help with setting up VPN through 2 ASA 5510 Firewalls
inderpalsogi
'm trying to set up a vpn connection through two ASA 5510 firewalls.
My network is as follows:
PC | FW A | Internet |FW B| - lan |
I am trying to achieve the following:
PC | FW A | Internet |FW B| - | DMZ | - | FW C| - | lan |
However, I am not sure where the VPNs will need to terminate and how I will achieve this taking into account the WAN IPs.
I have attached a picture document which will give you more of an idea of what I am trying to achieve.
Any help will be more than appreciated.
andrew.prince
Level 10
Level 10
The below URL has everything you need
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html
