MST Transform help
patoberli
Hello
I've created a MST Transform file for Anyconnect 3.1 which removes the creation of the RUN key in the registry, so that the AnyConnect will not automatically started with Windows Boot.
I try to inlcude this MST now into the ASA, so that it will be deployed automatically with the web installation.
Has anybody any experience on how to do that?
Currently the active AnyConnect on my ASA is 2.5.x for Windows. ASA is 8.4.6 and ASDM is 7.1.3.
When I go to Configuration - Remote Access VPN - Network (Client) Access - AnyConnect Customization/Localization - Customize Installer Transforms and import there my .mst file, it does not offer to apply the configuration. It also seems to not work, but I can't really test it, as it's a live system with many users.
Any ideas if I do something wrong?
Attached is the MST file.
Patrick
0 Replies 0
