRP:
router eigrp 10
  redistribute static metric 100 1 244 1 1500
Does anyone know the way to work out this issue? Thank you so much!
Mark Malone
Hi really need the configs here to check the issue very difficult to make a call without them , could you post them since its just a lab
hi markmalone,
thank you for your cmt. The configuration I will post later because of inconvenience. But one thing I confused is: normally all Hub and Spoke configuration sample here only connect the LAN-attached to Spoke to LAN-attached to Hub. In my lab, I need to connect a LAN from other router behind the Spoke (ex- 192.168.2.1/24 and 192.168.3.1 on R5 and R6 respectively). What configuration is needed to overcome this. My solution is here and it doesnt work:
-configure eigrp between R3 with R3, R6 with R4
-redistribute static routing into eigrp on Spokes (on R3 and R4)
