How to separate WIFI and LAN with ASA 5505
alendpr.cisco
HI Guys,
We have CISCO ASA 5505 in our office , right now port 0 has configured for outside and port 1 for inside (I believe it is the default configurations) now for security reasone I want to separate the Network traffic from inside (office LAN) and WIFI , please correct me if I'm wrong but I believe since i have 6 ports in vlan1 (inside) if I make the port which has the connecting to our switch and the port which i m going to connect to my wireless router
(same vlan1)  protected / isolated then this should work ,  but here is what is happening , the minute I save the configurations port 3 which is supposed to be my wifi port will lose its connection to the Internet.
i tried to make another vlan for wifi to seprate the trafic from vlan1 , but I m not getting internet connection on that port which is been assigned to new vlan for wifi.
any idea where i am wrong ? would you guys please let me know what should i do for this scenario ?
Thanks a lot
5 Replies 5
Mariusz Bochen
Hi Alen,
If you're configuring a new VLAN on ASA you need to reconfigure NAT as well in order to get Internet access on wireless devices.
Also how the WIFi router is configured? Is it just a standard bridge mode? What about the DHCP?
If you post your config we can help you out.
Mariusz
Hi Thanks for the respond
Well I m new in CISCO so dont know how exactly I have to make NAT so it would be perfect if you let me know how can I do that , preferly via ASDM .
we have the basic license (two vlan "outside and inside" and DMZ) basically i m trying to configure the DMZ in order to connect my wireless router to it so our customers who are using the WIFI can not have any access to our LAN . I dont know if this is the best scenario (DMZ) please correct me if I can use easier way for this purpose .
at this point lets forget about the wifi router and DHCP , as long as I can configure the port so I can connect my laptop to it and get the Internet without access to my LAN it would be perfect so I can configure the wireless router later.
Right now I have created a vlan (DMZ) with security level 50 , I have restricted the access of this interface to vlan1 (inside LAN) , I assigned the IP address 192.168.1.0
But cant get internet when connect myself to it , what else I have to do ?
Thanks for your help in advance
If everything is setup as default this CLI command should help:
nat (DMZ) 1 0.0.0.0 0.0.0.0
If you don't want tu use CLI (which is highly recommended) you can do it from ASDM: Configuration > Firewall > NAT Rules > Add dynamic NAT, select your dmz VLAN, Source any, and select outside pool with number 1.
Good thing to do if you're new to Cisco is to change preferences Tools > Preferences > Tick Preview commands before sending them to the device. Helps alot with learning CLI commands
Hope this helps
Mariusz
HI
Sorry as I said i m not good in CLI yet , if I m suppose to enter nat (DMZ) 1 0.0.0.0 0.0.0.0 I need to know everything from the beginning to enter this command , anyway when I tried ASDM as you instructed first i got the error saying the outside pool 1 is already exists so i deleted all the NAT under the DMZ , and did select it again and below was the code sent to the firewall :
  no nat (DMZ) 1 192.168.1.0 255.255.255.0
  clear xlate interface DMZ local 192.168.1.0 netmask 255.255.255.0
Yet i have no chance
Maybe it is good if you let me know what should I do from the beginning by having this point in mind that whatever I do should not affect the inside network because it is the live router and all users are working .
Also please correct me if I’m wrong , isn't it suppose when we have two ports in the same vlan (inside) for example port 2 and port 3 , if we select them as protected / isolated ports then these ports should not pass any traffic to each other but pass the traffic to another vlan (outside) ? Why whenever I make the port 2 as protected which has the connation to our main switch still get the internet from port 0 (outside) but port 3 is not getting Internet?
Hi Alen,
Sorry for been quiet for few days.I am struggling with a giant cold...
We need to see the config in order to provide a good advice. Just login to CLI, type in 'show run' and post the config. Don't forget to hide all confidential info.
Mariusz
