07-17-2020 02:46 PM
Hi all,
I struggle to find information for how to configure Cisco ASA with Azure MFA. to be more precise, there are only two pieces that I miss.
What should I put in the Identifier and reply URL? I thought it's the existing / new tunnel-group from the ASA, but I guess it's a URL that I need to provide.
Can someone clarify it for me?
Lets say the new tunnel-group on the ASA will be called "anyconnect-tg" and the hostname of the firewall is "myasa5500.com"
Thanks in advance.
07-30-2020 01:40 AM
Sorry, I couldn't take the output
group-policy ANYCONNECT-POLICY internal group-policy ANYCONNECT-POLICY attributes banner none wins-server none dns-server value 10.50.0.10 10.50.0.11 dhcp-network-scope none vpn-access-hours none vpn-simultaneous-logins 3 vpn-idle-timeout 30 vpn-idle-timeout alert-interval 1 vpn-session-timeout none vpn-session-timeout alert-interval 1 vpn-filter none ipv6-vpn-filter none vpn-tunnel-protocol ssl-client ssl-clientless password-storage disable ip-comp disable re-xauth disable group-lock none pfs disable ipsec-udp enable ipsec-udp-port 10000 split-tunnel-policy tunnelspecified ipv6-split-tunnel-policy tunnelspecified split-tunnel-network-list value SPLIT default-domain value mywebsite.com split-dns value mywebsite.com myweb mywebsite.com split-tunnel-all-dns disable intercept-dhcp 255.255.255.255 disable secure-unit-authentication disable user-authentication disable user-authentication-idle-timeout 30 ip-phone-bypass disable client-bypass-protocol disable gateway-fqdn none leap-bypass disable nem disable backup-servers keep-client-config msie-proxy server none msie-proxy method no-modify msie-proxy except-list none msie-proxy local-bypass disable msie-proxy pac-url none msie-proxy lockdown enable vlan none address-pools none ipv6-address-pools none smartcard-removal-disconnect enable scep-forwarding-url none client-firewall none client-access-rule none webvpn url-list none filter none homepage none html-content-filter none port-forward disable http-proxy disable anyconnect ssl dtls enable anyconnect mtu 1406 anyconnect firewall-rule client-interface private none anyconnect firewall-rule client-interface public none anyconnect keep-installer installed anyconnect ssl keepalive 20 anyconnect ssl rekey time none anyconnect ssl rekey method none anyconnect dpd-interval client 30 anyconnect dpd-interval gateway 30 anyconnect ssl compression none anyconnect dtls compression none anyconnect modules none anyconnect profiles none anyconnect ask none customization none keep-alive-ignore 4 http-comp gzip download-max-size 2147483647 upload-max-size 2147483647 post-max-size 2147483647 user-storage none storage-objects value cookies,credentials storage-key none hidden-shares none smart-tunnel disable activex-relay enable unix-auth-uid 65534 unix-auth-gid 65534 file-entry enable file-browsing enable url-entry enable deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information smart-tunnel auto-signon disable anyconnect ssl df-bit-ignore disable anyconnect routing-filtering-ignore disable smart-tunnel tunnel-policy tunnelall always-on-vpn profile-setting
08-03-2020 04:48 AM
any ideas?
08-04-2020 05:36 AM
In your tunnel-group general attributes you have:
tunnel-group anyconnect general-attributes <snip> authentication-server-group LOCAL
but the webvpn attributes have:
tunnel-group anyconnect webvpn-attributes <snip> authentication saml
Why are they different? The LOCAL one shoudn't be needed at all.
08-04-2020 09:41 AM
before the change it was LDAP LOCAL
once I removed LDAP I only have left LOCAL which cannot remove
how it should be configured if I want SAML for authentication but LDAP to indicate the group-policy - is this is even possible?
08-04-2020 09:55 AM - edited 08-04-2020 10:00 AM
It should be possible to have authentication-server be saml and authorization-server be LDAP (AD).
Something like what's described here:
https://packetswitch.co.uk/cisco-anyconnect-with-azure-ad/
The example talks about MFA but that's just an attribute of the SAML authentication in their case.
