ISDN E1 problems
Steven Peree
Community Member
Hi for some reason our ISDN dialout is not working. Any help would be greatly appreciated :
brussel3#sh run
Building configuration...
Current configuration : 6804 bytes
! Last configuration change at 08:18:01 NFT-1DF Thu Apr 26 2012 by ppp
version 12.4
hostname yyyy
boot-start-marker
boot system flash c3725-ipbasek9-mz.124-11.XW7.bin
boot system tftp c3725-i-mz.122-13.T9.bin 255.255.255.255
boot-end-marker
logging buffered 10000
no logging console
enable secret 5 $1$qFs5$Ez01V2kTc9OZLx24SG/Iy1
aaa new-model
aaa group server radius AUTHEN
server 193.202.69.1 auth-port 1645 acct-port 0
server 193.202.68.161 auth-port 1645 acct-port 0
aaa group server radius ACCOUNT
server 193.202.68.173 auth-port 0 acct-port 1646
aaa authentication login default local group tacacs+
aaa authentication login NO_AUTHENT none
aaa authentication ppp default local group AUTHEN
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization exec NO_AUTHOR none
aaa authorization network default local group radius
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group ACCOUNT
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone NRT 1
clock summer-time NFT-1DFT recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate wic 2
ip cef
no ip domain lookup
ip address-pool local
async-bootp dns-server 172.17.49.102 193.202.69.2
isdn switch-type primary-net5
isdn voice-call-failure 0
chat-script offhook "" "ATH1" OK \c
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
username xxx secret 5 xxx
archive
log config
  hidekeys
controller E1 0/0
pri-group timeslots 1-31
description VZB
controller E1 1/0
shutdown
clock source internal
controller E1 1/1
shutdown
framing NO-CRC4
interface FastEthernet0/0
ip address 172.17.51.252 255.255.240.0
ip access-group 101 out
speed 100
full-duplex
interface Serial0/0:15
description VZB-Dial-xxx-0224545454
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
no snmp trap link-status
isdn incoming-voice modem
no peer default ip address
no cdp enable
ppp callback permit
ppp authentication ms-chap-v2 ms-chap chap
ppp multilink
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 180
dialer-group 1
peer default ip address pool GVBpool
no cdp enable
ppp callback permit
ppp authentication ms-chap chap callin
ppp multilink
interface Group-Async1
physical-layer async
encapsulation ppp
dialer in-band
dialer idle-timeout 1800
dialer-group 1
async mode interactive
ppp callback permit
ip local pool GVBpool 172.17.55.1 172.17.55.32
ip route 0.0.0.0 0.0.0.0 172.17.51.250
no ip http server
no ip http secure-server
ip sla responder
logging trap debugging
logging facility local2
logging 193.202.68.219
access-list 11 permit 10.132.133.73
access-list 20 permit 193.202.68.0 0.0.0.255
access-list 20 permit 193.210.201.192 0.0.0.31
access-list 20 permit 172.17.48.0 0.0.15.255
access-list 101 permit tcp host 172.17.56.8 host 193.202.68.62 eq 3389
access-list 101 permit tcp host 172.17.56.8 host 193.202.68.62 eq www
access-list 101 deny   ip host 172.17.56.8 any log
access-list 101 permit tcp host 172.17.56.10 host 193.202.68.62 eq 3389
access-list 101 permit tcp host 172.17.56.10 host 193.202.68.62 eq www
access-list 101 permit ip host 172.17.56.10 host 193.202.68.248
access-list 101 permit ip host 172.17.56.11 host 193.202.68.248
access-list 101 deny   ip host 172.17.56.11 any log
access-list 101 permit ip any any
access-list 2001 permit ip any host 172.17.49.105
access-list 2002 permit ip 172.17.55.0 0.0.0.255 host 172.17.49.106
access-list 2003 permit ip 172.17.55.0 0.0.0.255 host 172.17.66.27
access-list 2004 permit tcp 172.17.55.0 0.0.0.255 10.132.224.0 0.0.0.255 eq telnet
access-list 2005 permit ip 172.17.55.0 0.0.0.255 host 193.202.68.249
access-list 2006 permit ip 172.17.55.0 0.0.0.255 host 193.202.68.105
access-list 2007 permit ip 172.17.55.0 0.0.0.255 host 193.202.68.139
access-list 2007 permit ip 172.17.55.0 0.0.0.255 host 193.202.72.65
access-list 2008 permit ip 172.17.55.0 0.0.0.255 10.132.224.0 0.0.0.255
access-list 2009 permit tcp 172.17.55.0 0.0.0.255 host 193.202.68.249 eq telnet
access-list 2009 permit tcp 172.17.55.0 0.0.0.255 gt 1023 host 172.17.18.5 eq ftp
access-list 2009 permit tcp 172.17.55.0 0.0.0.255 gt 1023 host 172.17.18.5 eq ftp-data established
access-list 2010 permit ip 172.17.55.0 0.0.0.255 10.132.194.0 0.0.0.255
access-list 2011 permit tcp 172.17.55.0 0.0.0.255 host 193.53.47.100 eq telnet
access-list 2012 permit ip 172.17.55.0 0.0.0.255 host 193.202.69.39
access-list 2013 permit ip 172.17.55.0 0.0.0.255 host 193.202.68.62
dialer-list 1 protocol ip permit
snmp-server community xxx RO 10
snmp-server community xxxd RW 11
snmp-server trap-source FastEthernet0/0
snmp-server contact xxx
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server host 172.17.51.1 xxx  config snmp
snmp-server host 193.210.201.195 xxx  envmon config snmp
snmp-server host 193.210.201.221 xxx  tty frame-relay isdn x25 config hsrp
tacacs-server host 10.132.133.50
tacacs-server directed-request
tacacs-server key xxxx
radius-server key ******** xxxx
control-plane
banner login ^C
xxxx ! ! !
