High Availability hub to Spoke using GRE tunnels and IPSEC
ryan.schembri
Hi all, currently I am working on a network project using a highly available core (2xISR4451) using HSRP to 3 different spokes, having 3 GRE tunnels, and using IPSEC. I used this method previously for point-to-point networks and worked perfectly. however, this time since I added another 2 sites and at the core introduced HSRP I had to change the tunnel source from the interface number to the HSRP virtual IP address in order to get the status UP. Up till here worked perfectly however when I came to include the IPSEC and under the tunnel interface used: tunnel protection ipsec profile {profile name } shared an error occurred:
Error: Tunnel11 - shared tunnel protection is not supported when tunnel source is specified as an IP address. Configure "tunnel source <interface>" when using shared tunnel protection.
Do I need to create a profile for each tunnel in order not to use the shared key ?
Is there any workaround ??? because if change tunnel source address to the interface the tunnel will never terminate on the virtual IP for high availability
Below is the sample code:
[Router R1 Core]
crypto ikev2 proposal ikev2propsal
 encryption aes-cbc-256
 integrity sha256
 group 5
crypto ikev2 policy ikev2policy
 match fvrf any
crypto ikev2 keyring keys
 peer site_B
  address 20.100.255.4
  pre-shared-key cNETkey2023
crypto ikev2 profile ikev2profile
 match identity remote address 20.100.255.4 255.255.255.255
 authentication local pre-share
 authentication remote pre-share
 keyring local keys
crypto ikev2 dpd 10 2 on-demand
crypto isakmp keepalive 10
crypto ipsec transform-set myset esp-aes 256 esp-sha-hmac
 mode tunnel
crypto ipsec profile cnetprofile
 set transform-set myset
 set ikev2-profile ikev2profile
interface Tunnel11
 description VOIP_FW
 ip address 20.100.10.1 255.255.255.252
 ip mtu 1400
 ip tcp adjust-mss 1300
 tunnel source 20.100.255.1
 tunnel destination 20.100.255.4
 tunnel key 11
interface Tunnel12
 description dataB
 ip address 20.100.20.1 255.255.255.252
 ip mtu 1400
 tunnel key 12
interface GigabitEthernet0/0/1
 description UHF_LINK_FW
 ip address 20.100.255.2 255.255.255.248
 standby version 2
 standby 11 ip 20.100.255.1
 standby 11 timers msec 300 msec 900
 standby 11 priority 105
 standby 11 preempt
 standby 11 authentication md5 key-string 7 14343C2E38
 negotiation auto
[Spoke Router]
 integrity sha256
 group 5
 match fvrf any
 peer site_A
  address 20.100.255.1
 match identity remote address 20.100.255.1 255.255.255.255
 keyring local keys
 mode tunnel
interface Tunnel11
 description VOIP
 ip address 20.100.10.2 255.255.255.252
 ip mtu 1400
 tunnel source GigabitEthernet0/0/0
 tunnel destination 20.100.255.1
 tunnel key 11
interface Tunnel12
 description dataB
 ip address 20.100.20.2 255.255.255.252
 ip mtu 1400
 tunnel key 12
interface GigabitEthernet0/0/0
 ip address 20.100.255.4 255.255.255.248
 negotiation auto
Under the tunnel interface due to error I did not include tunnel protection in the above code.
below is the network diagram :
6 Replies 6
In hub and spoke I see only one tunnel why you need shared for ipsec profile???
sorry i was posting an abstract of the actual configuration as it is a bit long I added another tunnel. For each spoke I have 3 tunnels Data A, data B and Managment Data
It true shared keyword can use only if you use interface in tunnel source not IP'
will make lab check this issue
thanks
MHM
thanks a lot, if needed i can provide the whole config.
No need
MHM
Hello sir by any chance did you find any solution for the above issue ? meanwhile I did a small workaround by using the 2nd router rising floating static route from the spoke routers and to keep track of the main tunnel I am using IP SLA as these will be encrypted pings rather using GRE keepalives where the reply will unencrypted.
