Lan 2 Lan over MPLS and can't use remote Internet Connection
jdwcal730
We are setting up a Lan 2 Lan VPN using MPLS. The eqipment is a IOS 12.2 router to PIX 7.0. The tunnel is up and everyone can access the systems on each others LANS.
The Internet connection is connected to the PIX. The users on the Router end cannot connect to the Internet.
However, when the router side tries to connect to the Internet, they traverse the tunnel. It never goes out to the Internet. Can't figure out why.
There is a NAT 0 statement and a global (outside) statement on the PIX. For the lcoal networks. Does the PIX decryt the traffic, and then PAT it to the Internet, then send the return traffic back to the originating IP address?
acomiskey
Level 10
Level 10
I "think" this is what you're looking for...it applied to l2l tunnels as well.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805734ae.shtml