Authorized access only (TACACS)!
Disconnect IMMEDIATELY if you are not an authorized user ! ! !
^C
banner motd ^xxxx GROUP^C
line con 0
exec-timeout 0 0
logging synchronous
line 65 76
line aux 0
line vty 0 4
exec-timeout 0 0
ntp clock-period 17180512
ntp server 193.202.68.173
end
DEBUG
Apr 26 05:31:58.993: ISDN Se0/0:15 EVENT: UserIdle: callid 0x8002 received ISDN_CALL (0x0)
Apr 26 05:31:58.993: ISDN Se0/0:15 EVENT: process_pri_call: call id 0x8002, number 0224545454, Guid 00B115C06267, speed 64, call type DATA, redial No, CSM call No, pdata No
Apr 26 05:31:58.993: ISDN Se0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 0224545454
Apr 26 05:31:58.993: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=37 nr=37
Apr 26 05:31:58.993: ISDN Se0/0:15 Q931: SETUP pd = 8  callref = 0x0081
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x81, '0224545454'
                Plan:ISDN, Type:Unknown
Apr 26 05:31:59.005: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=38
Apr 26 05:31:59.121: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=37 nr=38
Apr 26 05:31:59.121: ISDN Se0/0:15 Q931: CALL_PROC pd = 8  callref = 0x8081
Apr 26 05:31:59.121: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=38
Apr 26 05:31:59.121: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x8002 calltype 1 CALL_PROCEEDING
Apr 26 05:31:59.273: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=38 nr=38
Apr 26 05:31:59.273: ISDN Se0/0:15 Q931: SETUP pd = 8  callref = 0x1ABF
                Standard = CCITT
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Calling Party Number i = 0x00A3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '224545454'
                Plan:ISDN, Type:National
        Sending Complete
Apr 26 05:31:59.273: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=39
Apr 26 05:31:59.273: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x20 calltype 1 CALL_INCOMING
Apr 26 05:31:59.273: ISDN Se0/0:15 EVENT: call_incoming: call_id 0x0020, Guid = 00FFFFFFFFFF
Apr 26 05:31:59.277: ISDN Se0/0:15 EVENT: UserIdle: callid 0x20 received ACCEPT_CALL (0x13)
Apr 26 05:31:59.277: %LINK-3-UPDOWN: Interface Serial0/0:0, changed state to up
Apr 26 05:31:59.277: %ISDN-6-CONNECT: Interface Serial0/0:0 is now connected to N/A N/A
Apr 26 05:31:59.277: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=38 nr=39
Apr 26 05:31:59.277: ISDN Se0/0:15 Q931: CALL_PROC pd = 8  callref = 0x9ABF
        Channel ID i = 0xA98381
                Exclusive, Channel 1
Apr 26 05:31:59.277: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=39 nr=39
Apr 26 05:31:59.277: ISDN Se0/0:15 Q931: CONNECT pd = 8  callref = 0x9ABF
Apr 26 05:31:59.285: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=39
Apr 26 05:31:59.289: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=40
Apr 26 05:31:59.317: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=39 nr=40
Apr 26 05:31:59.317: ISDN Se0/0:15 Q931: CONNECT_ACK pd = 8  callref = 0x1ABF
Apr 26 05:31:59.321: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=40
Apr 26 05:31:59.321: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x20 calltype 1 CALL_PROGRESS
Apr 26 05:31:59.569: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=40 nr=40
Apr 26 05:31:59.569: ISDN Se0/0:15 Q931: CONNECT pd = 8  callref = 0x8081
Apr 26 05:31:59.569: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=41
Apr 26 05:31:59.569: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x8002 calltype 1 CALL_CONNECT
Apr 26 05:31:59.569: %LINK-3-UPDOWN: Interface Serial0/0:30, changed state to up
Apr 26 05:31:59.569: %ISDN-6-CONNECT: Interface Serial0/0:30 is now connected to 0224545454 N/A
Apr 26 05:31:59.569: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x8002 calltype 1 CALL_PROGRESS
Apr 26 05:31:59.573: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=40 nr=41
Apr 26 05:31:59.573: ISDN Se0/0:15 Q931: CONNECT_ACK pd = 8  callref = 0x0081
Apr 26 05:31:59.581: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=41
Apr 26 05:32:05.278: %ISDN-6-CONNECT: Interface Serial0/0:0 is now connected to N/A N/A
