Need help configuring NAT on ASR for internet using VRF's for IPSEC VPN's
TracyMcClain
I am working with an ASR 1006 that is used strictly for IPSEC VPN tunnels and am utilizing VRF's to segregate traffic to support instances where tunnels may be using the same IP scheme.
Occasionally, it would be beneficial to allow access to the internet for downloading drivers and such.
So far, all of the supporting documentation for internet access via VRF refers to MPLS connections.
Here is how one of the tunnels is configured for TEST VRF.
vrf definition TEST
 rd 22:22
 address-family ipv4
 exit-address-family
crypto keyring TEST
  pre-shared-key address x.x.x.x key 6 Y`J`B]Q\YFOW\HW[BWCbOf_]QTWggK\ER
crypto isakmp profile TEST
   vrf TEST
   keyring TEST
   match identity address x.x.x.x 255.255.255.255
crypto map OUTSIDE 5 ipsec-isakmp
 set peer x.x.x.x
 set transform-set ESP-AES-256-SHA
 set isakmp-profile TEST
 match address TEST
interface GigabitEthernet1/0/0
 ip address #.#.#.# 255.255.255.224
 negotiation auto
 crypto map OUTSIDE
interface GigabitEthernet1/0/1.22
 encapsulation dot1Q 22
 vrf forwarding TEST
 ip address 10.0.0.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 #.#.#.#
ip route vrf TEST 192.168.0.0 255.255.255.0 #.#.#.# global
ip access-list standard VTY
 permit any
ip access-list extended TEST
 permit ip 10.0.0.0 0.0.0.255 192.168.0.0 0.0.0.255
Hello
You need to have a VRF nat and VRF default route to accomplish this
ip nat inside
ip nat outside
ip route vrf TEST 0.0.0.0 0.0.0.0 <XXXXX) global
ip nat inside source list <acl to allow the private pool>  pool <pool to specify the public> vrf  TEST
regards
Harish
