IPsec VPN Phase 2 not working. Need help with Debug output
david.santel
Level 3
Level 3
Can someone please tell me why I can't establish Phase 2 ipsec negotiations.  I am trying to connect a 2651XM to a Pix 501.
Below is the debug isakmp and ipsec output and the configs. I have verified keys are the same. And transforms sets look ok. Any ideas why its not working?
What is the below telling me?
1:32:37: IPSEC(validate_transform_proposal): invalid local address 1.1.1.2
01:32:37: ISAKMP:(0:2:SW:1): IPSec policy invalidated proposal
01:32:37: ISAKMP:(0:2:SW:1): phase 2 SA policy not acceptable! (local 1.1.1.2 re
mote 1.1.1.3)
mote 1.1.1.3)
ISAKMP (0): beginning Quick Mode exchange, M-ID of -1154286426:bb32fca6
crypto_isakmp_process_block: src 1.1.1.2, dest 1.1.1.3
ISAKMP (0): processing NOTIFY payload 14 protocol 2
        spi 2224366689, message ID = 1503891776
ISAKMP (0): deleting spi 1629787524 message ID = 3140680870
return status is IKMP_NO_ERR_NO_TRANS
pixfirewall#
pixfirewall# sh crypto is
ISAKMP (0): beginning Quick Mode exchange, M-ID of 400184159:17da535f
        spi 2649583861, message ID = 1778335964a
ISAKMP (0): deleting spi 4117818781 message ID = 400184159
return status is IKMP_NO_ERR_NO_TRANSkmp sa
Total     : 1
Embryonic : 0
        dst             src          state       pending    created
         1.1.1.2          1.1.1.3    QM_IDLE         0           0
pixfirewall#
ISAKMP (0): beginning Quick Mode exchange, M-ID of 923039456:370476e0
        spi 2163779852, message ID = 2746774364
ISAKMP (0): deleting spi 212465792 message ID = 923039456
return status is IKMP_NO_ERR_NO_TRANSexi
Logoff
CCC#sh cryp
CCC#sh crypto isakmp sa
dst             src             state          conn-id slot status
1.1.1.2         1.1.1.3         QM_IDLE              1    0 ACTIVE
CCC#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CCC#ping 192.168.1.5
Sending 5, 100-byte ICMP Echos to 192.168.1.5, timeout is 2 seconds:
CCC#debug crypto isakmp
Crypto ISAKMP debugging is on
CCC#debug crypto ipsec
Crypto IPSEC debugging is on
CCC#debug crypto verbose
verbose debug output debugging is on
CCC#
00:51:24: ISAKMP (0:134217729): received packet from 1.1.1.3 dport 500 sport 500
Global (R) QM_IDLE
00:51:24: ISAKMP: set new node 1268073006 to QM_IDLE
00:51:24: ISAKMP:(0:1:SW:1): processing HASH payload. message ID = 1268073006
00:51:24: ISAKMP:(0:1:SW:1): processing SA payload. message ID = 1268073006
00:51:24: ISAKMP:(0:1:SW:1):Checking IPSec proposal 1
00:51:24: ISAKMP: transform 1, AH_SHA
00:51:24: ISAKMP:   attributes in transform:
00:51:24: ISAKMP:      encaps is 1 (Tunnel)
00:51:24: ISAKMP:      SA life type in seconds
00:51:24: ISAKMP:      SA life duration (basic) of 28800
00:51:24: ISAKMP:      SA life type in kilobytes
00:51:24: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
00:51:24: ISAKMP:      authenticator is HMAC-SHA
00:51:24: ISAKMP:(0:1:SW:1):atts are acceptable.