Apr 26 05:32:05.570: %ISDN-6-CONNECT: Interface Serial0/0:30 is now connected to 0224545454 N/A
Apr 26 05:32:09.583: ISDN Se0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=41
Apr 26 05:32:09.587: ISDN Se0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=41
Apr 26 05:32:19.588: ISDN Se0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=41
Apr 26 05:32:19.592: ISDN Se0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=41
Apr 26 05:32:19.724: ISDN Se0/0:15 EVENT: UserIdle: callid 0x8002 received ISDN_HANGUP (0x1)
Apr 26 05:32:19.724: ISDN Se0/0:15 EVENT: isdn_hangup: Hangup call to call id 0x8002 ces = 1
Apr 26 05:32:19.724: %ISDN-6-DISCONNECT: Interface Serial0/0:30  disconnected from 0224545454 , call lasted 20 seconds
Apr 26 05:32:19.724: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=41 nr=41
Apr 26 05:32:19.724: ISDN Se0/0:15 Q931: DISCONNECT pd = 8  callref = 0x0081
        Cause i = 0x8090 - Normal call clearing
Apr 26 05:32:19.732: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=42
Apr 26 05:32:19.968: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=41 nr=42
Apr 26 05:32:19.968: ISDN Se0/0:15 Q931: RELEASE pd = 8  callref = 0x8081
Apr 26 05:32:19.972: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=42
Apr 26 05:32:19.972: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x8002 calltype 1 CALL_CLEARED
Apr 26 05:32:19.972: %LINK-3-UPDOWN: Interface Serial0/0:30, changed state to down
Apr 26 05:32:19.972: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=42 nr=42
Apr 26 05:32:19.972: ISDN Se0/0:15 Q931: RELEASE_COMP pd = 8  callref = 0x0081
Apr 26 05:32:19.980: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=43
Apr 26 05:32:20.020: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=42 nr=43
Apr 26 05:32:20.024: ISDN Se0/0:15 Q931: DISCONNECT pd = 8  callref = 0x1ABF
Apr 26 05:32:20.024: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=43
Apr 26 05:32:20.024: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x20 calltype 1 CALL_DISC
Apr 26 05:32:20.024: %ISDN-6-DISCONNECT: Interface Serial0/0:0  disconnected from unknown , call lasted 20 seconds
Apr 26 05:32:20.024: %LINK-3-UPDOWN: Interface Serial0/0:0, changed state to down
Apr 26 05:32:20.024: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=43 nr=43
Apr 26 05:32:20.024: ISDN Se0/0:15 Q931: RELEASE pd = 8  callref = 0x9ABF
Apr 26 05:32:20.032: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=44
Apr 26 05:32:20.068: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=43 nr=44
Apr 26 05:32:20.068: ISDN Se0/0:15 Q931: RELEASE_COMP pd = 8  callref = 0x1ABF
Apr 26 05:32:20.072: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=44
Apr 26 05:32:20.072: ISDN Se0/0:15 EVENT: process_rxstate: ces/callid 1/0x20 calltype 1 CALL_CLEARED
Apr 26 05:32:30.073: ISDN Se0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=44
Apr 26 05:32:30.077: ISDN Se0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=44sh isdn
yyyy#sh isdn ac
yyyy#sh isdn active
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
yyyy#sh isdn his
yyyy#sh isdn history
Apr 26 05:32:40.078: ISDN Se0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=44
Apr 26 05:32:40.082: ISDN Se0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=44
                                ISDN CALL HISTORY
Call History contains all active calls, and a maximum of 100 inactive calls.
Inactive call data will be retained for a maximum of 15 minutes.
In    ---N/A---    224545454                    20
Out   ---N/A---   0224545454                    20                      0
Richard Burts
I believe that this line gives a good clue about what is going on:
What I think we can see in the debug is that the call was completed, that the call lasted 20 seconds (the same amount of time as the several preceding calls that show up in the history), and that the other side sent a hangup. So the question becomes why did the other side send a hangup?
Do you have any information from the device on the other side? Are there any error messages or debug outputs available from the other side?
Rick
Rick
