issue:3G & ADSL on same router
jain.nitin
Level 3
Level 3
Hi All,
I am in problem where I have 3G and ADSL line together on a single router and if ADSL line fails router should provide internet through 3G and vice versa...
I have configured the router with only one dialer interface 1. As soon as adsl line dials I get an IP internet works but when I try to do the failover by removing ADSL cable from ethernet (PPPoE) then 3G (cellular interface) does not dial out....i tried to change the sequence as well means first 3G dials and get the public IP then once 3G goes down adsl dials but it does not work in both case.
Can some give me configuration for working 3G & ADSL both together with NAT as well...currently I configured NAT with route-map and it seems to be working...
Please help me to resolve this issue.
NK
paolo bevilacqua
Is not that like one can "give configuration for  working".
You must find why your is not working, using normal troubleshooting techniques.
