12-17-2020 02:34 PM
Dears sir
kindly ,we have issue strange in dmvpn with ISR4321/K9 describes as below software version
spoke (ISR4321/K9)
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
GPL code under the terms of GPL Version 2.0. For more details,
i need to activate DMVPN phase 3 after configure ip nhrp shortcut in spoke router under tunnel it accept it but when we do
sh run int tunnel x we missing command & when send direct spoke -spoke traffic after enable summarization in hub under eigrp
we missing also nhrp route in spoke indicate dmvpn phase 3 working
note :
ip nhrp redirect is exist in show interface tunnnel x in hub router & by the way we use following ASR
hub router (ASR1001-X )
ASR-MOI-HQ1#sh version | in Version
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
GPL code under the terms of GPL Version 2.0. For more details, see the
Solved! Go to Solution.
12-20-2020 02:37 PM
12-20-2020 02:43 PM
12-20-2020 03:20 PM
Your spoke routers only have static routes to the hub router's outside interface, not the other spoke router. The only default route they have is learnt over the DMVPN tunnel, so that won't work.
Define static routes to the other spoke router's outside interface or better still use VRF on the outside interface. Example here.
12-20-2020 08:14 AM - edited 12-20-2020 08:50 AM
here
green orange can summary to 10.0.0./16 "or high superNet"
each spoke tunnel destination must reachable from other spoke, can do that by
ip route 0.0.0.0 0.0.0.0 ISPinterface
that it check this.
12-20-2020 04:23 PM
dear MHM
Kindly, Iam not tested yet but logically you are right NBMA is the address that must reach from every one
only path for NBMA between spokes is default provided by DMVPN tunnel
you are smart person ..
12-20-2020 04:39 PM
Thanks for your words friend
and your are so so welcome
03-18-2023 05:02 AM
@saif What was the reason the ip nhrp shortcut was not visible in running config? I am experiencing the same problem, but I am using different routing protocols for underlay and overlay. The NBMA addresses are pingable but I still cannot see ip nhrp shortcut in the running config of spokes.
