IKEv2 connections problems
jorgemfm
Frequent Visitor
Frequent Visitor
Note: I'm kind of new to cisco, and this configuration was not made by me.
We have a IKEv2 tunnel configured and I rebember that when I run
show crypto ikev2 sa
 it would only show 1 Tunnel with status READY
A few week ago I noticed that now it shows 2 tunnels, one with READY status a onother with IN-NEG status.
Router#show crypto ikev2 sa
 IPv4 Crypto IKEv2  SA
Tunnel-id Local                 Remote                fvrf/ivrf            Status
2         x.x.x.x/500          x.x.x.x/500    none/none            IN-NEG
      Encr: 3DES, Hash: SHA96, DH Grp:2, Auth sign: Unknown - 0, Auth verify: Unknown - 0
      Life/Active Time: 120/0 sec
1         x.x.x.x/500          x.x.x.x/500    none/none            READY
      Encr: 3DES, Hash: SHA96, DH Grp:2, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 86400/693 sec
 IPv6 Crypto IKEv2  SA
I didn't make any change, I don't know if the other part has made any, buy is there any way I can understand what is wrong?
Also, we started having problems with the connection, from time to time users where unable to acess the remote network and I have to run clear comand so that thay can again connect.
clear crypto ikev2 sa
Any ideas on how I can start investigating this?
Thank you!
20 Replies 20
IPSec have two phase and two lifetime,
in your case the lifetime is mismatch with other Peer,
if you see the lifetime is different between the two entry.
so make sure that other peer use same lifetime 86400 instead of 120.
Mike.Cifelli
AFAIK ikev2 lifetime is not negotiated and is locally significant to each respective peer in regard to ios.  The ikev2 lifetime is not negotiated in the ikev2 proposals, and configured in ikev2 profiles in respect to ios.  Whichever peer has the lower lifetime will always end up being the one to request rekeying via CREATE_CHILD_SA.  What types are the connecting devices? Have you attempted any debugs? If so, are you able to see any specifics such as negotiation failing? IKE_AUTH failures, etc.?
jorgemfm
Frequent Visitor
Frequent Visitor
Hi, sorry for the late answer.
Our device is a  cisco C891F router, I dont know the other end device.
No, like I said, i'm kind of new to cisco, trying to learn. Will search online for information about debugging
Thank you
I would start with #debug crypto ikev2 packet.  This should help shed some light on why negotiations are failing.  Let us know what errors you see.  Any chance you can share the ikev2 local/remote side config?  Lastly, an easy checkbox should be reaching out to remote side to see if they made any changes as well.
Phase 1 lifetime is 120 in other Peer
phase 1 lifetime is 86400 in your side,
phase 1 in other side timeout and try to establish new Phase1 BUT your side still have active phase1 this make
other peer failed to phase1 and your side the tunnel can not send traffic, NOW
only config your side phase1 lifetime =120 and see if the traffic is stable BUT BUT 120 is to short.
jorgemfm
Frequent Visitor
Frequent Visitor
Sorry for late reply.
I think the problem was on their side, basically they used the same network for 2 different tunnels so there was some conflits.
They made the change today so i'm going to wait a few more days to be sure. If it continues I will leave here the requested information.
Thank you all.
until that
Good luck friend.
Sheraz.Salim
once you learn the vpn side as you need in this. please upgrade your vpn encryption setting. by looking into the displayed output you using a legacy (which is not recommanded setting anymore at this living time) for example 3DES encryption  must not be used in production network plust you using DH group 2 again not recommand one.
ideally, Encrytion should be AES-256 and DH group 19,20,21
have a look on Here and upgrade the encryption (once agreed with you and the remote side).
please do not forget to rate.
jorgemfm
Frequent Visitor
Frequent Visitor
Hi, Sorry Again for the late answer
The problem still persists and now its worst than ever.