00:51:24: ISAKMP: transform 1, ESP_3DES
00:51:24: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= 1.1.1.2, remote= 1.1.1.3,
    local_proxy= 10.10.10.0/255.255.255.0/0/0 (type=4),
    remote_proxy= 192.168.1.0/255.255.255.0/0/0 (type=4),
    protocol= AH, transform= ah-sha-hmac  (Tunnel),
    lifedur= 0s and 0kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x2
00:51:24: IPSEC(validate_proposal_request): proposal part #2,
    protocol= ESP, transform= esp-3des  (Tunnel),
00:51:24: IPSEC(validate_transform_proposal): invalid local address 1.1.1.2
00:51:24: ISAKMP:(0:1:SW:1): IPSec policy invalidated proposal
00:51:24: ISAKMP:(0:1:SW:1): phase 2 SA policy not acceptable! (local 1.1.1.2 re
mote 1.1.1.3)
00:51:24: ISAKMP: set new node -429221146 to QM_IDLE
00:51:24: ISAKMP:(0:1:SW:1):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 2
        spi 2237255312, message ID = -429221146
00:51:24: ISAKMP:(0:1:SW:1): sending packet to 1.1.1.3 my_port 500 peer_port 500
(R) QM_IDLE
00:51:24: ISAKMP:(0:1:SW:1):purging node -429221146
00:51:24: ISAKMP:(0:1:SW:1):deleting node 1268073006 error TRUE reason "QM rejec
ted"
00:51:24: ISAKMP (0:134217729): Unknown Input IKE_MESG_FROM_PEER, IKE_QM_EXCH:
for node 1268073006: state = IKE_QM_READY
00:51:24: ISAKMP:(0:1:SW:1):Node 1268073006, Input = IKE_MESG_FROM_PEER, IKE_QM_
EXCH
00:51:24: ISAKMP:(0:1:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_READY
00:51:24: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer
at 1.1.1.3
00:51:54: ISAKMP (0:134217729): received packet from 1.1.1.3 dport 500 sport 500
Global (R) QM_IDLE
00:51:54: ISAKMP: set new node -500877443 to QM_IDLE
00:51:54: ISAKMP:(0:1:SW:1): processing HASH payload. message ID = -500877443
00:51:54: ISAKMP:(0:1:SW:1): processing SA payload. message ID = -500877443
00:51:54: ISAKMP:(0:1:SW:1):Checking IPSec proposal 1
00:51:54: ISAKMP: transform 1, AH_SHA
00:51:54: ISAKMP:   attributes in transform:
00:51:54: ISAKMP:      encaps is 1 (Tunnel)
00:51:54: ISAKMP:      SA life type in seconds
00:51:54: ISAKMP:      SA life duration (basic) of 28800
00:51:54: ISAKMP:      SA life type in kilobytes
00:51:54: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
00:51:54: ISAKMP:      authenticator is HMAC-SHA
00:51:54: ISAKMP:(0:1:SW:1):atts are acceptable.
00:51:54: ISAKMP: transform 1, ESP_3DES
00:51:54: IPSEC(validate_proposal_request): proposal part #1,
00:51:54: IPSEC(validate_proposal_request): proposal part #2,
00:51:54: IPSEC(validate_transform_proposal): invalid local address 1.1.1.2
00:51:54: ISAKMP:(0:1:SW:1): IPSec policy invalidated proposal
00:51:54: ISAKMP:(0:1:SW:1): phase 2 SA policy not acceptable! (local 1.1.1.2 re
mote 1.1.1.3)
00:51:54: ISAKMP: set new node -701693099 to QM_IDLE
00:51:54: ISAKMP:(0:1:SW:1):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 2
        spi 2237255312, message ID = -701693099
00:51:54: ISAKMP:(0:1:SW:1): sending packet to 1.1.1.3 my_port 500 peer_port 500
(R) QM_IDLE
00:51:54: ISAKMP:(0:1:SW:1):purging node -701693099
00:51:54: ISAKMP:(0:1:SW:1):deleting node -500877443 error TRUE reason "QM rejec
ted"
00:51:54: ISAKMP (0:134217729): Unknown Input IKE_MESG_FROM_PEER, IKE_QM_EXCH:
for node -500877443: state = IKE_QM_READY
00:51:54: ISAKMP:(0:1:SW:1):Node -500877443, Input = IKE_MESG_FROM_PEER, IKE_QM_
EXCH
00:51:54: ISAKMP:(0:1:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_READY
00:52:14: ISAKMP:(0:1:SW:1):purging node 1268073006
00:52:44: ISAKMP:(0:1:SW:1):purging node -500877443...
