Inside Interface IP Phase 3 DROP Implicit Rule
stownsend
Level 2
Level 2
I'm trying to Save my Configs to TFTP Server that is on the other side of a VPN Tunnel.
Packet Tracer from a LAN Device IP gets thought Fine. Though from the IP of the Inside Interface it gets Dropped.   I have the same-security-traffic commands in the Config, though that does not seem to be helping.   What else can I look for?  This ASA was a config from a 5505 8.3 upgraded to a 5506 9.1
These are in my Config:
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
This is the Result of the packet-Tracer
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Additional Information:
 Forward Flow based lookup yields rule:
 in  id=0x7f11c5bbc320, priority=500, domain=permit, deny=true
        hits=2, user_data=0x7, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=10.4.0.2, mask=255.255.255.255, port=0, tag=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0
        input_ifc=inside, output_ifc=any
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
7 Replies 7
pjain2
packet tracer with the source ip as the ASA's inside interface ip will show drop and is expected.
however, to test the traffic across the vpn, you can directly do a ping sourcing from the inside interface:
ping inside <destination ip>
please make sure that you have management-access enable don the inside interface
At remote site B (IOS 8.3(2)) I can Issue:
packet-tracer in out tcp 10.11.0.1  2340 10.1.1.160 80 detail
Where 10.11.0.1 is the Inside Interface of the ASA and 10.1.1.160 is a Webserver across the VPN.
I get back up to Phase 8 and its allowed.
I do the same thing from the new remote site IOS 9.1(5) and I get the DROP at phase 3.
The main reason I'm looking to do this is that I need to have the ASA Access the TFTP server to Save its configs. The 'write net' command is timing out.   I can hit the TFTP server from other devices on the remote LAN, so its not a VPN  connectivity issue.
I also have 'management-access inside' in the config.
I also have 'telnet NETWORK-HBG 255.255.255.0 inside' where NETWORK-HBG is the Management network on the other end of the VPN and I cannot Telnet to the ASA. This is also working at the other remote sites running 8.3.2.
Thanks!
please try with the source interface as inside and try the packet tracer again
On the Remote B ASA 8.3(2)
   packet-tracer in out tcp 10.11.0.1  80 10.1.1.160 80 de
I get though no issues, I can hit the TFTP server and Telnet from a 10.1.x.x to the 10.11.0.1
  packet-tracer in in tcp 10.11.0.1  80 10.1.1.160 80 de
This Dies at Phase 2
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
 in  id=0xc9d73308, priority=500, domain=permit, deny=true
    hits=1, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
    src ip/id=10.11.0.1, mask=255.255.255.255, port=0
    dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
On Remote A 9.1(5)
   packet-tracer in out tcp 10.4.0.1  80 10.1.1.160 80 de
Dies at Phase 3
  packet-tracer in in tcp 10.4.0.1  80 10.1.1.160 80 de
Whoa! It works now?
Though Remote A site I still Cannot Telnet to and I cannot Save the TFTP Config
This works on Remote B
tftp-server inside 10.1.0.12 olivetasa.2015.0910.01.cfg
This does not work on Remote A
tftp-server inside 10.1.0.12 irvineasa.2015.0910.01.cfg
please send the output of show run sysopt from site A
Thank you for your Reply,
Site A
sysopt noproxyarp outside
sysopt noproxyarp inside
Site B
(nothing)
What is the Command to show the Running 'Default' Commands?
instead of the inside interface ip address, can you do the following:
packet inp inside tcp 10.11.0.2  1234 10.1.1.160 80 det
the packet-tracer output from out to in will drop if you do not have that traffic permitted in the outside interface access-list; but when the actual traffic comes through vpn into the ASA, sicne we have sysopt connection permit-vpn configured, the ASA's outside interface access-list is bypassed.
so if you just want to check the packet-tracer output, please allow the traffic explicitly for testing on the outside interface access-list
to see the default running config commands:
eg. sh run all crypto
show run all ssl
