ISDN: How to check whether its point-to-point or multipoint
t4tauseef33
Hi, Is there any show/debug command to see whether the isdn link is point-to-point or multipoint?
When you configure isdn static tei, it's p-to-p, else, its p-to-mp.
Multinumber BRi are p-to-mp, in fact see your above got assigned a dynamic TEI.
7 Replies 7
andrew.prince
Level 10
Level 10
It will only be pt-pt, but you can have multiple calls into a hub depending on the ISDN presentation, ISDN 2 or ISDN PRI.
HTH>
paolo bevilacqua
Check for no TEI assigned when configured p-to-mp on a p-t-p circuit.
Generally, multiple circuits with a single pilot number are p-t-p.
we have ISDN2e. I want to check whether this ISDN is p-to-p or p-to-mp. From the configuration, i have not configured it manullay as a point to point or point to multipoint.
On this ISDN we have two ISDN numbers. How can i check it? below is the show isdn status command.
show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 115, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Pls tell me if that BRI configured as Point to point then what will be a value for the TEI
Check your dialer map statements.
The TEI (Terminal Ennpoint Identifier) is assigned to the line from the exchange.
Always 0.
