IPSEC VPN using AES256 SHA256 not establishing 887VA
stuart.pannell
Level 3
Level 3
Hi all, I have setup an IPSEC VPN between 2 routers in a lab environment as I wasn't able to get this to work in my live environment and I am seeing the same issues: -
1/ I setup 2 887VA routers with the following and this works: -
Router 1
crypto isakmp policy 10
 encr aes 256
 hash sha256
 authentication pre-share
 group 2
crypto isakmp key xxxxxxxxxx address 192.168.0.2
crypto ipsec transform-set aesset esp-aes 256 esp-sha-hmac
 mode tunnel
crypto map aesmap 10 ipsec-isakmp
 set peer 192.168.0.2
 set transform-set aesset
 match address 120
access-list 120 permit ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 120 permit ip 10.0.1.0 0.0.0.255 10.0.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 Vlan1
interface Vlan1 ## point-to-point connection to router 2 ##
 ip address 192.168.0.1 255.255.255.252
 crypto map aesmap
end
interface Vlan2
 ip address 10.0.0.1 255.255.255.0
 no autostate
end
interface FastEthernet1
 mtu 1452
 no ip address
end
Router 2
 encr aes 256
 hash sha256
 group 2
crypto isakmp key xxxxxxxxxx address 192.168.0.1
 mode tunnel
 set peer 192.168.0.1
 match address 120
interface Vlan1 ## point-to-point connection to router 1 ##
 ip address 192.168.0.2 255.255.255.252
 crypto map aesmap
end
interface Vlan2
 ip address 10.0.1.1 255.255.255.0
 no autostate
end
 mtu 1452
 no ip address
end
My issue is when I try to change the line "crypto ipsec transform-set aesset esp-aes 256 esp-sha-hmac" on both routers to be "crypto ipsec transform-set aesset esp-aes 256 esp-sha256-hmac"
Changing the transform-set to be stronger using sha256 appears to break the routers, they become slow to respond and the VPN fails to establish at stage2
Would I be right in thinking that the 887 routers are unable to support crypto ipsec transform-set aesset esp-aes 256 esp-sha256-hmac ?
My live environment was the same with a checkpoint firewall being one of the endpoints and the 887 being the remotes end
stuart.pannell
Level 3
Level 3
Just in case anyone else comes across this, it's an IOS bug and needs upgrading to 15.4(3)M or above
Yes, I have the same exact problem running;  esp-aes 256 esp-sha256-hmac , on the crypto IPsec transform-set.  Current IOS on 2911 router;  15.5(3)M
 I'll downgrade to 15.4(3)M and report back.
