Max Connect time setting ASA 5520
oklier
My searches are comming up blank for some reason, its just me. Just need to know where I can set a Max connect time so users dont camp on the ASA when they are not using it.
Thanks in advance!
In the same link provided before - look  under vpn-session-timeou  configuration ,   this command enforces a maximun RA connection  per tunnel   or per username
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/uz.html#wp1631430
PLS rate helpful posts
Jorge Rodriguez
8 Replies 8
JORGE RODRIGUEZ
Level 10
Level 10
if you meant users connected to ASA for administration of the firewall either by ssh/telnet/ or https you can set the timeout session  for each of these connections to the asa to expired at a certain time in minutes , if this is not what you meant please let us know.
#telnet timeout  < value in min> max is 1440 min
#ssh timeout     max is 60 min
# http server session-timeou   max is 1440
See command references http://www.cisco.com/en/US/products/ps6120/prod_command_reference_list.html
Jorge Rodriguez
Sorry not what I meant. I was looking for Max Time out for VPN clients, i.e. after 24 hours they get disconnected regardless of activity and they are forced to reconnect.
Sorry for not clarifying earlier.
ok
You are looking at vpn-idle-timeout attribute settings under group-policy for yourRA vpn tunnel  or per username  , follow guidelines bellow.
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/uz.html#wp1630720
Jorge Rodriguez
Thanks! I already have that set though. When they have Outlook open it will never be idle .
So then the connection is not idle,    if you want to   enforce a connection time then there is other settings you can use.
Jorge Rodriguez
You wouldnt happen to know them would you?
Jorge Rodriguez
Thanks!!
