Help with ipsec parameters
captkloss
I have received ipsec parameters for phase 1/2 from a non-ASA customer:
Phase 1
authentication-method
pre-shared-keys
authentication-algorithm
sha-256 (384)
encryption-algorithm
aes-192-cbc (256)
dh-group
group2
lifetime-seconds
28800
Phase 2
sha-256
aes-192-cbc (256)
protocol
esp
lifetime-seconds
3600
perfect-forward-secrecy keys
none
Can you help with creating corresponding transform-set and crypto policy?
Thanks!
Hey,
If the other party say they are using IKEv1 that is not going to work since the ASA doesn´t support sha256 for IKEv1 policies, just IKEv2. The other party needs to verify this information in order to configure the right commands on the ASA, here is a link for reference: https://www.cisco.com/c/en/us/td/docs/security/asa/asa91/configuration/vpn/asa_91_vpn_config/vpn_ike.html#78391
Gio
GioGonza
Level 4
Level 4
Hello @captkloss
Before any suggestion is made, can you specify if this VPN tunnel is IKEv1 or IKEv2?.
Have a good one!
Gio
The other party claims they use ikev1 - however i cant see an option to match sha256 using ikev1.... so i'm bit confused...
Hey,
Gio
GioGonza
Level 4
Level 4
Hello @captkloss,
Have a good one!
Gio
