Please check the URL for easy-vpn server configuration steps.
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/configuration-professional/112037-easyvpn-router-config-ccp-00.html
If you google Cisco vpn-client, you will find, it is downloadable from many sites.
thanks
