ISDN and callback problem
sleste
I have a client has a Cisco 2600 router configured with ISDN callback for one of their users. On their last bill from the telco they saw that during the callback session, another 0,04 Norwegian kroner was charged about every 30 sec. during the callback connection was established and running. Just wondering if the router is doing something it shouldn't as I find it strange that it makes a call attempt to the callback phone no. when it already is established.
Would like a second oppinion. Can anyone look at the config below and see if anything concerning callback is either wrong and/or be the reason for the problem?
My experience rather sketchy when it comes to remote access routers.
Current configuration : 3252 bytes
version 12.2
service exec-callback
service timestamps debug uptime
service timestamps log uptime
hostname 2612-ISDN-GW
enable secret 5 xxxxxxxxxxxxxxxx
enable password xxx
username yyy password 0 xxx
username yyy callback-dialstring 555-12345678 password 0 xxx
ip subnet-zero
no ip domain-lookup
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-31
interface Ethernet0/0
no ip address
half-duplex
no cdp enable
interface TokenRing0/0
ip address 192.168.0.245 255.255.255.0
ring-speed 16
no cdp enable
interface Serial1/0:15
no ip address
encapsulation ppp
dialer rotary-group 1
ppp callback accept
ppp authentication chap callin
ppp multilink
interface Dialer1
description *********** Incomming calls *************
ip unnumbered TokenRing0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 14400
dialer hold-queue 10
dialer load-threshold 1 either
ppp callback accept
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.254
ip http server
ip pim bidir-enable
map-class dialer callback
dialer callback-server username
logging 192.168.0.201
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password xxxxxx
login
no scheduler allocate
end
Steffen
6 Replies 6
Kevin Dorrell
Level 11
Level 11
Is it the client that is being charged the extra 0,04 Kr, or the central site. If it is the client, the problem probably lies in the client configuration. If it is the central site, this is probably because of the load-threshold and multilink; in this case it is probably the client that is taking down the call after 30 seconds.
Maybe the client doesn't have multilink correctly configured, but is accepting the second connection. However, there is no data flowing on the second connection because the data is balanced by session, therefore the client takes down the second channel after a timeout.
I think I would like to see the remote config as well.
Kevin Dorrell
Luxembourg
and thanx for the quick reply.
The 0,04 is being charged the central site. So, to me it looks like it is trying to establish a extra connection back to the client.
The clients are either Windows 2000 or XP.
In that case, I guess it is the multilink and load-threshold that is trying to open a second parallel link. I would remove the load-threshold and let the other end decide whether a second link is required.
Kevin Dorrell
Luxembourg
Thanx a lot, and I will try that and see what happens. If I still have problems, I will return to this thread.
Have a good weekend, and again... thanx a lot!
Steffen
Steffan,
OK, but please return to the thread even if the problem is fixed ... that way we can all benefit from the experience.
Have a nice weekend yourself.
It shall be done. 🙂