Tomorrow I will have a meeting with a cisco technician and the team from the other side of the tunnel to see if we can fix the problem
Still, I did some checking and when executing
debug crypto ikev2 error
I get the following
Apr 28 19:56:20.370: IKEv2:: Packet is a retransmission
Apr 28 19:56:29.382: IKEv2:(SESSION ID = 189,SA ID = 2):: Failed to receive the AUTH msg before the timer expired
Apr 28 19:56:29.382: IKEv2:(SESSION ID = 189,SA ID = 2):: Auth exchange failed
Apr 28 19:56:29.430: IKEv2:Failed to retrieve Certificate Issuer list
Apr 28 19:56:29.434: IKEv2:Failed to retrieve Certificate Issuer list
Apr 28 19:56:32.430: IKEv2:: Packet is a retransmission
Apr 28 19:56:38.426: IKEv2:: Packet is a retransmission
Apr 28 19:56:50.426: IKEv2:: Packet is a retransmission
Apr 28 19:56:59.434: IKEv2:(SESSION ID = 190,SA ID = 2):: Failed to receive the AUTH msg before the timer expired
Apr 28 19:56:59.434: IKEv2:(SESSION ID = 190,SA ID = 2):: Auth exchange failed
Apr 28 19:56:59.482: IKEv2:Failed to retrieve Certificate Issuer list
Apr 28 19:56:59.486: IKEv2:Failed to retrieve Certificate Issuer list
Apr 28 19:57:02.482: IKEv2:: Packet is a retransmission
Apr 28 19:57:08.482: IKEv2:: Packet is a retransmission
Apr 28 19:57:20.478: IKEv2:: Packet is a retransmission
Apr 28 19:57:29.486: IKEv2:(SESSION ID = 191,SA ID = 2):: Failed to receive the AUTH msg before the timer expired
Apr 28 19:57:29.486: IKEv2:(SESSION ID = 191,SA ID = 2):: Auth exchange failed
Don't know if its related to the problem, didn't find much online about this.
I will keep updating as the situation evolves.
Thank you all!
DO you change the lifetime ?? I think NO and as I mention before lifetime is issue but....ANYWAY
also what auth you use ??
PSK or RSA ???
I think the Policy is make issue here,
when your side try initiate the IPSec it select right the Auth BUT when other side initiate the IPSec the issue arise IKEv2 don't know select RSA or PSK.
how many tunnel run in this router ?
jorgemfm
Frequent Visitor
Frequent Visitor
Hi, sorry for not letting you know about the lifetime.
I'va tried to change the lifetime to 120, but the results where the same, and the thing is, I can't even find anywhere on the configuration the 86400 value on the lifetime (maybe it's default?). Also I don't know if I changed on the right place, like I said on the first post, i'me not very familiar with cisco.
This is the place I can find a lifetime configuration, and it was always 28800, i've tried change to 120 like I said, but got same results
Router#show crypto isakmp policy
Global IKE policy
Protection suite of priority 10
        encryption algorithm:   AES - Advanced Encryption Standard (256 bit keys).
        hash algorithm:         Secure Hash Standard
        authentication method:  Pre-Shared Key
        Diffie-Hellman group:   #2 (1024 bit)
        lifetime:               28800 seconds, no volume limit
Don't know if this information helps with the other questions.
Also, showing here the tunnels with detailed information. Like I said before, there's only suposed to be 1 tunnel, and looking at this info, we can see the second tunnel is in IN-NEG state an as the  Local id: and Remote id: fields empty.
Router#show crypto ikev2 sa detailed
1         yyy.yyy.yyy.yyy/500          xxx.xxx.xxx.xxx/500    none/none            READY
      Life/Active Time: 86400/518 sec
      CE id: 2352, Session-id: 12
      Status Description: Negotiation done
      Local spi: 25CE263C93D957DA       Remote spi: D83ACA7E3D462DBD
      Local id: yyy.yyy.yyy.yyy
      Remote id: xxx.xxx.xxx.xxx
      Local req msg id:  0              Remote req msg id:  30
      Local next msg id: 0              Remote next msg id: 30
      Local req queued:  0              Remote req queued:  30
      Local window:      5              Remote window:      1
      DPD configured for 0 seconds, retry 0
      Fragmentation not configured.
      Extended Authentication not configured.
      NAT-T is not detected
      Cisco Trust Security SGT is disabled
      Initiator of SA : No
2         yyy.yyy.yyy.yyy/500          xxx.xxx.xxx.xxx/500    none/none            IN-NEG
      CE id: 2370, Session-id: 0
      Status Description: Responder waiting for AUTH message
      Local spi: 770C8AAA0B6F69B2       Remote spi: 24333416BB94EB23
      Local id:
      Remote id:
      Local req msg id:  0              Remote req msg id:  1
      Local next msg id: 0              Remote next msg id: 1
      Local req queued:  0              Remote req queued:  1
      Local window:      1              Remote window:      1
Thanks again!
jorgemfm
Frequent Visitor
Frequent Visitor
Hi, sorry for not talking about the lifetime thing, I've tried changing it, but the results where the same. And the thing is, I can't find anywhere on the configuration the 86400 value (may its default?) and I really don't know if I changed on the right place, like I said, i'm not very familiar with cisco and ipsec.
