I have problem with vpn client for widows 7 64 bits?
Mariela788
Hello I have a Windows 7 for 64 bits, but I cant´t install the version cisco vpn client 5.
What version is available?
Ivan Martinon
Level 7
Level 7
There is still no VPN Client from Cisco that is supported on 64Bit platforms, you would need to use the anyconnect client or use a 3rd party client that might be out there.
HI,
Agreeing with Ivan that Cisco has still not released a client for Windows 64 bit.
Although there are lot of freeware clients available to download such as Shrew, Safenet etc that support 64 bit OS
Pradhuman
Phillip Remaker
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to cvc-beta@cisco.com.
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
There are currently no plans to support Windows XP 64 bit in the VPN client.
