L2L IPSEC Hub (Static) and Spoke (DHCP)
lepITSupport
Cisco ASA 5510 Static DHCP (Hub) - Cisco ASA 5505 WAN DHCP (spoke)
L2L Tunnel is up but passing no traffic
sh cryp ipsec sa (Hub)
peer address: 187.xxx.xxx.xxx
    Crypto map tag: Outside_dyn_map, seq num: 40, local addr: 38.xxx.xxx.xxx
      access-list outside_cryptomap_65535.40 extended permit ip 192.168.80.0 255.255.255.0 192.168.37.0 255.255.255.0
      local ident (addr/mask/prot/port): (192.168.80.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.37.0/255.255.255.0/0/0)
      current_peer: 187.xxx.xxx.xxx
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 23, #pkts decrypt: 23, #pkts verify: 23
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 38.xxx.xxx.xxx/4500, remote crypto endpt.: 187.xxx.xxx.xxx/4500
      path mtu 1500, ipsec overhead 66, media mtu 1500
      current outbound spi: 67210F88
      current inbound spi : 75428968
    inbound esp sas:
      spi: 0x75428968 (1967294824)
         transform: esp-des esp-sha-hmac no compression
         in use settings ={L2L, Tunnel,  NAT-T-Encaps, PFS Group 1, }
         slot: 0, conn_id: 8605696, crypto-map: Outside_dyn_map
         sa timing: remaining key lifetime (kB/sec): (4373998/26389)
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00FFFFFF
    outbound esp sas:
      spi: 0x67210F88 (1730219912)
         sa timing: remaining key lifetime (kB/sec): (4374000/26389)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
      access-list outside_cryptomap_65535.40 extended permit ip 192.168.90.0 255.255.255.0 192.168.37.0 255.255.255.0
      local ident (addr/mask/prot/port): (192.168.90.0/255.255.255.0/0/0)
      #pkts decaps: 5, #pkts decrypt: 5, #pkts verify: 5
      current outbound spi: E58F341D
      current inbound spi : 38748ED6
    inbound esp sas:
      spi: 0x38748ED6 (947162838)
         sa timing: remaining key lifetime (kB/sec): (4373999/27967)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x0000003F
    outbound esp sas:
      spi: 0xE58F341D (3851367453)
         sa timing: remaining key lifetime (kB/sec): (4374000/27967)
         IV size: 8 bytes
         Anti replay bitmap:
sh crypto ipsec sa (Spoke)
interface: outside
    Crypto map tag: outside_map, seq num: 1, local addr: 10.10.10.2
      access-list outside_cryptomap_1 extended permit ip 192.168.37.0 255.255.255.0 192.168.80.0 255.255.255.0
      local ident (addr/mask/prot/port): (SpokeSubnet1/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (HubSubnet1/255.255.255.0/0/0)
      current_peer: 38.xxx.xxx.xxx
      #pkts encaps: 23, #pkts encrypt: 23, #pkts digest: 23
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts not compressed: 23, #pkts comp failed: 0, #pkts decomp failed: 0
      local crypto endpt.: 10.10.10.2/4500, remote crypto endpt.: 38.xxx.xxx.xxx/4500
      current outbound spi: 75428968
      current inbound spi : 67210F88
    inbound esp sas:
         slot: 0, conn_id: 5005312, crypto-map: outside_map
         sa timing: remaining key lifetime (kB/sec): (3915000/25751)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (3914998/25751)
         IV size: 8 bytes
         Anti replay bitmap:
      access-list outside_cryptomap_1 extended permit ip 192.168.37.0 255.255.255.0 192.168.90.0 255.255.255.0
      remote ident (addr/mask/prot/port): (HubSubnet4/255.255.255.0/0/0)
      #pkts encaps: 5, #pkts encrypt: 5, #pkts digest: 5
      #pkts not compressed: 5, #pkts comp failed: 0, #pkts decomp failed: 0
      current outbound spi: 38748ED6
      current inbound spi : E58F341D
    inbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (3915000/27330)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (3914999/27330)
         IV size: 8 bytes
         Anti replay bitmap:
<span style="text-decoration: underline;" mcestyle="text-decoration: underline;">Crypto Dyn Map (Hub)</span>
crypto dynamic-map Outside_dyn_map 40 match address outside_cryptomap_65535.40
crypto dynamic-map Outside_dyn_map 40 set pfs group1
crypto dynamic-map Outside_dyn_map 40 set transform-set ESP-DES-SHA
crypto dynamic-map Outside_dyn_map 40 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 40 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 40 set reverse-route
<span style="text-decoration: underline;" mcestyle="text-decoration: underline;">Crypto Map (Spoke)</span>
crypto map outside_map 1 match address outside_1_cryptomap_1
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 38.109.190.210
crypto map outside_map 1 set transform-set ESP-DES-SHA
crypto map outside_map 1 set reverse-route
crypto map outside_map interface outside
<span style="text-decoration: underline;" mcestyle="text-decoration: underline;">Ping from Spoke to machine behind Hub</span>
ping inside 192.168.80.240
Message from Hub logs
713042   IKE Initiator unable to find policy: Intf outside, Src: 192.168.80.240, Dst: 192.168.37.1
<span style="text-decoration: underline;" mcestyle="text-decoration: underline;">Ping from Hub to spoke's inside interface</span>
ping inside 192.168.37.1
713041    IP = 213.xxx.xxx.xxx, IKE Initiator: New Phase 1, Intf NP Identity Ifc, IKE Peer 213.xxx.xxx.xxx  local Proxy Address 192.168.80.0, remote Proxy Address 192.168.37.0,  Crypto map (Outside_map)
<div class="mcePaste" id="_mcePaste" style="position: absolute; left: -10000px; top: 0px; width: 1px; height: 1px; overflow: hidden;" mcestyle="position: absolute; left: -10000px; top: 0px; width: 1px; height: 1px; overflow: hidden;"></div>
lepITSupport
This is a little more information:
The last message on the ping from the Hub to the spoke is attempting to use an Outside address of another spoke (213.xxx.xxx.xxx).  The tunnel is up but there is misconfigurations in my maps and ACLs.  Any help is greatly appreciated.
Thank you!
lepITSupport
I fixed it myself by removing all entries of the 192.168.37.0/32  in other ACLs.
