IPSEC VPN REMOTE CLIENT PROBLEM
djemba-djemba
Community Member
Dear Expert,
I want to set up a VPN remote client for a LAPTOP which is going to access the computers under my network which a ASA 5510 is proctected.
From the ASA 5510 tools CD, I found a VPN Client 5.xx version is provided, But I don't know why it seems to be not match with my ASA 5510 VPN setting. The ASA 5510 VPN Remote Access must set 3DES sthon phase 1 and 2 for security. However, I can not find any places on the provided Client to set this kind of encrytion types.
Do you have any other VPN Remote Client that can work with the ASA, or any other solutions?
Thanks!
ajagadee
The VPN Client 5.x should work with the ASA. Have you already configured the ASA for Remote Access and tried connecting using the VPN Client 5.x. If so, can you post the debugs from the ASA.
Also, there is no hard setting on the VPN Client for the IKE Proposals. The VPN Client has a set of built in IKE Proposals and negotiates this with the ASA VPN Server. Please refer the below URL for the supported IKE Proposals:
http://www.cisco.com/en/US/docs/security/vpn_client/cisco_vpn_client/vpn_client46/administration/guide/vcAch8.html#wp1157757
Arul
*Pls rate if it helps*