00:52:50: ISAKMP (0:134217729): received packet from 1.1.1.3 dport 500 sport 500
Global (R) QM_IDLE
00:52:50: ISAKMP: set new node 1186613650 to QM_IDLE
00:52:50: ISAKMP:(0:1:SW:1): processing HASH payload. message ID = 1186613650
00:52:50: ISAKMP:(0:1:SW:1): processing SA payload. message ID = 1186613650
00:52:50: ISAKMP:(0:1:SW:1):Checking IPSec proposal 1
00:52:50: ISAKMP: transform 1, AH_SHA
00:52:50: ISAKMP:   attributes in transform:
00:52:50: ISAKMP:      encaps is 1 (Tunnel)
00:52:50: ISAKMP:      SA life type in seconds
00:52:50: ISAKMP:      SA life duration (basic) of 28800
00:52:50: ISAKMP:      SA life type in kilobytes
00:52:50: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
00:52:50: ISAKMP:      authenticator is HMAC-SHA
00:52:50: ISAKMP:(0:1:SW:1):atts are acceptable.
00:52:50: ISAKMP: transform 1, ESP_3DES
00:52:50: IPSEC(validate_proposal_request): proposal part #1,
00:52:50: IPSEC(validate_proposal_request): proposal part #2,
    remote_proxy= 192.1.68.1.0/255.255.255.0/0/0 (type=4),
00:52:50: IPSEC(validate_transform_proposal): invalid local address 1.1.1.2
00:52:50: ISAKMP:(0:1:SW:1): IPSec policy invalidated proposal
00:52:50: ISAKMP:(0:1:SW:1): phase 2 SA policy not acceptable! (local 1.1.1.2 re
mote 1.1.1.3)
00:52:50: ISAKMP: set new node -1113601414 to QM_IDLE
00:52:50: ISAKMP:(0:1:SW:1):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 2
        spi 2237255312, message ID = -1113601414
00:52:50: ISAKMP:(0:1:SW:1): sending packet to 1.1.1.3 my_port 500 peer_port 500
(R) QM_IDLE
00:52:50: ISAKMP:(0:1:SW:1):purging node -1113601414
00:52:50: ISAKMP:(0:1:SW:1):deleting node 1186613650 error TRUE reason "QM rejec
ted"
00:52:50: ISAKMP (0:134217729): Unknown Input IKE_MESG_FROM_PEER, IKE_QM_EXCH:
for node 1186613650: state = IKE_QM_READY
00:52:50: ISAKMP:(0:1:SW:1):Node 1186613650, Input = IKE_MESG_FROM_PEER, IKE_QM_
EXCH
00:52:50: ISAKMP:(0:1:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_READY
00:52:50: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer
at 1.1.1.3        .
CCC#
00:53:20: ISAKMP (0:134217729): received packet from 1.1.1.3 dport 500 sport 500
Global (R) QM_IDLE
00:53:20: ISAKMP: set new node 459446741 to QM_IDLE
00:53:20: ISAKMP:(0:1:SW:1): processing HASH payload. message ID = 459446741
00:53:20: ISAKMP:(0:1:SW:1): processing SA payload. message ID = 459446741
00:53:20: ISAKMP:(0:1:SW:1):Checking IPSec proposal 1
00:53:20: ISAKMP: transform 1, AH_SHA
00:53:20: ISAKMP:   attributes in transform:
00:53:20: ISAKMP:      encaps is 1 (Tunnel)
00:53:20: ISAKMP:      SA life type in seconds
00:53:20: ISAKMP:      SA life duration (basic) of 28800
00:53:20: ISAKMP:      SA life type in kilobytes
00:53:20: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
00:53:20: ISAKMP:      authenticator is HMAC-SHA
00:53:20: ISAKMP:(0:1:SW:1):atts are acceptable.
