IKEv2 connections problems
jorgemfm
Note: I'm kind of new to cisco, and this configuration was not made by me.
We have a IKEv2 tunnel configured and I rebember that when I run
show crypto ikev2 sa
 it would only show 1 Tunnel with status READY
A few week ago I noticed that now it shows 2 tunnels, one with READY status a onother with IN-NEG status.
Router#show crypto ikev2 sa
 IPv4 Crypto IKEv2  SA
Tunnel-id Local                 Remote                fvrf/ivrf            Status
2         x.x.x.x/500          x.x.x.x/500    none/none            IN-NEG
      Encr: 3DES, Hash: SHA96, DH Grp:2, Auth sign: Unknown - 0, Auth verify: Unknown - 0
      Life/Active Time: 120/0 sec
1         x.x.x.x/500          x.x.x.x/500    none/none            READY
      Encr: 3DES, Hash: SHA96, DH Grp:2, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 86400/693 sec
 IPv6 Crypto IKEv2  SA
I didn't make any change, I don't know if the other part has made any, buy is there any way I can understand what is wrong?
Also, we started having problems with the connection, from time to time users where unable to acess the remote network and I have to run clear comand so that thay can again connect.
clear crypto ikev2 sa
Any ideas on how I can start investigating this?
Thank you!
20 Replies 20
Yes that enough,
try
1-make PSK same for local and remote
2-check the remote ID and local ID if there are any NAT between two router and you use mapped not real IP.
I have the same situation
in the profile  Lifetime is set to 86400
and on cryptomap also 86400
Local 10.10.10.10 - cisco 2911
Remote 20.20.20.20 - ASA
3         10.10.10.10/500      20.20.20.20/500    none/none            IN-NEG
      Encr: AES-CBC, keysize: 256, PRF: SHA512, Hash: SHA512, DH Grp:14, Auth sign: Unknown - 0, Auth verify: Unknown - 0
IKEv2 profile: PROFILE_CBT
 Ref Count: 2
 Match criteria:
  Fvrf: global
  Local address/interface: none
  Identities:
   address 20.20.20.20 255.255.255.255
  Certificate maps: none
 Local identity: none
 Remote identity: none
 Local authentication method: pre-share
 Remote authentication method(s): pre-share
 EAP options: none
 Keyring: CBT
 Trustpoint(s): none
 Lifetime: 86400 seconds
 DPD: disabled
 NAT-keepalive: disabled
 Ivrf: none
 Virtual-template: none
 mode auto: none
 AAA AnyConnect EAP authentication mlist: none
 AAA EAP authentication mlist: none
 AAA Accounting: none
 AAA group authorization: none
 AAA user authorization: none
crypto map IPSECMAP 100 ipsec-isakmp
 set peer 20.20.20.20
 set security-association lifetime seconds 86400
 set transform-set CBT
 set pfs group14
 set ikev2-profile CBT
 match address VPN_CBT
jorgemfm
Hi Again
Thank all for all the replies.
Everything is currently working now, but I really can't tell you what cause the problem...we made some changes, that didnt work, than later on it just randomly started working.
After it was working on our local network, users from VPN access where not able to access the tunnel, then later like magic it just started to work...
We have change also our ISP router, I don't know if that helped or not, but we where on this several days trying diferent configs and doing debug to a point that I really don't know what happened.
If any one whants to look at some configuration parameter please just ask.
Thank you
Sure I need to see last config if you can share,
also the show crypto ipsec sa and show crypto isakmp sa.
tommar
its very often the transport network thats different to and from the remote endpoint, thats causing delays and can be dropped for any reason on the remote carriers network between your endpoints. no debugs will tell you this.
