LTE in Germany using Telekom/Vodafone LAN-to-LAN tunnel
NISITNETC
Hello !
We habe some locations with very slow DSL connetion (< 200 kbit). Some services need direct vpn-connection to the datacenter and some RDP access etc. - the networks are connceted with LAN-to-LAN ipsec tunnel. Work's fine with slow speed.
Now we like to set up one side with LTE. Did someone set up ipsec with one side via LTE via Telekom or Vodafone in Germany ?
9 Replies 9
Michael Muenz
Level 5
Level 5
Yes, both works! We used the vendor modems and connect to IOS routers. Then we configured the links as backup EasyVPN connections.
Michael
Please rate all helpful posts
Michael Please rate all helpful posts
@ciscomax
You uses EasyVPN to get a LAN-to-LAN connection ?
Sure, with network extension mode, works great. But only for lte cause of thy dynamic ip adresses.
Michael
Ok. Never configured the "network extension mode". Can you drop the relevant part of your configuration? What Hardware and IOS do you use?
Sorry, was on vacation, do you still need the config parts?
Michael
Hello!
I'll be happy about a working config with Vodafone. Actually our Chat-Script ends with: "Chat script lte finished, status = Connection timed out; remote host not responding"
We use the B1000 from Vodafone to do the LTE stuff and behind it is a IOS router.
I can only provide D1 Chat Script (3G) from another project:
chat-script gsm "" "ATDT*99#" TIMEOUT 30 CONNECT
interface Cellular0
no ip address
ip flow ingress
encapsulation ppp
no ip mroute-cache
load-interval 60
dialer in-band
dialer pool-member 1
no ppp lcp fast-start
interface Dialer1
ip address negotiated
ip flow ingress
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
no cdp enable
ppp authentication chap callin
ppp chap hostname tm
ppp chap password 7 021209
ppp ipcp dns request
cellular 0 gsm profile create 1 internet.t-d1.de chap tm tm
Michael
PIN:
router#cellular 0/2/0 gsm sim unlock 6543
Create the profile:
router#cellular 0/2/0 gsm profile create 1 apnname.net
AT command is
ATD*gprs_sc*CID#
or
ATDT*gprs_sc*CID#
where gprs_sc (GPRS service code) is 99, but  98 can also work. T-Mobile says 99, Cisco docs contain 98.
                  Some modem manual says:
                 99 (GPRS Service Code) a digit string (value 99) that identifies a
                   request to use the Packet Domain service.
                  98 (GPRS Service Code) a digit string (value 98) that identifies a
                   request to use the IP service
CID (PDP Context Identifier) is the connection profile number (see show cellular 0/2/0 profile ), number between 1..16 This profile contains the APN name.
Typical AT command is: ATD*99*1#*
(Or simply *99# ,  default CID is obviously 1 )
I don't think you need a chat-script:
interface Cellular0/1/0
  no ip address
  encapsulation ppp
  load-interval 30
  dialer in-band
  dialer-group 1
  async mode interactive
interface Dialer0
ip address negotiated,
no ip redirects
  no ip proxy-arp
  encapsulation ppp
  load-interval 30
  dialer pool 1
  dialer string "*99*1#"
dialer persistent
dialer-group 1
  no cdp enable
  ppp pfc local forbid
  ppp pfc remote reject
  ppp acfc local forbid
  ppp acfc remote reject
  ppp eap refuse
  ppp eap local
  ppp chap refuse
  ppp ms-chap refuse
  ppp ms-chap-v2 refuse
  ppp pap refuse
  ppp ipcp address accept
dialer-list 1 protocol ip permit
Troubleshooting:
sh int cell0/0/0
sh cell 0/0/0 all
(config)#service internal
(config)#exit
#test cellular 0/0/0 modem-power-cycle
Hi, is it solved?
