Mutiple AnyConnect profiles on same client to same ASA
networkhelp1
Is there a way, on the client side, to have 2 profiles pointing to the same ASA ? If so , can they show in the drop down box ?
Yes, this is possible. And you can have them show in the drop down box, this will automatically be populated once you connect and download the profiles.  remember that the profiles should be associated with different group-policies.
Please remember to select a correct answer and rate helpful posts
