How to map SPAN and RSPAN destination to same interface
vasanth_acharya
How to resolve this issue,
First we have one switch <sw1> which is connected with server (voice packet capturing server) we are able to fetch voice packets.
Now we added  new switch <sw2> we configured remote span on that switch and sw1 is the destination  to fetch voice packet as per server located in SW1 but destination interface for both SW1 and SW2 are same so we are getting error.
Our requirement is how to capture both switches voice packet in server.
<SW1>  Configuration
Interface fastEthernet 1/0/21
Switchport access vlan 520
Switchport mode acess
Swithcport voice vlan 400
Monitor session 1 source vlan 400
Monitor session 1 destination interface fastethernet 1/0/9 - 10
In this Fas 1/0/9-10 connected server which is able to capture voice packet perfectly
Now we added one more switch
<SW2>  configuration
Vlan 430
Remote-span
Interface fastEthernet 1/0/22
Monitor session 2 source vlan 400
Monitor session 2 destination remote vlan 430
<SW1> configuration
Vlan 430
Remote-span
Monitor session 2 source remote vlan 430
Now is the issue
Monitor session 2 destination session interface fas1/0/9-10
When we mapping to destination interface in SW1 it is already mapped to SPAN so it is thronging out error.
%Interface(s) Fa1/0/9 – 10 already configured as destinations in other monitor session
Shelley Bhalla
Level 3
Level 3
You can have overlapping source  ports but no overlapping destination ports. This seems to be a  limitation and working as expected.
As per the cisco guide:
Destination Port
#Each local SPAN session or RSPAN destination session must have a destination port (also called a monitoring port)   that receives a copy of traffic from the source ports or VLANs and   sends the SPAN packets to the user, usually a network analyzer.
#A destination port has these characteristics:
#It   can participate in only one SPAN session at a time (a destination port   in one SPAN session cannot be a destination port for a second SPAN   session)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swspan.html#wp1036749
Hope it helps. Please rate and mark complete if there are no more questions.
Shelley Bhalla
Cisco TAC.