00:53:20: ISAKMP: transform 1, ESP_3DES
00:53:20: IPSEC(validate_proposal_request): proposal part #1,
00:53:20: IPSEC(validate_proposal_request): proposal part #2,
00:53:20: IPSEC(validate_transform_proposal): invalid local address 1.1.1.2
00:53:20: ISAKMP:(0:1:SW:1): IPSec policy invalidated proposal
00:53:20: ISAKMP:(0:1:SW:1): phase 2 SA policy not acceptable! (local 1.1.1.2 re
mote 1.1.1.3)
00:53:20: ISAKMP: set new node -1692074376 to QM_IDLE
00:53:20: ISAKMP:(0:1:SW:1):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 2
        spi 2237255312, message ID = -1692074376
00:53:20: ISAKMP:(0:1:SW:1): sending packet to 1.1.1.3 my_port 500 peer_port 500
(R) QM_IDLE
00:53:20: ISAKMP:(0:1:SW:1):purging node -1692074376
00:53:20: ISAKMP:(0:1:SW:1):deleting node 459446741 error TRUE reason "QM reject
ed"
00:53:20: ISAKMP (0:134217729): Unknown Input IKE_MESG_FROM_PEER, IKE_QM_EXCH:
for node 459446741: state = IKE_QM_READY
00:53:20: ISAKMP:(0:1:SW:1):Node 459446741, Input = IKE_MESG_FROM_PEER, IKE_QM_E
XCH
00:53:20: ISAKMP:(0:1:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_READY
00:53:40: ISAKMP:(0:1:SW:1):purging node 1186613650
00:53:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, chang
ed state to down
00:54:10: ISAKMP:(0:1:SW:1):purging node 459446741
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list outside_cryptomap_20 permit ip 192.168.1.0 255.255.255.0 10.10.10.0
255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.1.0 255.255.255.0 10.10.1
0.0 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 1.1.1.3 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 10.10.10.0 255.255.255.0 inside
pdm location 10.10.10.0 255.255.255.0 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 1.1.1.2 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set Petaluma_VPN ah-sha-hmac esp-3des
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set peer 1.1.1.2
crypto map outside_map 20 set transform-set Petaluma_VPN
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address 1.1.1.2 netmask 255.255.255.255 no-xauth no-config-m
ode
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.5-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:8c0d4948407071d3515f1546cf8bc147
: end
pixfirewall#
CCC#sh run
Building configuration...
Current configuration : 1328 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname CCC
boot-start-marker
boot system flash c2600-adventerprisek9-mz.124-25d.bin
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp key cisco123 address 1.1.1.3
crypto map Petaluma_1 1 ipsec-isakmp
set peer 1.1.1.3
match address 100
interface FastEthernet0/0
ip address 1.1.1.2 255.255.255.0
speed auto
half-duplex
interface Serial0/0
no ip address
shutdown
clock rate 56000
interface FastEthernet0/1
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 192.168.1.0 255.255.255.0 1.1.1.3
no ip http server
no ip http secure-server
access-list 100 permit ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
CCC#
encr 3des
hash md5
group 2
set peer 1.1.1.3
match address 100
speed auto
half-duplex
interface Serial0/0
no ip address
shutdown
clock rate 56000
duplex auto
speed auto
no ip http server
Loren Kolnes
Hi David,
Looking over the router configuration it seems as thought you applied the crypto map to the wrong interface.
speed auto
half-duplex
duplex auto
speed auto
Since the pix will attempt to build a VPN tunnel to 1.1.1.2 the crypto map Petaluma_1 should be applied to FastEthernet0/0, not FastEthernet 0/1.
Let me know if this helps.
Loren
Loren Kolnes
Hi David,
speed auto
half-duplex
duplex auto
speed auto
Loren
Hi Loren,
Good catch! That was the fix. Can't believe I missed that! Thanks!!!!!!!!
