Not able to telnet or ssh to outside interface of ASA and Cisco Router
wuyuke1982
Dear All
Please help me with following question, I have set up testing lab, but still not work.
it is Hub and spoke site to site vpn case, connection between hub and spoke is metro-E, so we are using private ip for outside interface at each site.
Hub -- Juniper SRX
Spoke One - Cisco ASA with version 9.1(5)
spoke two - Cisco router with version 12.3
site to site vpn has been successful established. Customer would like to telnet/ssh to spoke's outside ip from Hub(using Hub's outside interface as source for telnet/ssh), or vise versa. Reason for setting up like this is they wants to be able to make configuration change even when site to site vpn is down. Sound like a easy job to do, I tried for a long time, search this forum and google too, but still not work.
Now I can successfully telnet/ssh to Hub SRX's outside interface from spoke (ASA has no telnet/ssh client, tested using Cisco router).
Anyone has ever done it before, please help to share your exp. Does Cisco ASA or router even support it?
When I tested it, of cause site to site vpn still up and running.
YK
Hello YK,
On this case on the ASA, you should have the following:
CConfiguring Management Access Over a VPN Tunnel
If your VPN tunnel terminates on one interface, but you want to manage the ASA by accessing a different interface, you can identify that interface as a management-access interface. For example, if you enter the ASA from the outside interface, this feature lets you connect to the inside interface using ASDM, SSH, Telnet, or SNMP; or you can ping the inside interface when entering from the outside interface. Management access is available via the following VPN tunnel types: IPsec clients, IPsec LAN-to-LAN, and the AnyConnect SSL VPN client.
To specify an interface as a mangement-only interface, enter the following command:
hostname(config)# management access management_interface
where management_interface specifies the name of the management interface you want to access when entering the security appliance from another interface.
You can define only one management-access interface
Also make sure you have the pertinent configuration for SSH, telnet, ASDM and SNMP(if required), for a quick test you can enable on your lab Test:
  SSH
- ssh 0 0 outside
- aaa authentication ssh console LOCAL
- Make sure you have a default RSA key, or create a new one either ways, with this command:
    *crypto key generate rsa modulus 2048
Telnet
- telnet 0 0 outside
aaa authentication telnet console LOCAL
Afterwards, if this works you can define the subnets that should be permitted.
On the router:
!--- Step 1: Configure the hostname if you have not previously done so.
hostname Router
!--- aaa new-model causes the local username and password on the router
!--- to be used in the absence of other AAA statements.
aaa new-model
username cisco password 0 cisco
!--- Step 2: Configure the router's DNS domain.
ip domain-name yourdomain.com
!--- Step 3: Generate an SSH key to be used with SSH.
ip ssh time-out 60
ip ssh authentication-retries 3
!--- Step 4: By default the vtys' transport is Telnet. In this case,
!--- Telnet and SSH is supported with transport input all
line vty 0 4
transport input All
*!--- Instead of aaa new-model, the login local command may be used.
no aaa new-model
line vty 0 4
  login local
Let me know how it works out!
Please don't forget to Rate and mark as correct the helpful Post!
David Castro,
