Issue with access using mobile device
My client has a PC that can use a SIM card to gain access to the internet.  They have an ASA5540 and are running IPsec VPN.
When accessing the VPN while the PC connects to the internet via use of the SIM card, he connects successfully to the VPN but is unable to access anything on the internal network.  If he connects to the internet using wireless or wired, he connects successfully to the VPN and is able to access everything on the internal network.
Is this a limitation of the Cisco VPN Client?  Perhaps something missing in the configuration?  Or do they still require the mobility license (though I thought that was only for AnyConnect)?
thanks
Please remember to select a correct answer and rate helpful posts
Marcin Latosiewicz
Marius,
It could be one of many limiations of old VPN client, but it's hard to say at first glance.
FIrst thing to check is whether the ASA is actually reciving encrypted packets from clients post connection :-)
Open up a TAC case - we'll help.
M.
