How to load balance connecting users across 3 Anyconnect VPNs?
MicJameson1
Hello.
The enterprise has three Anyconnect RA VPNs. Users tend to all use the same connection profile Anyconnect1.mydomain.com
QUESTION: What is the solution so that technology load-balances the incoming connecting users across the three ASA 1120s that use an FTD image?
I researched below links. They did not provide solution (The OGS technology seems to only force users to the nearest ASA, not the intended least used.
AnyConnect Optimal Gateway Selection Troubleshoot Guide - Cisco
Cisco AnyConnect Mobile Platforms Administrator Guide, Release 4.1 (niap-ccevs.org)
Please help. Thank you.
@MicJameson1 using XML profiles to manually specify which primary FTD to connect to is the least best solution.
You create a VPN XML profile using the Secure Client (AnyConnect) VPN Profiler Editor and create 3 different configurations, using a different primary/backup server. The XML profile should be deployed to different groups of users (by AD group membership), the file is stored:- C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile. You can use Windows GPO to copy the XML profile to the computers to deploy the configuration settings.
I suggest you do not upload the XML profile to the headend (FTD/ASA) as well as manually deploying (as above). If you do, when the user connects to the FTD they will download the profile to the clients, which would overwrite their configuration.
5 Replies 5
@MicJameson1 if the 3 ASAs have layer 2 connectivity you can use the VPN Load Balancer functionality to load balanace the user sessions across the ASA or a third party load balancer, such as F5.
Alternatively you can configure the anyconnect XML profile with a primary ASA server and backup server(s), but that will only use the backup servers if the primary has failed.
Thank you for your reply.
Relevant is that we are soon migrating to use only FTD images on our ASAs. The otherwise great pasted link states....
"Load Balancing is currently only supported on ASA software, not FTD", --so this option does not seem to be available.
Also it states, "All devices must be on the same inside and outside IP network"-- Our ASAs each have unique public IP subnets.
So then, is there a solution to achieve the original intent?
Thank you.
@MicJameson1 FTD VPN Load Balancer has subsequently been introduced on newer FTD version (from 7.0) if using the FMC for management. https://integratingit.wordpress.com/2021/06/13/ftd-vpn-load-balancing/
Correct you need layer 2 connectivity for the FTD/ASAs to use VPN Load Balancer.
So you'd need to use a third party load balancer, or manual load balancing by deploying different XML profiles with different primary/backup FTD headends to different groups of users.
"So you'd need to use... manual load balancing by deploying different XML profiles with different primary/backup FTD headends to different groups of users" -- So the idea is to assign equal amounts of users to different XML profiles?
Do these XML profiles live in the OS of the end-user workstations?
How is this done at scale