This is the only place I found a lifetime configuration, I changed to 120, but like I said, the results where the same. still, the value was always 28800
Global IKE policy
Don't know if this info answers yous other questions
Chacking again the tunnels, this time with detailed. Like I said before, theres only suposed to be 1 tunnels, and as you can see, teh second one is always in IN-NEG status and the  fields Local id and Remote id are empty.
      Life/Active Time: 86400/1816 sec
      Local req msg id:  0              Remote req msg id:  95
      Local next msg id: 0              Remote next msg id: 95
      Local req queued:  0              Remote req queued:  95
      CE id: 2413, Session-id: 0
      Local spi: 8F324FE43C437E38       Remote spi: 7334FC00D809E779
      Local id:
      Remote id:
Thanks again!
Hmm I don't anymore think that this is lifetime issue..
this issue with ID
run
deb crypto ikev2 packet
share output and then NO debug for CPU.
jorgemfm
Frequent Visitor
Frequent Visitor
is this enough?
Apr 28 22:26:16.198: IKEv2:Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: INITIATOR Message id: 0, length: 252
Payload contents:
 SA  Next payload: KE, reserved: 0x0, length: 44
  last proposal: 0x0, reserved: 0x0, length: 40
  Proposal: 1, Protocol id: IKE, SPI size: 0, #trans: 4    last transform: 0x3, reserved: 0x0: length: 8
    type: 1, reserved: 0x0, id: 3DES
    type: 2, reserved: 0x0, id: SHA1
    type: 3, reserved: 0x0, id: SHA96
    last transform: 0x0, reserved: 0x0: length: 8
    type: 4, reserved: 0x0, id: DH_GROUP_1024_MODP/Group 2
 KE  Next payload: N, reserved: 0x0, length: 136
    DH group: 2, Reserved: 0x0
 N  Next payload: NOTIFY, reserved: 0x0, length: 36
 NOTIFY(Unknown - 16430)  Next payload: NONE, reserved: 0x0, length: 8
    Security protocol id: Unknown - 0, spi size: 0, type: Unknown - 0
Apr 28 22:26:16.202: IKEv2:(SESSION ID = 494,SA ID = 2):Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: RESPONDER MSG-RESPONSE Message id: 0, length: 276
Payload contents:
 N  Next payload: VID, reserved: 0x0, length: 24
 VID  Next payload: VID, reserved: 0x0, length: 23
 VID  Next payload: NONE, reserved: 0x0, length: 21
Apr 28 22:26:19.198: IKEv2:(SESSION ID = 494,SA ID = 2):Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: RESPONDER MSG-RESPONSE Message id: 0, length: 276
Payload contents:
Apr 28 22:26:25.194: IKEv2:(SESSION ID = 494,SA ID = 2):Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: RESPONDER MSG-RESPONSE Message id: 0, length: 276
Payload contents:
Apr 28 22:26:28.458: IKEv2:(SESSION ID = 351,SA ID = 1):Next payload: ENCR, version: 2.0 Exchange type: INFORMATIONAL, flags: INITIATOR Message id: 217, length: 60
Payload contents:
Apr 28 22:26:28.458: IKEv2:(SESSION ID = 351,SA ID = 1):Next payload: ENCR, version: 2.0 Exchange type: INFORMATIONAL, flags: RESPONDER MSG-RESPONSE Message id: 217, length: 60
Payload contents:
 ENCR  Next payload: NONE, reserved: 0x0, length: 32
Apr 28 22:26:37.194: IKEv2:(SESSION ID = 494,SA ID = 2):Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: RESPONDER MSG-RESPONSE Message id: 0, length: 276
Payload contents:
Apr 28 22:26:46.254: IKEv2:Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: INITIATOR Message id: 0, length: 252
Payload contents:
Apr 28 22:26:46.258: IKEv2:(SESSION ID = 495,SA ID = 2):Next payload: SA, version: 2.0 Exchange type: IKE_SA_INIT, flags: RESPONDER MSG-RESPONSE Message id: 0, length: 276
Payload contents:
