Need help determining why my nothing is showing up after setting up site to site vpn
JoeSS8700
Ok, so I'm am trying to figure out why I can't get nothing to show up when I do sh crypto isakmp sa or sh crypto ipsec sa. I did the basic setup for a site to site vpn and I can ping across both networks just fine no problem. So when I ping from a pc in the 172.16.0.0 network to 192.168.0.0 network there is no problem at all because the pings are recieved just fine. But when I go to sh crypto isakmp sa, there is just nothing there and I can't for the life of me figure out why. I looked at my sh run for both routers and everything looks fine, but I guess I may be overlooking something. If someone could help me diagnose this problem I would truely appreciate.   I have attached my packet tracer file and both routers are using the password binary. I put the password on there for the sake of it and to have a more real feel.
JoeSS8700
Here are the show runs for both routers
Router Main A
hostname RmainA
ip dhcp pool ITS
network 172.16.150.0 255.255.255.0
default-router 172.16.150.1
option 150 ip 172.16.150.1
username ciscosdm privilege 15 password 0 ciscosdm
crypto isakmp policy 2
encr aes 128
authentication pre-share
group 2
crypto isakmp key binary address 192.0.2.27
crypto ipsec transform-set yasser esp-aes 128 esp-sha-hmac
crypto map vader 100 ipsec-isakmp
set peer 192.0.2.27
set pfs group2
set transform-set yasser
match address S2S-VPN-TRAFFIC
no ip domain-lookup
spanning-tree mode pvst
interface Loopback0
ip address 172.16.95.100 255.255.255.255
interface FastEthernet0/0
ip address 192.0.2.25 255.255.255.248
duplex auto
speed auto
crypto map vader
interface FastEthernet0/0.1
no ip address
interface FastEthernet0/1
description TRUNK TO MAIN SWITCH A
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.240
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.0
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 172.16.30.1 255.255.255.0
interface FastEthernet0/1.40
encapsulation dot1Q 40
ip address 172.16.40.1 255.255.255.0
interface FastEthernet0/1.70
encapsulation dot1Q 70
ip address 172.16.70.1 255.255.255.0
interface FastEthernet0/1.95
encapsulation dot1Q 95
ip address 172.16.95.1 255.255.255.240
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 172.16.100.1 255.255.255.0
shutdown
interface FastEthernet0/1.150
encapsulation dot1Q 150
ip address 172.16.150.1 255.255.255.0
interface Serial0/0/0
description TO BRANCH
ip address 10.0.0.1 255.255.255.252
clock rate 64000
shutdown
interface Serial0/0/1
no ip address
clock rate 125000
shutdown
interface Serial0/1/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface FastEthernet1/0
switchport mode access
shutdown
interface FastEthernet1/1
shutdown
interface FastEthernet1/2
shutdown
interface FastEthernet1/3
shutdown
interface FastEthernet1/4
shutdown
interface FastEthernet1/5
shutdown
interface FastEthernet1/6
shutdown
interface FastEthernet1/7
shutdown
interface FastEthernet1/8
shutdown
interface FastEthernet1/9
shutdown
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
shutdown
interface FastEthernet1/13
shutdown
interface FastEthernet1/14
shutdown
interface FastEthernet1/15
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.0.0.3 area 0
network 192.0.2.24 0.0.0.7 area 0
network 172.16.0.0 0.0.0.255 area 1
network 172.16.1.0 0.0.0.255 area 1
network 172.16.10.0 0.0.0.255 area 1
network 172.16.20.0 0.0.0.255 area 1
network 172.16.30.0 0.0.0.255 area 1
network 172.16.70.0 0.0.0.255 area 1
network 172.16.95.1 0.0.0.0 area 1
network 172.16.95.0 0.0.0.15 area 1
network 172.16.100.0 0.0.0.3 area 1
network 172.16.150.0 0.0.0.255 area 1
network 0.0.0.0 255.255.255.255 area 1
default-information originate
ip classless
ip default-network 10.0.0.0
ip access-list extended S2S-VPN-TRAFFIC
permit ip 172.16.0.0 0.0.0.255 192.168.0.0 0.0.0.255
dial-peer voice 150 voip
destination-pattern 20..
session target ipv4:192.168.150.1
telephony-service
max-ephones 30
max-dn 30
ip source-address 172.16.150.1 port 2000
auto assign 1 to 30
ephone 1
device-security-mode none
mac-address 0014.6AAC.2355
type 7960
ephone 2
ephone 3
ephone 4
ephone 5
ephone 6
ephone 7
ephone 8
ephone 9
ephone 10
ephone 11
ephone 12
ephone 13
ephone 14
ephone 15
ephone 16
ephone 17
ephone 18
ephone 19
ephone 20
ephone 21
ephone 22
ephone 23
ephone 24
ephone 25
ephone 26
ephone 27
ephone 28
ephone 29
ephone 30
line con 0
exec-timeout 90 0
password binary
logging synchronous
login
line vty 0 4
password binary
login local
end
Router Branch
hostname Rbranch
enable secret 5 $1$KFpd$ZTYwy8CoWVhjvBXiDDoQx0
ip dhcp pool ITS
network 192.168.150.0 255.255.255.0
default-router 192.168.150.1
option 150 ip 192.168.150.1
encr aes 128
group 2
crypto isakmp key binary address 192.0.2.25
set peer 192.0.2.25
set pfs group2
no ip domain-lookup
interface Loopback0
ip address 192.168.95.100 255.255.255.255
ip address 192.0.2.27 255.255.255.248
duplex auto
speed auto
crypto map vader
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
encapsulation dot1Q 1 native
ip address 192.168.10.1 255.255.255.0
ip address 192.168.20.1 255.255.255.0
ip address 192.168.30.1 255.255.255.0
ip address 192.168.95.1 255.255.255.240
ip address 192.168.150.1 255.255.255.0
ip address 10.0.0.2 255.255.255.252
clock rate 2000000
shutdown
ip address 10.0.0.6 255.255.255.252
ip ospf priority 128
clock rate 2000000
shutdown
no ip address
clock rate 2000000
shutdown
no ip address
clock rate 2000000
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
network 10.0.0.4 0.0.0.3 area 0
network 192.168.0.0 0.0.0.255 area 2
network 192.168.1.0 0.0.0.255 area 2
network 192.168.10.0 0.0.0.255 area 2
network 192.168.20.0 0.0.0.255 area 2
network 192.168.30.0 0.0.0.255 area 2
network 192.168.95.0 0.0.0.15 area 2
network 192.168.95.100 0.0.0.0 area 2
network 192.168.100.0 0.0.0.3 area 2
network 192.168.150.0 0.0.0.255 area 2
ip classless
ip default-network 192.168.100.0
permit ip 192.168.0.0 0.0.0.255 172.16.0.0 0.0.0.255
destination-pattern 10..
session target ipv4:172.16.150.1
telephony-service
max-ephones 30
max-dn 30
ip source-address 192.168.150.1 port 2000
auto assign 1 to 30
ephone 1
mac-address 0008.E399.DC43
type 7960
ephone 2
mac-address 000D.287E.3A28
type 7960
ephone 3
ephone 4
ephone 5
ephone 6
ephone 7
ephone 8
ephone 9
ephone 10
ephone 11
ephone 12
ephone 13
ephone 14
ephone 15
ephone 16
ephone 17
ephone 18
ephone 19
ephone 20
ephone 21
ephone 22
ephone 23
ephone 24
ephone 25
ephone 26
ephone 27
ephone 28
ephone 29
ephone 30
line con 0
exec-timeout 90 0
password binary
logging synchronous
login
line vty 0 4
password binary
login local
end
Anyone have any clues of what I'm doing wrong?
