IPSEC VPN help !!!
bsn1980in
Level 2
Level 2
Hi All
I have ASA 5520 and want to enable IPSEC VPN and want to access it through cisco VPN client.
I have done natting on router which is connected on outside interface of the ASA. I have done a static nat of private IP address of outside i/f of ASA to the public IP, on router. I am able to ping that public IP from internet and also able to access firewall thru ASDM using that public IP.
I have done the configuration using VPN wizard but some how not able to connect thru VPN client. Please guide, if I have missed something.
Configuration of ASA is attached.
bsn
try to do this
conf t
no crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
no crypto map WAN_map interface WAN
crypto map WAN_map interface WAN <- just to be sure that all the changes were applyed
and show
debug crypto isa 10
debug crypto ipsec 10
15 Replies 15
a.alekseev
Level 11
Level 11
no access-list LAN extended permit ip 10.0.0.0 255.0.0.0 any
no access-group LAN in interface LAN
no access-list WAN extended permit ip any 10.0.0.0 255.0.0.0
no access-group WAN in interface WAN
ip local pool VPN-Pool 10.0.5.1-10.0.5.255 mask 255.255.255.0
access-list LAN_nat0_outbound extended permit ip any 10.0.5.0 255.255.255.0
nat (LAN) 0 access-list LAN_nat0_outbound
no access-list cisco_splitTunnelAcl standard permit any
access-list cisco_splitTunnelAcl standard permit 10.0.0.0 255.0.0.0
route WAN 10.0.5.0 255.255.255.0 10.0.0.25 1
route WAN 0.0.0.0 0.0.0.0 10.0.0.25 1
route LAN 10.0.0.0 255.0.0.0 10.0.0.1 1
sysopt connection permit-vpn
If I will remove access-list LAN and WAN, then I will loose my connectivity to internet from inside network.
Rest I have configured but no luck.
bsn
Could you explain how did you check the vpn?
I have Cisco VPN client software Ver 4.0.01 installed on one of my machine in remote office.
I tried to access the public IP (natted to ASA outside private IP) with following settings:
group user: cisco
password: cisco
Transport: IPSEC over UDP ( I have tried IPSEC over TCP 10000 as well)
Thats all
BSN
ok... then add following
crypto isakmp ipsec-over-tcp port 10000
group-policy cisco attributes
ipsec-udp enable
I have added this:
and rest were already there in configuration.
Still not able to connect. Can you suggest some debugs.
Regards/bsn
debug crypto isakmp 10
conf t
logg mon 7
Debug is attached. I have replaced the Source Public IP. In the debug output, I can see there are no hits on group policy cisco. It is hitting default policy. please suggest.
Regards/bsn
tunnel-group cisco general-attributes
authentication-server-group LOCAL
I tried but the command is not executing.
ASA(config)# tunnel-group cisco general-attributes
ASA(config-tunnel-general)# authentication-server-group LOCAL
ASA(config-tunnel-general)# exi
ASA(config)# sh run | be tunnel-group cisco general-attributes
address-pool VPN-Pool
default-group-policy cisco
tunnel-group cisco ipsec-attributes
pre-shared-key *
regards/bsn
could you show the running configuration?
Show run is attached.
Recent change I have done is md5. Earlier it was SHA:
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5 >>>>>>>>>>>>> It was sha earlier.
group 2
lifetime 86400
In the debug I am getting below error messages:
Jul 02 14:26:12 [IKEv1]: Group = cisco, IP = , Duplicate Phase 1 packet detected. Retransmitting last packet.
Jul 02 14:26:12 [IKEv1]: Group = cisco, IP = , P1 Retransmit msg dispatched to AM FSM
Complete debug output is attached.
rgds/bsn
try to do this
conf t
and show
debug crypto isa 10
