Lan-2-Lan VPN between Checkpoint (static IP) to ASA 5506 (PPPoE) - packets not encrypted in phase2
maktala007
We have a scenario as below:
Site A (static IP) : Checkpoint (R77.20 )
Site B (ADSL pppoe DHCP) : Cisco ASA5506 9.8(2)
Site A  <<< Lan-2-Lan VPN >>> Site B
We are seeing tunnel is getting 'up' (both phase 1 & 2), but don't see any traffic in the tunnel:
Attached is the running config and 'sh cry..' output for your immediate reference.
Does anyone have idea if this setup really works. Or am I missing any configuration ?
Any suggestion would be really appreciated.
Thanks in advance
Rajender
This is problem is resolved. Apparently the issue was found on the local server (192.168.255.10) which is behind the 'inside' of ASA.
The issue was identified as follows. I have enabled the packet capture on 'inside' interface of ASA. And initiated traffic to remote host. VPN tunnel was triggered and I was seeing packets in ipsec phase 2. But I don't see any reply from remote host nor echo reply in the packet capture:
#pkts encaps: 4, #pkts encrypt: 4, #pkts digest: 4
#pkts decaps: 4, #pkts decrypt: 4, #pkts verify: 4
9: 09:37:52.340817 192.168.255.10 > 3.194.223.246: icmp: echo request
10: 09:37:57.176794 192.168.255.10 > 3.194.223.246: icmp: echo request
11: 09:38:02.163489 192.168.255.10 > 3.194.223.246: icmp: echo request
Then, I captured the logs on local server and asked the remote admin to initiate the traffic from remote host.
VPN tunnel triggered, I am seeing the packets in phase 2 and in packet capture on ASA. But no packet were seen on the local server.
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 2, #pkts decrypt: 2, #pkts verify: 2
9: 10:44:23.842928 3.194.223.246 > 192.168.255.10: icmp: echo request
10: 10:44:25.393305 3.194.223.246 > 192.168.255.10: icmp: echo request
Then, me and remote admin agreed to add new host (192.168.255.111) to VPN ACL for testing and isolating the issue.
This works like a charm :-)
1: 10:58:12.235812 3.194.223.246.3742 > 192.168.255.111.3389: S 3566128414:3566128414(0) win 16384 <mss 536,nop,wscale 0,nop,nop,timestamp 1465992661 0>
2: 10:58:12.236437 192.168.255.111.3389 > 3.194.223.246.3742: S 132589075:132589075(0) ack 3566128415 win 64000 <mss 1460,nop,wscale 0>
3: 10:58:12.267365 3.194.223.246.3742 > 192.168.255.111.3389: . ack 132589076 win 16616
Thank you all.
Rajender
10 Replies 10
balaji.bandi
High level there is no traffic initiated ? from allowed source ?
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
can you post the configuration and ACL and interesting traffic allowed both the side?
BB
Thanks for the quick response. I have already attached the configuration and also initiated the traffic from end host as well as packet tracer from ASA. Let me know if you need more details.
Can you run packet-tracer from local network to remote network and provide the output for review. Need to ensure traffic is hitting the NAT exemption rule.
Though the Packet tracer output is there in the attachment, I am pasting it here again:
PPPOE-ASA# packet-tracer input inside_7 tcp 192.168.255.10 3389 3.193.0.2 5555
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (inside_7,outside) source static Jump_host Jump_host destination static SEN_VPN SEN_VPN no-proxy-arp
Additional Information:
NAT divert to egress interface outside
Untranslate 3.193.0.2/5555 to 3.193.0.2/5555
Phase: 2
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 192.168.255.10/3389 to 192.168.255.10/3389
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: VPN
Subtype: encrypt
Result: DROP
Config:
Result:
input-interface: inside_7
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Sorry I missed the attached first time around. Your ASA configuration looks ok as far as I can tell.
Is that output of the packet-tracer result run just once? To get an accurate result, packet-tracer needs to be run twice (the first packet-tracer test will bring up the tunnel and the second will actually simulate traffic sent over the tunnel).
I have run packet tracer multiple times (also initiated traffic from end host multiple times) but still no luck.
Please see attached logs.
The remote ident selector is 3.192.0.0/255.255.0.0 therefore 3.193.0.0 would not match, that is despite you defining the correct mask of 255.224.0.0 in your ACL. Check the configuration on the Check Point end.
access-list outside_cryptomap extended permit ip host 192.168.255.10 3.192.0.0 255.224.0.0
local ident (addr/mask/prot/port): (192.168.255.10/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (3.192.0.0/255.255.0.0/0/0)
Attempt to packet-tracer to any IP address within the 3.192.x.x network, just to confirm that works.
Verified with remote network admin. He confirmed that
network 3.192.0.0/11 is allowed in the VPN acl to the destination 3.195.136.110 (which they NATed to 192.168.255.10).
They have a seperate NAT rule: whenever src:3.192.0.0/11  dst: 3.195.136.110 , src will be original and dst will be 192.168.255.10.
Tried with 3 different IPs from the same network. Please see attachment for more logs:
3.195.0.2
remote ident (addr/mask/prot/port): (3.195.0.2/255.255.255.255/0/0)
3.192.0.2
3.194.13.60
remote ident (addr/mask/prot/port): (3.194.13.60/255.255.255.255/0/0)
20191218-UPDATE:
I have sent the information about 'remote ident..' to the network admin of other end and asked him to verify the config on Checkpoint one more time.
After some time, I have seen logs on my ASA (he might have initiated traffic from other end )as below (for full logs, please see attachment):
interface: outside
Crypto map tag: outside_map, seq num: 2, local addr: 7.139.95.7
remote ident (addr/mask/prot/port): (3.192.0.0/255.224.0.0/0/0)
current_peer: 95.2.36.40
#pkts decaps: 21, #pkts decrypt: 21, #pkts verify: 21
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#TFC rcvd: 0, #TFC sent: 0
#Valid ICMP Errors rcvd: 0, #Invalid ICMP Errors rcvd: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 7.139.95.7/500, remote crypto endpt.: 95.2.36.40/500
Whereas, when I run the packet-tracer from my ASA, it still the same issue as earlier.
Thank you all.
Rajender
