Help with VPN between ASA and cisco 877
whiteford
Hi, I am trying to move a Cisco 877 that is happily connected to a cisco concentrator over a DSL to our Cisco ASA.
I changed the 877's peer to the ASA and went through the ASA's VPN wizard in the ASDM and the tunnel didn't come up.
I take it the local network is my LAN IP range and the remote network is the LAN IP range of the 877?
The VPN info on the 877 is:
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key abcdefg address 1.2.3.4
crypto ipsec transform-set CBSO_T_Set esp-aes 256 esp-sha-hmac
crypto map CBSO_Crypto_Map 10 ipsec-isakmp
set peer 1.2.3.4
set transform-set CBSO_T_Set
match address 101
The local IP range of the 877 is 172.19.15.0/24
My IP range on the inside of the ASA is 192.168.80.0/24
The peer IP of the 877 is 4.3.2.1
What should I add to the ASA is CLI or ASDM based on the above?
ivillegas
Level 6
Level 6
Make sure that the security and other configuration parameters such as the lifetime matches on both the sides. Also ensure that interesting traffic is allowed properly using access list on both the sides. http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805e8c80.shtml
