IPSec access over PIX inside interface
zroth
Level 3
Level 3
Hi all,
I need advice with the following problem.
I have PIX 515E with 3 interfaces inside,
DMZ and outside,vers 6.3(3).Is it possible to access DMZ over inside interface with IPSec from CISCO VPN client ? IPSec makes a tunnel,the client
has a new address from address pool,but
in the log I have a message : No translation found etc.. when I try to
reach any device in DMZ.The reason seems
to be with nat (dmz) 0 which should be from DMZ to inside (secu 50 to secu 0).Even if I use nat (dmz) 0 access-list remote outside it does not work.Any hints ?
Zdenek
konopkp77
Community Member
More details, network address and the full log line you should give. It looks that you are trying to access dmz using your Lan setings (inside) without vpn.
